Instruction Decoder finished
A project log for Homebrew 16 bit relay computer
Goal of the project is to develop and build a homebrew 16 bit relay computer
peterPeter 04/15/2023 at 09:580 Comments
So, the instruction decoder is finished and will be tested during the following week. After test the module will be mounted on top of the instruction register. The next module will be the state register...
And yes, one corner of the board is broken...but thats only an esthetic problem. You have to be very careful if you mount a board using screws.
