Note: added some more photos for clarification.
https://hackaday.com/2022/12/11/a-straightforward-old-fashioned-dac/
Schematic
My assembly consists of two CD4007UBE. CD4007A is given in my book source, which has lower max voltage but is the faster version (30ns vs 20ns; one has to be aware of the general rule not using a faster logic family than necessary because of noise problems). 2R = 100k +/- 1%.
Programming
Generating digital data by means of a Raspberry Pi Pico µC in this project.
MicroPython program for an ad-hoc test (should generate 2.5V):
from machine import Pin lsb = Pin(7, Pin.OUT) # bit0, least significant bit bit1 = Pin(8, Pin.OUT) bit2 = Pin(9, Pin.OUT) bit3 = Pin(10, Pin.OUT) bit4 = Pin(11, Pin.OUT) msb = Pin(12, Pin.OUT) # bit5, most significant bit (2^5 = 32) lsb.high() bit1.high() bit2.high() bit3.high() bit4.low() msb.low()
For more sophisticated applications one can deploy the RP2040 Single-cycle IO block (SIO).
C program would look something like:
void setOutput(int DAC)
*(SIO + 0x014 / 4) = DAC << 7; // we start on GP7
setOutput(15ul);
Applications
SAR ADC, function generator, etc.
Costs
I paid 50 Cents for each IC, and close to 0 Cents for for the resistors.
If you load in the mA range the output voltage driving the resistors will droop depending on the MCU (and which pins and whether you have configured for "high drive" mode).
I already contributed a DAC project which avoids the resistors by using the transconductance of CMOS gates.
