Features:
- very compact - will fit into handle
- display show status, preset and tip temperature, power, supply voltage, drop, ...
- two buttons
- automatic standby
- sensing supply voltage and tip current
- precise regulation with PID (PSD controller with some modifications)
- supply voltage is from 5V to 15V (best is above 10V)
- designed to supply from LIPO battery 2S (7.4V max is about 18W) or 3S (11.1V max is more than 40W)
- calculating consumed Wh
- heat-up in 5sec from 25 to 400°C (with 40W limit)
- Idle current about 8mA
What is planed:
- case
- battery monitor (warn when battery need charge)
- configuration editor for some constants from PSD controller, power limit, ....
- open-source everything
Videos:
Hi,
very nice project, any plans to make the PCB available.
