I corrected last line to compensate 3-cycle overhead for every frame and also fixed order of patterns at the bottom of the screen - perfect version to burn my 1st OTP MCU :)
Final version is 445 words long (87% of PIC12C508) and available on GitLab
Source code also has schematics in it as a comment:
; +5V ; .--* ; # | PIC12C508 ; 470* # | ---v--- ; # \--|1 8|- GND ; | NC -|2 7|--###-\ 1.5 kOhm ; SYNC *-----|3 6|--###--* 680 Ohm ; | IN -|4 5|--###-/| 330 Ohm ; | ------- | ; ----------------###--*---> VIDEO (8 gray levels) ; 1 kOhm
UPDATE: Another 2 TVs running by OTP PC12C508A, both SONY - big CRT one (4:3):
and big LCD one (16:9):
with video :)
As you can see last few shades (5,6,7) are too bright and looks all white (may be because of 1.5V max amplitude). Also there is a space for 48th column on the left side - I'll add it in the next version that will be re-written for heavy macros usage to represent repeating code for visibility purposes...
SHAOS
