ESP8266 Parabolic Reflector
Experiment in 3D printing parabolic radio reflectors
Recently, I was asked to come up with a futuristic, space-ey prop for an upcoming video for the 2017 Hackaday Prize. My custom-built, easily transportable parabolic antenna immediately sprang to mind. The idea of a three-meter diameter parabolic dish was rejected for something that isn't insane, but I did go so far as to do a few more calculations, open up a CAD program and start work on the actual design. As a test, I decided to 3D print a small model of this dish. In creating this model, I inadvertently created the perfect WiFi antenna for an ESP8266 module using nothing but 3D printed parts, a bit of epoxy, and duct tape.
This is an experiment to determine if it's possible to 3D print a parabolic WiFi antenna.
Turns out it's very possible.
Standard Tesselated Geometry - 103.21 kB - 01/23/2017 at 00:03
Download
scad - 1.29 kB - 01/23/2017 at 00:03
Download
Standard Tesselated Geometry - 117.51 kB - 12/28/2016 at 04:18
Download
scad - 1023.00 bytes - 12/28/2016 at 04:18
Download
HexCenter.gcode
Gcode for the center in ABS
gcode - 5.45 MB - 12/27/2016 at 02:15
Download
View all 8 files
  • 1 × 3D printed parts
  • 1 × 5 minute epoxy
  • 1 × Duct tape Real duct tape, the kind you put on ducts.
  • 1 × ESP8266
  • Deploying A Dish
    Benchoff01/23/2017 at 01:31 0 comments
    I've aluminized the dish, mounted it to a tripod, and tested it out. Pics:
    I've also written a post on this for Hackaday. You can check that out here.
  • A Feedhorn? No, an ESP
    Benchoff12/28/2016 at 02:28 0 comments
    The center mount has a single 'stovepipe' that allows me to attach a pole for the feedhorn. This is the other end.
    It's designed to hold an ESP-01 module so that the antenna is directly in the center of the dish.
    $fn = 64;
    module esp8266(){
     union(){
         translate([0,-4,-2])
         cube([14.7,25,11], center=true);
         translate([0,-12.5,6])
         cube([12,8,12], center=true);
    module pole(){
     translate([27, 0, -21])
     cylinder(d=6.40, h=30);
    module holder(){
       difference(){
            hull(){
                translate([32,0,0])
                cylinder(d=4, h=10);
                translate([32,5,0])
                translate([32,-5,0])
                translate([10,10,0])
                cylinder(d=4, h=5);
                translate([-10,10,0])
                cylinder(d=4, h=5);
                translate([-10,-20,0])
                cylinder(d=4, h=5);
                translate([10,-20,0])
                cylinder(d=4, h=5);
            esp8266();
            pole();
    holder();
  • Designing the Center Mount
    Benchoff12/27/2016 at 02:14 0 comments
    Meant to hold a 1/4" dowel for the extnetion.
    Hexagon code from Chris Bate
    Uses 1/4-20 flange mount insert on the back, designed for camera tripod
    //  Center mount for 3D printed parabolic antenna
    //  hackaday.io/project/18866
    //  Brian Benchoff
    //  uses hexagon code from Chris Bate:
    //  https://www.youtube.com/watch?v=KAKEk1falNg
    $fn = 64;
    module phex(wid,rad,height){
    hull(){
            translate([wid/2-rad,0,0])cylinder(r=rad,h=height);
            rotate([0,0,60])translate([wid/2-rad,0,0])cylinder(r=rad,h=height);
            rotate([0,0,120])translate([wid/2-rad,0,0])cylinder(r=rad,h=height);
            rotate([0,0,180])translate([wid/2-rad,0,0])cylinder(r=rad,h=height);
            rotate([0,0,240])translate([wid/2-rad,0,0])cylinder(r=rad,h=height);
            rotate([0,0,300])translate([wid/2-rad,0,0])cylinder(r=rad,h=height);
    module plug(){
        difference(){
        cylinder(d=12,h=30);
        translate([0,0,-1])
                cylinder(d=6.40,h=25);
    module metaAdapter(){
        union(){
            translate([0,0,10]){
                difference(){
                phex(68,0.1,20);
                    translate([0,0,21])
                        phex(64,0.1,19);
                    translate([0,0,1])
                        cylinder(d=8,h=20);
                    translate([0,0,18.5])
                        cylinder(d=20,h=5);
                    translate([0,15,1])
                        cylinder(d=4,h=25);
            intersection(){
                translate([0,0,-10])
                phex(80,0.1,20);
                translate([0,0,50])
                   sphere(d=120);
           translate([27,0,-20])
            plug();
    module adapter(){
        difference(){
            metaAdapter();
            translate([20,13,-15])
            cylinder(d=10, h=50);
            translate([20,13,22])
                rotate([-90,0,-60])
                    cylinder(d=10,h=10);
                cylinder(d=6.4,h=40);
    adapter();
  • Commissioning A Dish
    Benchoff12/14/2016 at 05:16 0 comments
    The dish is printed. only thing left to do is add the center mount, metalize the dish, and place the feedhorn.
    The diameter of the dish is 49mm, which means the depth of the dish is 6mm. We're dividing everything by two here (units are arbitrary), so the feed horn must be 25mm from the bottom of the dish. This means the feed horn must be 19mm above the 'points' of the dish.
    Knitting needles and hot glue.
  • Designing a dish
    Benchoff12/09/2016 at 19:14 0 comments
    diameter 98, depth 12, Focal length 50. Units are arbitrary.
    I scaled this 500% when 3D printing it, so the actual specs are:
    490mm diameter, 60m depth, focal length 250.
    What do we end up with?
View all 5 project logs
offtherails2010 wrote 03/18/2019 at 17:11 point
Good day to you !
FANTASTIC PROJECT !!!
2 things though;
1. Where do you solder the wires onto the ESP-01 module to be able to use this antenna ?? unclear.
2. Just curious and not quite understanding the two ESP Programming Sketches, what exactly are the for and what do they do, just this extra description would be greatly appreciated and many thanks in advance, sorry if this question sounds silly for an obvious answer but i am still learning about this ESP8266 platform and struggling a lot as, well, um... im old lol
Thanks LOADS in advance, really also be grateful for positive responses, if you lot on the internet aint got anything nice to say then STFU and keep it to yourselves LOL !
Morning.Star wrote 01/25/2017 at 11:18 point
Thats really tidy, nice work. Makes mine look horrible lol. https://hackaday.io/project/19582
