Eager to mine some more scan codes, I am looking at handleKeyScanCode_EE37
EE37 13 63 01 04 brclr byte_63 1 loc_EE3F ; XXX flag? kbd (maybe option? maybe clover?)
EE3B 12 61 01 C9 brset byte_61 1 loc_EE08 ; XXX flag? kbd (any col 9) (maybe option? maybe clover?)
EE3F loc_EE3F:
EE3F 13 64 01 02 brclr byte_64 1 loc_EE45 ; XXX flag? kbd (any col 15)
EE43 8A 80 oraa #$80 ; 'Ç'
EE3F loc_EE45:
EE45 97 70 staa byte_70
EE47 81 56 cmpa #$56
EE49 27 DD beq handleClearFile_EE28
EE4B 81 2B cmpa #$2B
EE4D 27 28 beq loc_EE77
EE4F 81 35 cmpa #$35
EE51 27 2A beq loc_EE7D
EE53 81 34 cmpa #$34
EE55 27 36 beq loc_EE8D
EE57 81 37 cmpa #$37
EE59 27 40 beq loc_EE9B
EE5B 81 15 cmpa #$15
EE5D 27 4A beq loc_EEA9
EE5F 81 66 cmpa #$66
EE61 27 54 beq loc_EEB7
EE63 81 75 cmpa #$75
EE65 27 55 beq loc_EEBC
EE67 81 2D cmpa #$2D
EE69 27 56 beq loc_EEC1
EE6B 7E EF 67 jmp loc_EF67
This handles various special keys out-of-band of regular keystroke processing. The 'Clear File' key was figured out because the file clearing logic was found, so we know that is 0x56. The others are not yet known.
loc_EEC1 is interesting because it toggles the caps lock indicator found before:
EEC1 sub_EEC1:
EEC1 96 A1 ldaa bCapsLock_A1 ; XXX CAPS lock flag?
EEC3 88 01 eora #1
EEC5 97 A1 staa bCapsLock_A1 ; XXX CAPS lock flag?
EEC7 20 11 bra sub_EEDA
So scan code 0x2d is likely the caps lock key.
loc_EF67 is interesting because it handles everything else, and is likely involved in key code to ASCII conversion for the bulk of the keyboard.
EEC9 loc_EEC9:
EEC9 96 70 ldaa byte_70
EECB BD F5 92 jsr sub_F592
EECE 29 10 bvs leave_EEE0
EED0 13 A1 01 03 brclr bCapsLock_A1 1 loc_EED7 ; XXX CAPS lock flag?
EED4 BD EF BF jsr sub_EFBF
EED7 loc_EED7:
EED7 BD F3 07 jsr sub_F307
The interesting thing to me is that the scan code was saved in byte_70 earlier, prior to doing a bunch of things, then restored at the start of this routine. The value could be mutated in sub_F592, and then the capslock flag we saw earlier is checked and an optional transform sub_EFBF is performed if caps lock is on. Then the final value is processed in sub_F307. It's just a hunch, but it could be that sub_F592 transforms the scan code to ascii (exiting if it cannot), optionally converts to upper case if caps lock is on via sub_EFBF, and then sub_F307 processes the asii version of the character.
The transform at sub_EFBF is fairly obviously a 'make upper case routine' just for the lower case [a-z] by exploiting ASCII's structure:
EFBF sub_EFBF:
EFBF 81 61 cmpa #'a'
EFC1 25 06 bcs leave_EFC9
EFC3 81 7A cmpa #'z'
EFC5 22 02 bhi leave_EFC9
EFC7 84 DF anda #$DF ; goodbye, bit 5
EFC9 leave_EFC9:
EFC9 39 rts
What this also means is that coming into sub_F592 is a scan code in A, and then when it returns, coming into sub_EFBF is ASCII in A (or else the make upper wouldn't work). So sub_F592 /has/ to do scan code to ASCII translation.
