Project Log 2 - sanding and priming and sanding and...
A project log for Baffa-2+ Computer
All-in-one computer using the Baffa-2+ Single Board Computer and based on the standard set of boards from the Baffa-2 Project
augusto-baffaAugusto Baffa 01/19/2023 at 16:110 Comments
Material for finishing the case:
I didn't have the SBC yet and used the original Baffa-2 externally (ie the case worked as monitor+keyboard only). In this example, I used the "Baffa-X" set which works like an MSX1.
Now let's start finishing with the primer paint:
