iv19_bare_min.inonot quite bare minimum sketch to get tubes running. has code in for real time clock and also how i handle various levels of brightness using the blanking pin on the shift register driver chips. the code is a bit rough but should be simple enough to follow :) it also does not incorporate any code to preheat elements (good for making the display appear more responsive)ino - 5.24 kB - 02/07/2023 at 08:44 |
main_schematic.schschematic could use some more work with some more detail about some parts etc. Uploaded it because someone might find it helpful or useful :)sch - 1.28 MB - 02/06/2023 at 05:51 |
tube_schematic.schschematic could use some more work with some more detail about some parts etc. Uploaded it because someone might find it helpful or useful :)sch - 334.78 kB - 02/06/2023 at 05:51 |
tube_schematic.pdfschematic could use some more work with some more detail about some parts etc.Adobe Portable Document Format - 48.61 kB - 02/06/2023 at 05:44 |
main_schematic.pdfschematic could use some more work with some more detail about some parts etc.Adobe Portable Document Format - 64.70 kB - 02/06/2023 at 05:44 |
