preparing for kits
A project log for Fixietube - Fake Nixie Tube displays
30ml jam jars turned into beautiful LED displays - nixietube like looking without the higher voltage fuzz
davedarkodavedarko 01/06/2018 at 15:002 Comments
I've revisited the base board and the LED board today.
This will be all through hole to sell it as a kit. I know there are smd kits for everything, but this felt more right. Along with a 3D printed socket and one of the jam jars I've recently acquired, this will make one digit.
Bastiaan wrote 01/06/2018 at 15:52 point
Do the resistors and C1 have solderable pads? It doesn't look like solder mask is removed at the pads. I might be interested in a kit, would you also have the option to include the wire mesh etc?
davedarko wrote 01/06/2018 at 16:54 point
I played around with the footprints, they have no stop mask on the other side. The wire mesh needs to be in there, definitely :)
