1Soldering Top SMD Components and LEDs
Bottom Solder Layout
Solder all Bottom Bottom Components First
Solder LED Components
- LEDs Are designed to be mounted in reverse. Some LEDs require a little force to fit in the hole in reverse.
2Solder Top Components and LED's
Top Solder Layout
3Flashing Uno/Genuino Firmware
Download the Following 2 Hex Files
Arduino-COMBINED-dfu-usbserial-atmega16u2-Uno-Rev3.hex--------------------------------------------------
Atmega 16u2 Fuses
LFuse = 0xFF
HFuse = 0xD9
EFuse = 0xF4
Atmega 328P Fuses
LFuse = 0xFF
HFuse = 0xDE
EFuse = 0x05
