Torrents in a VPN
A project log for Container cheat sheet
x
lion-mclionheadlion mclionhead 10/26/2023 at 23:181 Comment
Lions contend that most containers are only used for downloading torrents in a VPN.  Most ISP's these days disable your account for nefarious downloading.
The mane VPN program is openvpn.  The mane command line torrent program these days is transmission-cli
apt install openvpn transmission-daemon transmission-cli
Getting it going in a VPN container is a long & hard process.
The daemon is a systemd service.  It immediately gives "unauthorized" for all commands.  You have to systemctl stop transmission-daemon, edit /etc/transmission-daemon/settings.json, set
rpc-authentication-required to false,
rpc-whitelist-enabled to false
systemctl start transmission-daemon to get around this.
Another new dance is the download-queue-enabled, queue-stalled-enabled  options have to be set to false or it'll set every new torrent to queued while waiting forever for the unseeded torrents.
You must disable the automatic transmission-daemon by running systemctl disable transmission-daemon
Generally, there's an openvpn command which configures the VPN.  It runs a command after the VPN starts & another command before the VPN dies, to ensure no data intended for the VPN goes to the insecure network.
openvpn --script-security 2 --config [.ovpn file] --auth-user-pass [userpass file] --comp-lzo --up-delay --up [startup script] --down-pre --down [shutdown script]
For some reason, the --comp-lzo option may have to be taken out if it can't access anything from inside the VPN.
The VPN nameserver is contained in a foreign_option_1 environment variable passed to the startup script.
At minimum, the startup & shutdown scripts have to manage the torrent daemon, default route, & set resolv.conf.
startup script:
#!/bin/sh
route del default
cat > /etc/resolv.conf << EOF
nameserver THE_VPN_NAMESERVER
EOF
shutdown script:
#!/bin/sh
nameserver THE_ISP_NAMESERVER
EOF
route add default gw 10.0.10.1
All the transmission downloads go in /var/lib/transmission-daemon/downloads.  The lion kingdom made this a mount point pointing to a host directory in the lxc config.
lxc.mount.entry = /home/mov/sin /var/lib/lxc/sin/rootfs/var/lib/transmission-daemon/downloads none bind 0 0
The permission has to be 777 since transmission-daemon runs as a normal user.
The torrents are all in /var/lib/transmission-daemon/.config/transmission-daemon/torrents & /var/lib/transmission-daemon/.config/transmission-daemon/resume
 New containers have to be routinely created as VPN's migrate to new ubuntu releases.  To transfer all the torrents between containers, you have to copy the 2 torrent directories, make sure the permissions are 777, & the user exists.
Key commands:
Start downloading a torrent:
transmission-remote -a "magnet link"
List status & ID's of all torrents:
transmission-remote -l
Sort by a column:
transmission-remote -l -k <column number starting with 1>
Stop a torrent by ID:
transmission-remote -t [ID] -S
Resume a torrent by ID:
transmission-remote -t [ID] -s
Remove a torrent by ID:
transmission-remote -t [ID] -r
There is no easy way to select individual files for downloading.  The general idea is to poll the torrent contents by torrent ID.
transmission-remote -t [ID] -f
Once it downloads the file list, stop all the files from downloading
transmission-remote -t [ID] -G all
Then resume 1 file at a time by passing its ID
transmission-remote -t [ID] -g [file ID]
Ken Yap wrote 08/09/2025 at 00:17 point
You need better ISPs then. Here they don't care. For example Archive.org provides torrent downloads. Nobody would call those nefarious.
