Adress plate connected...
A project log for Homebrew 16 bit relay computer
Goal of the project is to develop and build a homebrew 16 bit relay computer
peterPeter 02/28/2024 at 20:380 Comments
So, the most parts of the adress plate are finished and connected...the program-counter, the +1 adder, the program-counter temp register, the adressbus-register, the program-counter multiplexer and the adressbus-register multiplexer. Only the adress-register, which is needed for absolute and indirect memory adressing, is missing and will be added soon.
The following picture shows the plate. The white cable clamps at the bottom may look funny...but they are cheap and always avaliable and may not cause any problems. The control unit plate will get some of this connectors too.
