Step by step instructions on how to assemble the Swirly Sheep Kit!
Printable Sheep Instructions.pdfPrintable instructions for the Swirly Sheep KitAdobe Portable Document Format - 5.94 MB - 08/24/2023 at 17:14 |
Your kit should include:
1 - Battery
1 - Battery Holder
2 - Yellow, 3mm LED
2 - Green, 3mm LED
2 - Blue, 3mm LED
3 - Red Wires
6 - Blue Wires
3 - 470 ohm Resistors
2 - Wood Screws
1 - Ornament
Give each screw about 3 twists. You don't want them falling out but you want to keep enough room to wrap wires around them.
All LEDs get the same resistor value so you can choose where you want each color LED. *Note: you will want the long leg of the LED to go through the top hole and the short leg to go through the bottom hole on each LED. Once the LEDs are through bend the legs to secure.
