Open UpCell
An open source, USB Type C PD, single-cell BMS for Lithium batteries
Public Chat
Open UpCell is a USB Type-C PD single cell lithium-ion battery management system with either 5 v or 3.3 v outputs, up to 14 v input, and an i2c interface for battery and charge status monitoring. You can check battery fuel gauge, charge status, charge voltage selection, charge current selection, and more via the provided Arduino IDE and PlatformIO SDKs. Output and i2c voltage is selectable between 3.3 v and 5 v, and the board comes with Seeed Groove (JST-PH) and Stemma QT (JST-SH) 4 pin connectors to enable plug and play operation with pre-existing projects. Open UpCell is also capable of being a simple, rudimentary inverter for a project, with an up to 15 W output (5 v, 3 A) - enough to power a Raspberry Pi Board or small router.
Open UpCell enables rapid prototyping of battery-dependent projects while keeping things simple from setup to charging. It can be used to power existing Seeed Grove module chains and Adafruit Stemma QT module chains. It can also keep your projects powered and usable off the grid, perfect for some IoT and Edge projects, like an IoT soil sensor cluster or a simple PIR motion detector. And, at just a few mm larger than a standard 18650 battery, this useful system is small enough to be concealed in a DIY wearable project.
Features & Specifications
  • Safety: Short circuit protection, temperature loop control, input over-voltage protection, input over current protection, overcharge protection, fused input
  • 3.3 v and 5 v output options
  • STEMMA QT and Seeed Groove connectors for plug and play
  • Battery gauge over i2c
  • Charge control, status, and monitoring over i2c (1.8 v, 3.3 v, and 5 v compliant i2c)
  • Arduino IDE SDK for i2c communication
  • 5 v, 9 v, 12 v USB PD and Fast Charge capable (Up to 14 v or 3 A)
  • Compatible with any capacity of Li-Po or 18650 cells, 21600 cell, or equivalent lithium chemistry cell (must be single cell)
  • 1 × BQ25895 1S I2C Battery Charging IC
  • 1 × PPTC fuse 3.8A 12V
  • 1 × 18650 Li-Ion Non-Polarized Cell Holder
  • 1 × NTC 10K
  • 1 × LDO 3.3V 1A
  • Update 13: Data-sheet V/S Real life Testing
    PADMALAYA RAWAL01/27/2023 at 13:20 0 comments
    Hey Tinkerers,
    We are actively testing all the features of Open Upcell and comparing the result against the expected result of Datasheet as well. Here is the Battery Voltage profile from Datasheet and the one we have tested in real-life. We have used Influx for recording and analysing the results.
    Datasheet:
    Real life:
    Our Crowd Supply campaign will be live very soon, SUBSCRIBE the mailing list on Crowd Supply so that you won't miss any update :)
    Crowd Supply Page: https://www.crowdsupply.com/sikra/open-upcell
    Happy Tinkering :)
  • UPDATE 12: Performance Test
    PADMALAYA RAWAL01/25/2023 at 14:42 0 comments
    Hey Creators,
    For last few days we were working on the integration of Open Upcell with InfluxDB IoT platfoem for easy analysis of performance of battery and we have prepared different graphs using parameters such as Input Voltage, battery voltage, charging voltage, charging current, NTC temperature, Environment temperature, etc. Here is one of those graphs.
