GPS Network Time Server
A GPS Disciplined Network Time Server with a Local Display
Having all machines on a local net thinking it is the same time is a good thing. It makes revision control systems and the Make utility happier. The network in my shop is air-gapped from the wild internet, so outside time servers are not accessible. A local time server simplifies keeping the times on those machines synchronized. This server was built from leftovers of previous projects. A Raspberry Pi 2 is used to run the network, ntp daemon, and display drivers. A leftover GPS board supplies the time reference. Display drivers, an I2C mux board, an ambient light sensor, a DIP switch board and a power supply round out the electronics. Add some sheet metal and software and it is complete.
This project kind of grew rather than being designed. A good bit of the direction was based on parts I could get with the chip availability problems of 2022. Last summer, I decided to build a bunch of the cost optimized version of my LED Matrix display driver boards while I could get the parts. When the construction of the boards was complete, I built a test fixture to hold several of the displays, a miscellaneous LED controller board, the I2C mux board and ambient light sensor board. Pretty much anything that uses these displays uses all of these components. The ambient light sensor board is the only "new" design because the previous sensor was unavailable. Having these components all mounted nicely and wired up for doing the driver software development, it occurred to me that it would be a good start on the display for a time server.
Display Test Fixture
Initially, I did not want to use a Linux based system to run the server on. I have a couple of different eval boards for microcontrollers that have ethernet hardware support. The prospects of writing a GPS disciplined Network Time Protocol server to run on a network stack of unknown heritage were not appealing to me. This motivated me toward the Raspberry Pi. All of the display and user interface control would take place via the I2C bus. The GPS (an old Trimble Copernicus II board from previous projects) would interface via the UART and one GPIO pin for the 1PPS signal.
Only 4 of the displays can be run on an I2C bus segment because the driver chips (IS31FL3730) only support 4 choices for their address. Part of the cost reduction that I did on these boards was to remove the expensive I2C bus address translator chips from each display card. Now, I use an 8 way I2C bus multiplexer chip (PCA9547) on a board of it's own to split the I2C bus into up to 8 segments. Two of those segments are used to talk to the 7 characters. The discrete LEDs visible to the left of the top row, between the second and third displays on the top row and between characters on the bottom row are driven by a board using another IS31FL3730 chip. This was done because it is a simple way to control the "miscellaneous" LEDs with a part that I already have driver software written for. The ambient light sensor and the DIP switch board are on separate bus segments because it simplified the cabling. A single byte write to the mux chip is all that is required to select a segment, so the overhead is not bad.
Automatic intensity control for the LED displays is done via the ambient light sensor (VEML7700) chip. The ambient light level is read from the sensor and the result used to look up an intensity value for the LED driver chips from a short table. The contents of this table are empirically derived and there are only 5 different levels at this time. Originally, the ambient light sensor lived on the I2C mux board, but the sensor was completely unavailable (boo, hiss Rohm), so I designed a new board with sites for 2 different sensors from different vendors.
The user interface is done via a 6 wide DIP switch and 2 push buttons. The red button initiates system shutdown and the black one causes the last byte of the ethernet and WIFI addresses to be shown on the display. Only 3 of the switches in the  switch pack are used right now:
  •  12/24 hour time display format.
  • Local or UTC time display.
  • Red or Green display.
    User Controls, Ethernet Interface and USB Connectors.
A TCA9534 I2C I/O expander chip is used to read the switch settings. All of the switch circuits are protected from ESD damage with TVS diodes to ground. Capacitors to ground protect against RF noise in the switch circuits.
I had a couple of Trimble Copernicus II GPS modules and bare boards left over from previous projects. This module is 10 years old and no longer available, but it speaks reasonably standard NMEA and I had them. The boards that I had left over have a local 3.3V LDO regulator and a place to put an RS232 level shifter...
  • Top Level Schematic
    Bharbour03/26/2023 at 20:24 0 comments
    I have been working out a style for drawing top level schematics with a PCB schematic capture package. After a fair amount of messing around, this is the resulting drawing of my Timeserver project.
