While whizzing through the code trying to scrounge verified keyboard scan codes and flags, I found some some buried treasure in the form of an undocumented test routine. It's not that exciting -- it just fills the current file with some sample text.
F76D ; load the ROM test file into the current file
F76D spewROMtestFile_F76D:
F76D BD F6 18 jsr clearHomeLCD_F618 ; Clear LCD set cursor pos 0
F770 CE FB D5 ldx #aAreYouSureYouWantToOverwrite ; "Are you sure you want to overwrite"
F773 BD F6 69 jsr showText_F669 ; show nts text @ X
F776 BD F7 4E jsr setcpLine1_F74E ; set cursor Line 1
F779 CE FB F8 ldx #aThisFileWithTheRomTestFile?YN ; "this file with the ROM test file? (y/n)"
F77C BD F6 69 jsr showText_F669 ; show nts text @ X
F77F waitKey_F77F:
F77F BD E5 A0 jsr scanKbd_E5A0 ; do key scan and enqueue
F782 BD EB EE jsr dequeueKbdScanCode_EBEE ; pull scan code A (rowno|colno) from keyboard buffer; V set if empty, clear if valid
F785 29 F8 bvs waitKey_F77F
F787 81 22 cmpa #$22 ; 'y' scan code
F789 26 14 bne leave_F79F
F78B BD EB 9B jsr clearThisFile_EB9B ; clear file by resetting pointers
F78E CE FB 44 ldx #a1AlphasmartIsE ; "1 AlphaSmart is easy to use and rugged."...
F791 loop_F791:
F791 A6 00 ldaa 0,x
F793 27 0A beq leave_F79F
F795 08 inx
F796 3C pshx
F797 BD F3 07 jsr sub_F307
F79A 38 pulx
F79B 29 02 bvs leave_F79F
F79D 20 F2 bra loop_F791
F79F leave_F79F:
F79F 39 rts
You get there from scan code 0x21 and with a flag byte_62 being set. Since this is undocumented, I can't figure out what 0x21 is here, but it's still interesting because the implementation of spewROMtestFile_F76D should give me some further clues about file related structures. In particular, the loop_F791 is just pulling a character from ROM until nul is found, and calling sub_F307 with it. So that almost certainly is a 'append character to file' routine. That will be interesting.
Also, long ago I had mentioned finding what looked like an ASCII table that might give a clue to key mapping, but I couldn't find references to it. That turns out to be a red herring; those ASCII sequences are just part of the ROM test file. So I'll fix up that stuff to reflect the new findings.
However, this has given me a new idea: this product emulates a keyboard. It does this to transfer files, but it also acts just like an ordinary keyboard when connected to the PC/Mac. I don't know anything about Mac ADB, but I do have some experience with PS/2 from my TRS-80 emulator days. So I think that maybe I can find the table of PS/2 scan codes and maybe work backwards from there to figure out the keyboard matrix better. Food for thought....
Interesting... Yahknow it hadn't occurred to me this thing needs three different scancode tables; its own keymap, then PS2(* and ADB! Sheesh!
It's handy when you can cross reference an unknown to a known. Even better if you have two knowns to your one unknown!
It's handy when you can correlate a known to an unknown. Even better if you can have two knowns!