    We have used ESP32 board and DHT11 temperature and humidity sensor for the same. The code for this is
    //New code with env temp
    #include <WiFiMulti.h>
    #include <InfluxDbClient.h>
    #include <InfluxDbCloud.h>
    #include <Wire.h>
    #include "BQ25896.h"
    #include <Adafruit_Sensor.h>
    #include <DHT.h>
    #include <DHT_U.h>
    #define DHTPIN 2     // Digital pin connected to the DHT sensor
    #define DHTTYPE    DHT11     // DHT 11
    DHT_Unified dht(DHTPIN, DHTTYPE);
    uint32_t delayMS;
    BQ25896  battery_charging(Wire);
    WiFiMulti wifiMulti;
    #define DEVICE "ESP32"
    #define WIFI_SSID "EB LAB"
    #define WIFI_PASSWORD "EB13579@#$fhj5"
    #define INFLUXDB_URL "https://europe-west1-1.gcp.cloud2.influxdata.com"
    #define INFLUXDB_TOKEN "uSG2NN90KiFyXjyOjuO5rJHIp01q3-oBk9A8b7VCwC0iTsiJroAmixPwHZKrcDqOjBHNOracI_dMBFBfrAFu7g=="
    #define INFLUXDB_ORG "6039c76badddc47c"
    #define INFLUXDB_BUCKET "Open Upcell performance test"
    // Set timezone string according to https://www.gnu.org/software/libc/manual/html_node/TZ-Variable.html
    #define TZ_INFO "UTC5.5"
    // InfluxDB client instance with preconfigured InfluxCloud certificate
    InfluxDBClient client(INFLUXDB_URL, INFLUXDB_ORG, INFLUXDB_BUCKET, INFLUXDB_TOKEN, InfluxDbCloud2CACert);
    // Data point
    Point sensor("ENV Temp");
    Point sensor1("NTC Temp");
    Point sensor2("Input Voltage");
    Point sensor3("Charging Voltage");
    Point sensor4("Battery Voltage");
    Point sensor5("Charging Current");
    int rate =100;  //Sampling rate
    bool label= true;
    bool influx_charge_status=true;
    void setup() {
      Serial.begin(115200);
      dht.begin();
      Wire.begin();
      battery_charging.begin();
      WiFi.mode(WIFI_STA);
      wifiMulti.addAP(WIFI_SSID, WIFI_PASSWORD);
      Serial.print("Connecting to wifi");
      while (wifiMulti.run() != WL_CONNECTED) {
        Serial.print(".");
        delay(500);
      Serial.println();
      // Add tags
      //sensor.addTag("device", DEVICE);
      //sensor.addTag("SSID", WiFi.SSID());
      timeSync(TZ_INFO, "pool.ntp.org", "time.nis.gov");
      if (client.validateConnection()) {
        Serial.print("Connected to InfluxDB: ");
        Serial.println(client.getServerUrl());
      } else {
        Serial.print("InfluxDB connection failed: ");
        Serial.println(client.getLastErrorMessage());
    void loop() {
        battery_charging.properties();
        BQ25896::CHG_STAT status = battery_charging.getCHG_STATUS();
        //To keep the influx_charge_status true when the charge status is either of these three: Not charging, pre charge or fast charge
        if ((status == BQ25896::CHG_STAT::NOT_CHARGING)||(status == BQ25896::CHG_STAT::PRE_CHARGE)||(status == BQ25896::CHG_STAT::FAST_CHARGE)){
            influx_charge_status= true;
        //If the charge status is charged, it will make the influx_charge_status = false and stop sending the values
        else {
            influx_charge_status=false;
       if (influx_charge_status==true){
        sensors_event_t event;
        dht.temperature().getEvent(&event);
        sensor.clearFields();
        sensor1.clearFields();
        sensor2.clearFields();
        sensor3.clearFields();
        sensor4.clearFields();
        sensor5.clearFields();
        sensor.addField("Env Temp",event.temperature);
        sensor1.addField("NTC Temp",battery_charging.getTemperature());
        sensor2.addField("Input Voltage",battery_charging.getVBUS());
        sensor3.addField("Charging Voltage",battery_charging.getVSYS());
        sensor4.addField("Battery Voltage",battery_charging.getVBAT());
        sensor5.addField("Charging Current",battery_charging.getICHG());
        Serial.print("Writing: ");
        Serial.println(client.pointToLineProtocol(sensor));
        Serial.println(client.pointToLineProtocol(sensor1));
        Serial.println(client.pointToLineProtocol(sensor2));
        Serial.println(client.pointToLineProtocol(sensor3));
        Serial.println(client.pointToLineProtocol(sensor4));
     Serial.println(client.pointToLineProtocol(sensor5));
  • UPDATE 11: OSHWA certified✅
    PADMALAYA RAWAL01/19/2023 at 07:29 0 comments
    Hey Supporter,
    We are excited to share that our project is now Certified open source project. We have received the certification from OSHWA with OSHWA UID US002163 . You can check out the open source files on github page (https://github.com/sikra-io/open-lithium-bms/tree/v1.4 ). We are still updating the documentation and files. The CAD files are still not updated on github, we are still finalizing the design so that you can use it without any problem.
    OSHWA certification page: https://certification.oshwa.org/us002163.html
    We are getting closer to the launch date for Open Upcell on Crowd Supply, if you haven't checked it out yet. Please have a look at it and consider subscribing for updates so that you don't miss it.
    Crowd Supply page: https://www.crowdsupply.com/sikra/open-upcell
    Keep Tinkering & supporting :)
  • UPDATE 10: Clear filament test
    PADMALAYA RAWAL01/18/2023 at 16:07 0 comments
    Hey Innovators,
    Back on the enclosure update, we have printed out the latest enclosure in Clear PLA PRO filament. The enclosure in clear material looks pretty cool to me and also by doing so I am able see the indicator LEDs as well.
    We are still playing with settings to print the enclosure in such a way that we will be able to see through it. What are you suggestion on this? Should we use clear material or go with the colored one? Here are a few pictures. You can checkout previous logs of enclosure in colored material for comparison.
