Case v-1.0 (v{minus}1.0)
A project log for RT Soldering pen
Soldering pen for Weller RT tips with OLED display
vlkvlk 07/03/2018 at 21:027 Comments
Yes, I know, there is still no news about the case, so, at least something simple....
I try to put this soldering pen into transparent shrinkable tube (ø 10 mm) and seems with very good success, buttons are easy to press, so very good and cheap protection.
.... but one small fail, I forget to put down the protecting foil from the display! ,-D
ilium007 wrote 10/31/2018 at 02:22 point
is there any news on a case design yet ? I’ve seen a few but all seem to lack any sort of mechanical support to take strain off the 3.5mm connector.
ivan003003 wrote 07/13/2018 at 13:21 point
Hi there mr.vlk
I got 1 question about the rt soldering case.
Are you planning to make the case with mr.Otto Winter or you are going to make 1 made by your self ?
Thanks .
http://global-motions.com/ftp/Weller-RT6-Case2.jpg
vlk wrote 07/14/2018 at 05:27 point
Hi Ivan, I working on my own design.
Thanks for asking.
ivan003003 wrote 07/14/2018 at 05:51 point
Ok,thanks you very much :)
elektrinis wrote 07/11/2018 at 12:01 point
Hi vlk,
Nice iron, just bought one.
Can you share a 3D model to print a proper enclosure?
vlk wrote 07/13/2018 at 08:56 point
Thanks for purchasing, 3D model is still not done, some prototype will be soon
deʃhipu wrote 07/04/2018 at 00:39 point
This actually looks pretty good. I wonder if you could just cut some holes in a magic marker, for another improvised case.