The routine sub_F592 masks off the high bit and then multiplies that value by 4, and offsets it into a large array of 4-byte structures at unk_F8C5. We know that A coming in is the scan code, so this table seems to be some sort of scan code to something (ASCII?) translation. Lo! and Behold, this array is 128 entries, which would be consistent with the mask of 0x7f. It is also consistent with our scan code scheme of (row|col), since there are 16 columns and 8 rows.
F592 sub_F592:
F592 84 7F anda #$7F ; ; remove high bit, if present
F594 16 tab
F595 4F clra
F596 05 lsld
F597 05 lsld ; effectively multiply by 4 (4 byte entries)
F598 C3 F8 C5 addd #unk_F8C5 ; XXX 128 4-byte structures
F59B 8F xgdx ; X is now struct address for this scan code
F59C 13 64 01 04 brclr byte_64 1 loc_F5A4 ; XXX flag?
F5A0 A6 03 ldaa 3,x
F5A2 20 02 bra cont_F5A6
F5A4 loc_F5A4:
F5A4 A6 02 ldaa 2,x
F5A6 cont_F5A6:
F5A6 81 00 cmpa #0
F5A8 27 02 beq nochar_F5AC
F5AA 0A clv
F5AB 39 rts
F5AC nochar_F5AC:
F5AC 86 2A ldaa #$2A ; '*'
F5AE 0B sev
F5AF 39 rts
There is also a check of flag byte_64 which affects whether element at +2 or +3 is selected. This isn't the caps lock flag, but maybe it is the shift flag? Caps lock generally only affect alpha characters, whereas you still need to use shift to get to things above the numerics.
Since I had managed to figure out a few scan codes earlier by correlating with menu options, lets check those out for consistency. I (tediously) labelled all the entries in the array. We know (well, believe) that 'y' for 'yes' is 0x22. So, 0x22 * 4 + 0xF8C5 = 0xf94d
F94D 10 fcb $10
F94E 35 fcb $35 ; 5
F94F 79 fcb $79 ; y
F950 59 fcb $59 ; Y
And element +2 is lower-case y, and +3 is upper-case 'Y'. This looks promising. Some of the others known:
code 0x5c, believed to be '3':
FA35 14 fcb $14
FA36 26 fcb $26 ; &
FA37 33 fcb $33 ; 3
FA38 23 fcb $23 ; #
code 0x5d, believed to be '2':
FA39 13 fcb $13
FA3A 1E fcb $1E
FA3B 32 fcb $32 ; 2
FA3C 40 fcb $40 ; @
code 0x5e, believed to be '1':
FA3D 12 fcb $12
FA3E 16 fcb $16
FA3F 31 fcb $31 ; 1
FA40 21 fcb $21 ; !
code 0x5e, believed to be '4':
FA09 15 fcb $15
FA0A 25 fcb $25 ; %
FA0B 34 fcb $34 ; 4
FA0C 24 fcb $24 ; $
So this is checking out pretty good so far! And the upper case of the numerics corresponds to their shifted symbol on the keyboard.
OK, now I must tediously go through the entire table, and markup a printout of the keyboard. I will not be able to figure out all things, since this just covers stuff that is meant to translate to printable characters, but it will be a bit leg up. Plus, I don't know what elements +0 and +1 do yet
There are 80 physical keys on the AlphaSmart Pro, so most of these entries will be 'invalid' from the standpoint of the ASCI conversion.
I hesitate to offer photos of the membranes....
I'm amazed at what you're accomplishing, and I gather that you enjoy the detective-work...(?)
it will be interesting to see the insides of the keyboard at some point!
I do enjoy the detective work to see how far I can push it blind.
I'm a bit behind on posting, but tomorrow's post on yesterday's work, more-or-less concludes keyboard stuff. There are some ambiguities I cannot resolve from software alone (e.g. left/right alt key). Deets in the post.
