switched the DS1307 for the DS3231
A project log for Fixietube - Fake Nixie Tube displays
30ml jam jars turned into beautiful LED displays - nixietube like looking without the higher voltage fuzz
davedarkodavedarko 02/21/2015 at 22:330 Comments
and it was so simple! I didn't even change one line of code. I also found out the reason for why the modules were so cheap (1,10EUR) - there were no batteries with it. But I luckily took out the one from the DS1307. So coming up next should be a nice case, finally.
