Lixie Clock
A flexible LixieClock design using an ESP32 and laser cut parts
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This NixieTube clock alternative uses multiple laser engraved acrylic plates to display the time. So this clock is a LixieClock. It is easy to make and assemble. The number of digits can be configured freely. The basic design is a 4 or 6 continuous clock. Designfiles and PCB Gerbers as well as a building instruction can be found on the Github.