    Some things could use a little more work, but as a document, this works for me.
    Each individual board is created as a component in my CAD system. Connectors on the board are implemented as "parts" in the same way that you would have two (or 3 if you separate power supply pins) "parts" in a dual OPAMP component. This allows flexibility in how you place the individual connectors on a drawing. The one thing it does not allow is compiling into a net list. Each connector has pins "1", "2", "3"... and this confuses my CAD system because it would not make sense for a dual OPAMP to use pin 1 in both "parts" (other than the power supply pins). The way around this would be to include the connector ID in the pin number. For example on connector J1, pin 1, a name of J1-1 would be a unique name and the CAD system would be fine with that. The down side of this method is that the pin numbers become long and take more space on the drawing.
    The connectors are placed on the drawing and I have drawn a rectangle around each one to represent a board. It would not have to be done this way, it would be possible to scatter the connectors around the schematic in the same way that groups of signals are handled on schematics with large, complex IC's on them. I tend to like working with the connectors for a board gathered into one spot because it makes it easier when poking around with a scope probe to find the signal you are looking for. There is definitely a limit to how far this approach can be scaled though.
    Wire colors would be nice too. I think I can attach colors as a property to wires, but I have not gotten that far yet.
    I went back and edited the schematic library and the top level schematic. The end result is fine, and now it compiles to produce a net list. Top level schematics tend to be large drawings anyway, so the change is not a problem. Being that the purpose of this is to establish the method and start building a library of the PCBs that I have designed, I want to get the best result that I can.
    Has anybody else got a method for drawing top level system schematics and wiring harnesses that works?
  • Raspi RAM Overlay File System Startup issue.
    Bharbour02/08/2023 at 14:12 0 comments
    Since the Raspi2 runs out of a uSD card, minimizing writes seems like a good thing for long term reliability. The version of Raspi OS that I am using, offers "RAM Overlay Root File System" as an option on the raspi-config program. Reading on this indicates that the uSD card is marked read only and a RAM file system accepts the write data, making it non-persistant over resets or power cycles.
    Since the Raspi2B does not have a battery backed real time clock to fetch clock time from at start up, it appears to take the real time from somewhere in the file system, approximating the time that the system shut down. This gets into trouble with the RAM Overlay File System, because the time and date that it fetches looks to be the time and date that the system was changed over to run the RAM Overlay File System instead of the last shutdown time.
    Yesterday, we had a power line drop out for a few seconds. It was long enough to cause the Raspi2B in the time server to re-boot. After the re-boot, the ntpd daemon refused to stay connected to the GPS and PPS time sources.
    When ntpd starts up, it looks at the system time and if it differs too much from the GPS time, it stops listening to the GPS. There is a command line option ( -g) that looks like it should force the system time to match the GPS time, even if the difference is large. The man page on ntpd indicates that this large jump can only occur once. It seems like this should solve the issue of the startup time, but it appears not to be working. Maybe the GPS system had not recovered a 3D fix before the ntpd daemon tried to do the one-time jump, don't know yet. If the ntpd daemon runs for 7 or 8 hours without access to the GPS or PPS time sources (peers), it shuts down. When I noticed the issue with the real time being hours out of sync and ntpd not listening to the GPS, ntpd was still running. I manually set the system time with the date command, and ntpd immediately hooked up with the PPS source again and has been running fine since.
    It's possible that a battery backed real time clock is the answer. It seems like there should be a simpler answer.
    2/12/2023  I think I dodged a bullet on this one. I have some little clock boards with a PCF2127 clock chip, and a battery (as well as an un-needed EEPROM chip) that I designed a few years ago for another project. It turns out that Raspi OS already has drivers for that clock chip included in the distribution. I set it up on my test platform and it works just fine. It also insures that the system clock is very close to GPS time at startup because those PCF2127 clock chips are quite accurate.
    I considered writing a piece of code that will read time out of the GPS data stream and just force the system clock to that value at startup. There are a couple of problems beyond gracelessness with this approach. The amount of time that a GPS unit takes to get a fix can be pretty variable, depending on the environment. It can be up to a minute or so in extremely low signal environments and I don't want to whack the time setting that late in the boot process. Also, the effect on ntpd of doing that are unknown, by me anyway. This box already has a bunch of boards in it, one more will hardly be noticable.
