The Idea
A project log for Phi Go
A Linux computer on board with extra power and connectivity options
Mastro GippoMastro Gippo 07/12/2014 at 22:300 Comments
It’s been almost ten years from the enormous success of the Linksys WRT54G hacking, bringing an affordable embedded Linux system to the masses. Since then, a huge amount of incredible hacks came to light thanks to the popularity of cheap Linux routers, like the TP-link TL-WR703N, my favorite.
Then the Cambridge University came along and designed the Raspberry Pi, and this was the first cheap mainstream single board computer to hit the market, followed closely by a plethora of other options like the BeagleBone, the pcDuino, the Cubieboard and many other.
All these platforms offer good processing power and a bunch of GPIOs and peripherals, but I want more.
40 dollars at the dodgy cell phone market in Shenzhen can buy you this really nice phone, in a retail box with included headphones, charger and two batteries. This phones core is a Spreadtrum SoC, with a dual core Cortex A5 running at 1.2GHz, GSM, GPRS and WiFi connectivity, a big screen with capacitive touch and two cameras that may not excite a photographer but seem good enough for some serious OpenCV trickery.
So, my idea is to make a development platform out of cheap Chinese SOCs! Mediatek produces a nice range of chips with interesting features, with CPUs that can range from a dual core Cortex A5 to an octacore with four Cortex A17 and four Cortex A7. These chips are quite cool, because they’re designed to include a lot of functionality in a single package, so my board will have a lot of features that are not available on your average raspberry:
I will also design a cheaper, less powerful board for smaller applications.
All this goodness will enable a lot of interesting projects, for example the first thing that comes to my mind is a completely standalone home automation and alarm system, interfacing with e.g. an ANT sensor network and using the GSM connection when the WiFi is not available to alert the user.
But the first project that I personally would like to build with this platform would be a port of the Open Vehicle Monitoring System (http://www.openvehicles.com/), a small device that you can connect to your electric car’s diagnostic port and allows you to remotely check the battery state of charge and do all sorts of cool stuff like turning the AC on before you get to the car or track it with the embedded GPS.
Hold on for the next article where I'll talk about the problems that I will have to deal with and more!
