Solenoid Engine – RPI / Micro:bit Interface
A project log for Acrylic Solenoid Engine
An easy to build solenoid engine for use as a desk toy or as a peripheral to common SBC's as a learning toy.
extreme-electronicsExtreme Electronics 12/16/2016 at 15:180 Comments
Raspberry Pi and Micro:bit interface board returned from OSHPark
and a simple uPython script written for the BBC Micro:bit using the two A/B buttons for faster/slower.
Will also run from any of the Raspberry Pi SBCs. Code samples in C, and Python
Code details
Kits available via Extreme Kits RPI Micro:bit Solenoid Engine Kits
