Node number 8. The project conducts the design of gcode to process prototypes. The gcode file will be inserted into the machine to create the circuit template. Each machine will need its own design parameter, so this gcode file is calibrated according to that parameter, to ensure feasible machining.
TRAN.VINH.QUANG
