The main circuit board is already designed. It is a perfect fit in the TI-92 housing using all the existing mounting holes, and existing silicone keypad, keys and D-pad. With minimal modifications (the screen is bigger than default) to the housing, the new board lets you connect a RasPi Zero to a pimoroni HyperPixel 4.0 touch screen.
The main circuit board board was designed in Altium 'cause day job. Anyone interested in porting the project to KiCAD or similar?
Board bring-up is in process. Power supply works amazingly well. Microcontrollers are talking to the bus. Working on getting the USB hubs talking and working out keyboard mapping at the moment.
More to come!
TM
Stephano Herrera
Looking for a few good techies to help get this over the finish line.
