Stainless Steel Housing, welding
A project log for Epoxy concrete CNC milling machine
3-Axis CNC milling machine with solid epoxy concrete cast.
3d-meister3D Meister 07/26/2017 at 11:320 Comments
Here is another step where i weld some stainless steel for machine stand and the housing. My first time ever, welding something. These bars are for the drawer rails under the machine.  3 Drawers will be installed, on the left side for collecting the cooling water and separating dirt from milling. The middle drawer of all kind of important stuff and the right side for electronics, pneumatic and connections, vacuum and air.
