LampSoundSensor.py
Simple, straightforward MicroPython code for using a sound sensor with your lamp board.
py -
1.63 kB -
06/11/2025 at 18:30
Download
LampMotionSensor.py
py -
1.61 kB -
06/11/2025 at 18:18
Download
LampButton.py
py -
1.74 kB -
06/11/2025 at 18:18
Download
PCB Lamp Workshop - Controller Board v3.1.step
STEP file with grove/crowtail connectors
step -
6.83 MB -
02/28/2024 at 19:24
Download
PCB Lamp Workshop - Square.stp
STEP file
stp -
1.50 MB -
04/26/2023 at 00:27
Download
PCB Lamp Workshop - Line.stp
STEP file
stp -
1.36 MB -
04/26/2023 at 00:27
Download
PCB Lamp Workshop - Horseshoe.stp
STEP file
stp -
1.85 MB -
04/26/2023 at 00:27
Download
PCB Lamp Workshop - Circle.stp
STEP file
stp -
1.99 MB -
04/26/2023 at 00:27
Download
PCB Lamp Workshop - Controller and Lamp Board Outlines v3.dxf
2D PCBA's in DXF file format
AutoCAD DXF -
4.19 MB -
02/29/2024 at 22:49
Download
PCB Lamp Workshop - Controller and Lamp Board Outlines v3.1.ai
2D PCBA's in Adobe Illustrator file
postscript -
345.22 kB -
02/28/2024 at 21:23
Download
91290A013_Alloy Steel Socket Head Screw.STEP
Socket head screws work better because there is not a lot of space for mounting holes on the boards.<br><a target="_blank" rel="noopener noreferrer" href="https://www.mcmaster.com/91290A013/">https://www.mcmaster.com/91290A013/</a>
step -
425.34 kB -
04/26/2023 at 01:02
Download
91290A013_Alloy Steel Socket Head Screw.PDF
Adobe Portable Document Format -
134.61 kB -
04/26/2023 at 01:02
Preview
90592A075_Steel Hex Nut.STEP
<a target="_blank" rel="noopener noreferrer" href="https://www.mcmaster.com/90592A075/">https://www.mcmaster.com/90592A075/</a>
step -
243.57 kB -
04/26/2023 at 01:02
Download
90592A075_Steel Hex Nut.PDF
102.61 kB -
04/26/2023 at 01:02
Preview
Data Sheet - Raspberry Pi Pico W.pdf
Raspberry Pi Pico W documentation.
18.84 MB -
03/03/2023 at 20:39
Preview
Data Sheet - 987650-6631.PDF
Flat flex (ribbon) cable data sheet.<br>We are using the 6" OR 10" CABLE (FFC/FPC 6POS 1MM)<br><a target="_blank" rel="noopener noreferrer" href="https://www.digikey.com/en/products/detail/molex/0982670211/3469487">https://www.digikey.com/en/products/detail/molex/0982670211/3469487</a>
913.87 kB -
03/03/2023 at 20:33
Preview
Data Sheet - WS2812B.pdf
RGB LED's data sheet.
347.03 kB -
03/03/2023 at 20:33
Preview
Data Sheet - QRE1113-D.PDF
Miniature Reflective Object Sensor data sheet.
328.92 kB -
03/03/2023 at 20:33
Preview
Optical_Sensor_v2.py
x-python -
1.69 kB -
03/07/2024 at 02:59
Download
