Print the enclosure with the provided STL files.
Although Tom provides a link to PCBWay to order directly this won't work since it is NOT THE SAME PCB.
The PCB Gerbers are available in the files.
I used four M2 x 8mm screws to close the enclosure and one fragment of transparent 1.75mm filament as a light guide for the LED.
The STLs can be printed on an FDM 3D printer but for best results I recommend using the SLS capability of your PCB provider. I had good success with JLC PCB (not sponsored, just a happy customer) and their SLS black nylon for other projects. New photos when I receive the parts.
The whole project is licensed CC BY-NC-SA.
CYUL
gokux
Lithium ION
Mukesh Sankhla
