Since my first test board milling with my do-it-yourself cnc I have not had the resolution I wanted, there is a backlash problem that makes the chip with 0.1-0.2 mm spacing not suitable fit. This is really important during prototyping, because I want to prototype with my own machine, I have to fix it to the target resolution.
Continue to update...
TRAN.VINH.QUANG
