A 4$, 4ICs, Z80 homemade computer on breadboard
No iron, no cry! Build a mini 4MHz Z80 64kB RAM system with Basic and Forth interpreters, CP/M 2.2, QP/M 2.71, Assembler and C toolchains
This is the Z80-MBC (Mobile Breadboard Computer), a mini 4MHz Z80 64kB RAM system with Basic and Forth interpreters, CP/M 2.2, QP/M 2.71, Assembler and C toolchains.
It is a complete development "ecosystem", and using the iLoad boot mode it is possible cross-compile, load and execute on the target an Assembler or C program with a single command (like in the Arduino IDE).
More, it can be easily expanded and it has an "Arduino heart" using an Atmega32A as an "universal" I/O emulator, and can be used and powered with a tablet or smartphone too...
This project has grown a lot on the way (more than I've supposed at the beginning...) and now is renamed as "Multi Boot Computer" and is available on PCB (thanks to Bill Westfield) too.
* * NOTE * * : The new Z80-MBC2 is out!. Check it here: ( https://hackaday.io/project/159973 )
During some surfing on Ebay I realized that with 4$ it is possible to buy enough ICs to build a complete Z80 system that can be done using a breadboard, and taste some flavor of retro computing.... So I did it and here it is the story!
Here is a video with the Z80-MBC in action:
and here with a smartphone (so it is explained the word "Mobile" in his name...) with a common OTG cable (the various test clips in this video were used for some measurements with a Logic Analyzer):
* * HARDWARE OVERVIEW * *
The needed ICs are:
  • Z80 CPU CMOS (Z84C00) 4Mhz or greater ($1.16)
  • Atmega32A ($1.70)
  • TC551001-70 (128kB RAM) ($1.10)
  • 74HC00 ($0.25)
Total cost: $4.21
The wires were taken from salvaged broken LAN cables, and the other components were salvaged from others unused breadboards.
The schematic is attached in the Files section. The MCU Atmega32A is used as universal I/O subsystem, as Eeprom, and as reset and 4MHz clock generator for the Z80 CPU.
Into the Atmega32A it is flashed an Arduino bootloader taken from here , and it is possible to use the Board Manager of the Arduino IDE for that.
Flash the Arduino bootloader at first (with the method you prefer), next you can start to build the whole thing!
Of course I used the Arduino IDE to develop the IOS (I/O Subsytem) that interacts with the Z80 bus and "virtualizes" the peripherals seen by the Z80 CPU.
As oscillator it is used the internal 8MHz Atmega32A oscillator, so no quartz is needed, and from this one is derived the 4MHz clock for the Z80 CPU (so the "Internal 8MHZ osc." bootloader variant must be chosen when flashing the bootloader from the Arduino IDE!).
The 74HC00 is mainly used as RS flipflop to stop the Z80 CPU during I/O operation, giving the needed time to the Atmega32A to interact with the Z80 bus.
The 128kB RAM TC551001 is used only for half (64kB) because the Z80 address space is only 64kB (I've chosen this IC for the low cost).
Note that only the CMOS version of the Z80 CPU can be used here. This because only CMOS version, under given condition that are respected in this schematic, has logical levels compatibles with Atmega32A and 74HC00.
NOTES ABOUT THE COMPONENTS:
You can use any Z80 CMOS speed grade, because the lowest is 4MHz.
The 74HC00 can be substituted with a 74HCT00 if you already have one.
The RAM chip TC551001-70 can be substituted with any suitable 64kB RAM (do not use < 64kB RAM).
The USER led (D5 in the schematic) MUST be blue or white just to be sure that V(forward) is >= 3V.
Here is a video that shows a simple basic program that interacts with the "USER led" and "USER key":
On the breadboard there are others status led: the HALT led turns on if an HALT instruction is been executed and the Z80 CPU is in a Halt state, the DMA led turns on during DMA operations when the Z80 bus is in Hi-Z, the IO_OP led turns on when the Z80 CPU is accessing a I/O virtual device "emulated" by the Atmega32A (as the serial port), the LED_D0 led is the classical "Arduino" led (that one connected to D13 pin on the Arduino Uno) that here is connected with the Arduino D0 pin and is turned on normally as a power on indicator.
The serial port SERIAL-USB (see schematic)...
S111216.c
TASM Assembler utility.
C Source File - 1.21 kB - 05/15/2018 at 06:05
Download
build.sh
Linux shell script to invoke TASM for WINDOWS (using wine) to assemble Z80 source code and produce a HEX file and a 'C' header file containing the code. Requires TASM 3.2 and wine. See the notes in the script (by Scott).
x-shellscript - 1020.00 bytes - 05/14/2018 at 19:31
Download
optiboot_m32-20mhz.hex
Anyone wishing to overclock the AVR at 20MHz; OptiBoot HEX file for ATmega32/A running at 20MHz (by Scott).
x-hex - 1.31 kB - 05/14/2018 at 18:29
Download
optiboot_m32-8mhz.hex
OptiBoot HEX file for ATmega32/A running at 8MHz (by Scott).
x-hex - 1.31 kB - 05/14/2018 at 18:28
Download
optiboot_m32-16mhz.hex
OptiBoot HEX file for ATmega32/A running at 16MHz (by Scott).
