FreeEEG16-alpha1 TEST FAILED, use FreeEEG16-alpha2
2x ADS131M08, ESP32-C3, STM32F103C8/GD32VF103CB/CH32V103C8
ALPHA1.0 TEST FAILED, use FreeEEG16-alpha2
electrodes: https://hackaday.io/project/189216-freeeeg16-alphafreedryelectrodes16x34cm,
inspired by https://www.ncbi.nlm.nih.gov/pmc/articles/PMC9627315/
freeeeg16-alpha_bom.csv
Comma-Separated Values - 1.79 kB - 04/05/2023 at 13:07
Download
freeeeg16-alpha_pos.zip
Zip Archive - 2.40 kB - 04/05/2023 at 12:55
Download
freeeeg16-alpha_gerber.zip
Zip Archive - 105.46 kB - 04/05/2023 at 12:54
Download
  • 2 × ADS131M08IPBSR
  • 1 × ESP32-C3-WROOM-02U-N4
  • 1 × STM32F103C8T6/GD32VF103CBT6/CH32V103C8T6 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × MAX6070AAUT12+T
View all 3 project logs
kelvinA wrote 03/27/2023 at 13:42 • point
This project is looking impressive. About a month ago, I was wondering if a higher density BCI solution using pogo pins directly touching the scalp would improve things and bridge the gap between invasive and non-invasive performance.
