USB Power Measurement
A project log for Pi Pico Power Meter
For my electronic developments I need more than one multimeter to get the power. Here it is!
per-simon-saalPer-Simon Saal 04/21/2023 at 13:420 Comments
Some Code adjustments made it possible to track the charging power of my old Nexus 10 tablet.
With a button push the data are logged to a csv file. Another press will stop the logging.
For a decade I was wondering why the charge performance is bad. I can see that the charging current is variing all the time up and down.
After I took the photo I added the ground wire to get the voltage.
