Hackaday.io Hackaday.io
Sign up Log in
Illuminated Brain
Interactive model of a brain that responds to touch, displaying various patterns.
nicholas-stedmanNicholas Stedman
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
4 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
243
0
4
4
Team (2)
  • nicholas-stedmanNicholas Stedman
  • devlin-macphersonDevlin Macpherson
Join this project's team
ongoing project
This project was created on 01/27/2023 and last updated 4 years ago.
Description
Illuminated model of a brain displays patterns that simulate various states, properties and ailments. When touched, the triggered sensor is reported to a computer running an app on a large screen display that provides detailed information on the relevant ailment and associated treatments. The physical model is 3D printed using SLA and a combination of frosted, opaque and clear resins. The LED display is built from 8 of Adafruit's high density 8x8 dotstar grids. The sensor pads are gold plated earrings!! And the processor is an ESP32. It was produced in collaboration with Globacore Interactive for Dassault's Digital Twin exhibit at CES 2023.
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
A 1:6 scale version of the 1970s PC display.
Project Owner Contributor
Tiny Xerox Alto Display
trevor-flowersTrevor Flowers
Integration of graphical user interfaces, I2C sensors, and the ESP32-S3 microcontroller into a compact avionics instrument simulator.
DIY Avionics Simulator with ESP32
mircemkmircemk
The project uses a combination of ultrasonic sensor, a buzzer and LCD display.
Object detection using HC-RS04
fikunyinadebolafikunyin.adebola
2021 Hackaday Prize
Using 3D Magnetic sensor to visualize a magnet's pole direction, heading, virtual field line & strength on an E-ink Display
Magnetic Field Visualizer
drstoneDr.Stone
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Illuminated Brain", please tell us the reason.
Send message
Remove Member