    2/14/2023 The ntp server program ntpd is a large, complex piece of code. I looked through the documentation to see if there was more information on the behavior of the -g option to see if there was an obvious reason that it was not setting the time at startup and could not find one. Resorting to the source code, I followed the track of the -g (force_time_step) option in from the command line parser. It was not obvious why the time step was not doing what I expected.
    Mounting for clock board with easily accessible battery
    There is a place to mount the new clock board in a place where it is easy to access the battery for later changes.
  • Problems with ntpd shutting down
    Bharbour01/19/2023 at 22:09 1 comment
    1/19/2023 Several days into the testing on this box, I am finding that the ntpd time server daemon is disconnecting from the GPS and then 7 hours later, it shuts down. I am still isolating the problem. The bare GPS NMEA and 1pps interface is done via the gpsd daemon. The ntpd daemon interfaces with the gpsd daemon through a shared memory block.
     I have used ntpd in the distant past, and it seems reliable enough. It is pretty complex and the configuration for it is definitely not trivial. In prior applications, I had it talking directly with the GPS modules.
    The Trimble Copernicus II GPS modules have been working well for me in several other applications for years. This is a new board from an old design, so It's possible that the GPS is having problems, but that seems less likely.
    The gpsd daemon is a new one for me and it does not seem to be doing anything that I really need in this application.   My first step is setting up a test platform that has ntpd talking directly with the GPS and removing gpsd.
    I just got the hardware and software together to test this idea. Now it is time to wait and see how it goes.
    If the problem is not solved, I will swap the GPS module with a new design. The Trimble Copernicus II modules are not made anymore and I could not find any around from a credible source at a reasonable price. ST has a new line of low cost GPS modules called Teseo LIV3 and I put together a small breakout board for them before the holidays.
    It is possible that the problem is in the configuration of ntpd, and I am going to leave that one for last because it is going to be the most difficult one to pursue.
    1/26/2023 I am not ready to declare victory on this one, but I have gotten 6 days of operation from ntpd without a shutdown. Previously, I was getting a few hours up to 2 1/2 days before ntpd disconnected from the gps and pps sources. I swapped the Trimble GPS module from my test platform into the box and made the configuration changes necessary to disable gpsd and change ntpd over to use the Trimble TSIP protocol instead of NMEA.
    I added another bicolor LED and plugged it into an unused socket on the misc LED controller board to use as an ntpd status indicator. I wrote the code to exec the ntpq tool and parse the output to determine if ntpd was still connected to the gps and pps sources and added a threshold on the jitter set to 1.0 mS. If the ntpd daemon is shut down, the status LED shows red. If ntpd has disconnected from the gps and pps sources, the LED will show yellow and if the jitter values are > 1.0mS, the LED will show green. If everything is good, the LED is off. This code runs periodically (every 2 minutes right now) and updates the LED as described. This status indicator was added so that I don't have to power up another machine to check the ntpd health, I can just look for the LED.
    At some point, I will re-configure the GPS module that I pulled out and put it on the test platform  to test the GPS module. This is just sort of a sanity thing, I would like to know for sure that the problem was not the hardware. That sounds like a thing for another day though.
    The system is running on the box with the display now, for some longer term testing.
    1/29/2023 Yesterday, at about 02:00, I noticed that the ntpd status LED was showing that it could not communicate with ntpd. Testing manually, ntpd was fine and there was nothing in the logs to indicate that it had a problem. The way the monitor is coded, the LED shows red if it could not communicate with the daemon, so if the monitor had a problem, it would show red also. Thinking about the problem (instead of sleeping), it occurred to me that the monitor had been running about 36 hours when it stopped working. With the monitor running once, every 2 minutes, that is around 1000 iterations, which is suspiciously close to the max number of file descriptors allowed on a process.
    The way that I coded the monitor, upon requesting status, a...
View all 3 project logs
