Electroadhesives have been around for a while now. However they are not commercially available and information on them can be difficult to find. When I learned about electroadhesives I was extremely excited and I just had to make my own!
I have done a lot of research on electroadhesives and how they work.
I have developed a method for fabricating electroadhesive pads at home! The process is still being refined to ensure the best process for making high quality electroadhesives.
I am also experimenting with the silicone thickness and electrode patterns in an attempt to improve adhesion strength.
I have searched extensively and have only found a couple of instructions on how to make an electroadhesive pad. However none of these instructions provided a high quality electroadhesive that you can make at home. So I decided to share my project and provide instructions for my electroadhesives that can be made at home with easy to acquire materials.
Hello,
How much voltage do you need to get a paper to stick on the surface of the electroadhesive pad?
