3D model update: motor retaining screws now have nuts!
A project log for Mini FPV Speed Tank
A small, fully 3D printed tank, designed with a focus on compactness and performance
TobiasTobias 01/16/2023 at 11:570 Comments
I have made a tiny improvement which previously, due to laziness, I had not done yet. Originally, the grub screws that held the motors in place simply threaded into a plastic hole. This was a problem as they could not be screwed in tight without slipping, and then the motor would not be clamped down properly. I added space for some simple M3 nuts, which should mean the screws will screw in much better now.
I have not tested this yet, but it should be a-okay. The 3D models are now updated with this change!
