The basics of the code pt.2 - Switch Hook and pulses
A project log for Cellular conversion of vintage rotary phone
GSM conversion for rotary phone, using Arduino Pro Mini with Atmega328, a QCX601 SLIC module and a SIM800 breakout board.
johan-berglundJohan Berglund 12/12/2016 at 18:170 Comments
Now this needed some more attention. The switch hook pin (SHK) of the QCX601 not only tells us if the receiver is on hook or not. Due to the way pulse dialing works, it also presents us with the pulses from the rotary dial. To keep track of everything that's happening on that pin, we have to do some timing work again.
With the receiver on hook SHK is LOW, and off hook SHK is HIGH, so pulses coming in will be SHK going low about 60 milliseconds for every pulse. If the time since the last pulse is more than 500 ms we know we just got a complete digit. For accuracy and immunity against false pulses we want 10 to 15 ms of debouncing, so that's another timing thing to the list. To know when we have a complete number, we assume that ten digits is a complete number (you can easily change this) and if the number is shorter, it will be dialed anyway if there are no new pulses for six seconds. Finally, if we put the receiver back on hook for two seconds or more, the dialing should be aborted and we should go back to the idle state. So, we have a bunch of timings to define...
#define tNewDig 500     // time since last SHK rising edge before counting for next digit
#define tHup 2000       // time since last SHK falling edge before hanging up/flushing number
#define tComplete 6000  // time since last SHK rising edge before starting call
#define tDebounce 15    // debounce time
And then the code being looped while in the number getting state:
// count groups of pulses on SHK (loop disconnect) until complete number
// if single digit, fetch stored number
// then make call
if (pulses && (unsigned long)(currentMillis - lastShkRise) > tNewDig) {
  // if there are pulses, check rising edge timer for complete digit timeout
  digit = pulses - 1; // one pulse is zero, ten pulses is nine (swedish system)
  // for systems where ten pulses is zero, use code below instead:
  // digit = pulses % 10;
  Serial.println(digit); // just for debug
  // add digit to number string
  number += (int)digit;
  digits++;
  pulses = 0;
if ((shkState == LOW) && (edge == 0)) {
  edge = 1;
} else if ((shkState == HIGH) && (edge == 1)) {
  pulses++;
  Serial.print(". "); // just for debug . . . . .
  edge = 0;
if ((digits && (shkState == HIGH) && ((unsigned long)(currentMillis - lastShkRise) > tComplete)) || digits == 10) {
  // if completed number (full 10 digits or timeout with at least one digit)
  // check if shortnumber/fave and then tell GSM board to initiate call
  if (digits == 1) getFave();
  Serial.print("Number complete, calling: ");
  Serial.println(number);
  number.toCharArray(numArray, 11);
  #if defined(GSM_MODULE)
  call.Call(numArray);
  #endif
  state = ACTIVE_CALL;
if ((shkState == LOW) && (unsigned long)(currentMillis - lastShkFall) > tHup) {
  // reciever on hook, flush everything and go to idle state
  flushNumber();
  Serial.println("On hook. Flushing everything. Going idle.");
  state = IDLE_WAIT;
Like that. As you can see, I also put in a speed dial function where single digit numbers are checked against a list with the getFave() function and replaced with complete numbers. Also, you can see the default state of the code is for use with Swedish phones where the dial goes from 0 to 9. That's the line saying...
digit = pulses - 1;
Most likely you don't want that, so you should use this line instead...
That % in there (modulo) makes the digit value the remainder when dividing the number of pulses by ten. Basically it's using wrap around to get 0 instead of 10. I stole this little gem, I admit that. Looks so much nicer than the if-based alternative, and I got smarter by looking the % thing up ;)
As for the debouncing of SHK, it's done whatever state we are in, and it looks like this. The currentMillis used for all timings is set here too.
currentMillis = millis(); // get snapshot of time for debouncing and timing
// read and debounce hook pin
currentShkReading = digitalRead(shkPin);
if (currentShkReading != lastShkReading) {
  // reset debouncing timer
  lastShkDebounce = currentMillis;
if ((unsigned long)(currentMillis - lastShkDebounce) > tDebounce) {
  // debounce done, set shk state to debounced value if changed
  if (shkState != currentShkReading) {
    shkState = currentShkReading;
    if (shkState == HIGH) {
      lastShkRise = millis();
    } else {
      lastShkFall = millis();
lastShkReading = currentShkReading;
