Features
- Works on
- Windows
- Mac (Intel, M1)
- Linux (x64, ARM64)
- Raspberry Pi (ARMv6, ARMv7)
- Anything else go can be compiled on
- Extensive templating system through Nunjucks
- Extensive random generator system
- Various connection methods
- Windows Direct Printing
- Raw USB Printing
- CUPS (Linux, Mac)
- Serial
- Import & Export templates and data sources
- Fast access to external data sources like Open5e (instant access to SRD monsters, spells and more)
- Import FoundryVTT Modules to access the data of even more Systems
- Edit templates in your favorite editor (e.g. Visual Studio Code) and get live preview
Printer Requirements
At the moment Sales & Dungeons only supports the ESC/POS (Epson Standard Code) control codes, which is still one of the most used control code set. Check if a thermal printer you are interested in mentions ESC/POS or Epson in the description or manual.
In general the rule of thumb is:
- Most cheap chinese thermal printer found on Amazon or AliExpress support it
- Most epson thermal printer obviously support it
- A lot of older Serial printer (like Metapace T-1) also support it
Daniel S.
David Gitz
Atheros
Jakob Kilian
Awesome!