    Also, don't forget to checkout our Crowdsupply campaign which will be live soon. Also, make to SUBSCRIBE the mailing list on crowdsupply for updates.
    Keep Innovating :)
  • UPDATE 9: Sneak Peak in testing
    PADMALAYA RAWAL01/17/2023 at 13:47 0 comments
    Hey Awesome project creators,
    At present we are working on some tests but the question is which tests? Will you be able to guess them? Let's see, here is a sneak peak for the same. We will share all the instruction once we are done with all the codes and are self-satisfied.
    Our setup for testing:
    Here are some windows that you might need to guess what we are testing 😁
    We will reveal it soon, stay tuned w/ us. And don't forget to check out and  subscribe for our crowd supply campaign : https://www.crowdsupply.com/sikra/open-upcell
    Till then , Happy making :)
  • UPDATE 8: The Clever CAD Design
    PADMALAYA RAWAL01/13/2023 at 09:21 0 comments
    Hey Tinkerers,
    Here comes another revision of enclosure. We have designed it in two pieces by utilising the huge 1mm space 😂 which I mentioned in one of our previous post. If you see it carefully we have used the space available on perimeter on both sides and we made it to snap fit. Sending the files for 3D printing.
    Till then, you can checkout our crowdsupply page: https://www.crowdsupply.com/sikra/open-upcell
    We would love to hear suggestion & reviews from you. Comment them below.
    Happy Tinkering :)
  • UPDATE 7: Arduino & processing code
    PADMALAYA RAWAL01/12/2023 at 14:03 0 comments
    Hey Creators,
    We are now actively working on Arduino as well as on processing code to plot various graphs according  to the requirement. Here is a sneak peak into the circuit, code and output. Don't worry we will present it in more readable format for you once we will complete it. Till then, do checkout our Crowd Supply campaign which will be live very soon.
    Crowd supply page: https://www.crowdsupply.com/sikra/open-upcell
    Happy creating :)
  • UPDATE 6: The clever CAD design
    PADMALAYA RAWAL01/11/2023 at 07:49 0 comments
    Hey Makers,
    Our last 3D-printed part was good enough and holds our PCB so well but our goal was to build an enclosure for which we don't need any adhesive material or screws to hold the Open Upcell in place. And we just discovered a huge space around the perimeter of PCB which is 1 mm😂.
    Let's see how we will be able to use this huge space to hold the Open Upcell in place. Don't forget to check out our project campaign on Crowdsupply. You can either search "Open upcell" on Crowd Supply or use this link:https://www.crowdsupply.com/sikra/open-upcell
    Happy Tinkering  :)
    Stay tuned for more updates .............
  • UPDATE 5: 3D printed enclosure V3
    PADMALAYA RAWAL01/10/2023 at 12:52 0 comments
    Hey Developers,
    We are now getting close to the final version of the enclosure. Today, we have our 3D-printed V3 of the enclosure. The board fits very well in it. The only feature which is left for now is a mechanism to hold the board in place w/o any screws/tape/glue. We are already working on it, till then stay tuned.
    I hope you have already checked out our Open Upcell Project on Crowdsupply. If not, check it out by searching "Open Upcell" on crowd supply or just by clicking this link.
    Happy Hacking :)
  • UPDATE 4: 3D printed enclosure V1 modified
    PADMALAYA RAWAL01/09/2023 at 15:09 0 comments
    Hey Innovators,
    Before printing the latest version of our 3D model, we modified the previous version a bit and re-printed it to compare it with the first printed version. It works as it should but it makes the placement of board a bit wobbly. So, we have sent the latest CAD file printing too. Below is the modified version of V1.
    We would love to know your suggestions about the same. Btw, have you checked out the CROWD SUPPLY campaign yet for which we are building this enclosure?
    Follow the project for upcoming updates. Keep innovating :)
View all 13 project logs
  • 1
    3D Printer setting & specifications
    We have used Creality's Ender 3 V2 which has a bed size of 220mm*220mm and settings for slicing software (Cura in my case are as follows) along with other  information:
    Bed Temperature: 60℃ (Room temperature is 11℃ )
    Nozzle Temperature: 205℃
    Support: No
    Material: Red PLA+
    Layer height: 0.2mm
    Speed: 50mm/s
    Retraction distance: 10mm
    Retraction speed: 50mm/s
    Build plate adhesion: None
    Infill: 20%
    Nozzle size: 0.4mm
    Nozzle material: Brass
    Time: 1hr 45 min
    Material used: 12g
    If you still need any help, let us know & don't forget to SUBSCRIBE to our Crowd Supply campaign for the Open Upcell project.
View all instructions
