Another fragment of the board where the STLink V2 interface is located. This USB interface is used not only for programming the microcontroller but also as a USB Serial Interface. You must agree that this is convenient. But there are some disadvantages. For example the fact that this connector is located on the front panel. Also, it's not far from a retro DB9 connector -- but unfortunately there's no room on the board for large connectors.
h2w
