1Basic MQTT setup and testing
Check out the tutorial here: Getting started with MQTT
2Set up your own data collecting infrastructure with a few key presses
This repository contains everything you need to set up InfluxDB, Mosquitto, Telegraf and Grafana to collect and display your data. Everything is pre-configured and ready to go. Easy IoT data infrastructure setup via docker
Albertas Mickėnas
