revision log - small things to add
A project log for LoKiPAD
a low cost adafruit macropad clone with integrated todbot MacroPadSynthPlug
davedarkodavedarko 02/27/2023 at 10:310 Comments
With the mod connecting the button of the encoder to the switch on the PICO through a diode, I only need a reset button that's reachable so I can easily upload new programs. There are two pins unpopulated (13 and 16), that are able to be routed as I2C pins, which means I can add a qwiic connector on the board somewhere!