Download
View all 38 files
  • 1 × For the breadboard version see the file "Z80-MBC - BOM.xls" in the Files section
  • 2 × For the PCB version see the file "Z80-MBC PCB version - BOM.xls" in the Files section
  • The Z80-MBC2 is out!
    Just4Fun07/25/2018 at 16:25 0 comments
  • Hardware Fix for the A041116 schematic (USER led and key)
    Just4Fun07/19/2018 at 18:09 0 comments
    During some tests on the new Z80-MBC2 I realized that the circuitry of the USER led and key (that is the same used in the Z80-MBC) could cause in some cases an erratic behavior of the USER key (USER key not recognized when pressed).
    The solution is easy, and the fix requires only to change the values of R14 and R15 (see the A041116 schematic) to 390 Ohm (both) as shown:
    Remember that the USER led (D5) must have a forward voltage drop (Vf) of at least 2.7V (e.g. a blue led).
    Please note that this fix is suggested only if you are building a new board or if you are experiencing difficulties with the USER key.
    If you already have a perfect working board there is absolutely no need to apply this fix.
  • Bug fix: the "ghost RTC"
    Just4Fun02/10/2018 at 17:01 0 comments
    Reading this Japanese article on a kit sold in Japan to build a Z80-MCB, I realized the presence of a possible bug seeing this two images:
    As you can see, there is a Z80-MCB without any Virtual Disk or RTC attached and in the resulting screenshot the RTC appears present.
    After a quick check I found a little bug in the RTC discovery routine that see a "ghost RTC" when the Virtual Disk is not present.
    So I've uploaded a new "sketch" (S221116_R100218_Z80.ino) that fix the bug.
    Note that if you have the Virtual Disk already installed, there isn't any real need to upgrade.
  • How to make custom Virtual Disk images
    Just4Fun05/29/2017 at 14:29 1 comment
      To do that you need two really powerful tools: Cpmtools to create CP/M disk images and SRecord to manipulate ROM/EPROM images.
      Take in account that the structures of the virtual disk 0 and 1 of the Z80-MBC are different. Disk 0 has the two first tracks reserved for the system image (loaded into RAM by the CP/M loader), instead disk 1 doesn't have this "reservation". This means that the images have a different "structure". More, because disk 0 must have the system image inside the two first tracks, the disk 0 image creation will be different if the OS is CP/M rather than QP/M.
      So to make things easier I've prepared some batch file to simplify the needed operations.
      As for the Assembler and C toolchains you need a Windows host or VM.
      Here all the steps to set up the needed tools:
      1. Create a working directory on your Windows Machine;
      2. Download Cpmtools and unzip in your working directory;
      3. Download last version of SRecord and unzip in your working directory;
      4. Download from the Files section CPMtools-custom.zip and unzip the files into the directory containing the Cpmtool executables (as cpmcp.exe). During the copy overwrite the file DISKDEFS because the new one contains the needed definitions for the Z80-MBC;
      5. Download from the Files section SRecord-custom.zip and unzip the files into the directory containing the SRecord executables (as srec_cat.exe).
      Now you are ready to create your custom image. First create a sub-directory (called e.g. CPM-files) in the cpmtools directory to store all the files to load in the disk image. Check that they fit into the 128kB avaliable space.
      Steps to create a Disk 1 image
      1. Go to the cpmtools directory and with an editor modify/add/delete in the file MakeDisk1.bat the various lines "cpmcp -f z80mbc-d1 %dskfile% CPM-files\xxxxx.yyy 0:xxxxx.yyy" to match the directory in your host (if needed) and all the files to load (xxxxx.yyy);
      2. From the cpmtools directory open the provided DOS command shell and give the following command (I'll use here the name disk1.dsk for the disk image file):
        MAKEDISK1 disk1.dsk
      3. After the execution copy the file disk1.dsk in the SRecord directory;
      4. Go to the SRecord directory, open the provided DOS command shell and give the following command:
        D1TOHEX disk1.dsk
      5. After the execution you will find four files named from disk1_SEG0.hex to disk1_SEG4.hex to upload into the virtual disk with iDisk.
      Steps to create a Disk 0 CP/M image
      1. Go to the cpmtools directory and with an editor modify/add/delete in the file MakeDisk0CPM.bat the various lines "cpmcp -f z80mbc-d0 %dskfile% CPM-files\xxxxx.yyy 0:xxxxx.yyy" to match the directory in your host (if needed) and all the files to load (xxxxx.yyy);
      2. From the cpmtools directory open the provided DOS command shell and give the following command (I'll use here the name disk0CPM.dsk for the disk image file):
        MAKEDISK0CPM disk0CPM.dsk
      3. After the execution copy the file disk0CPM.dsk in the SRecord directory;
        D0TOHEXCPM disk0CPM.dsk
      5. After the execution you will find four files named from disk0CPM_SEG0.hex to disk0CPM_SEG4.hex to upload into the virtual disk with iDisk.
      Steps to create a Disk 0 QP/M image
      1. Go to the cpmtools directory and with an editor modify/add/delete in the file MakeDisk0QPM.bat the various lines "cpmcp -f z80mbc-d0 %dskfile% CPM-files\xxxxx.yyy 0:xxxxx.yyy" to match the directory in your host (if needed) and all the files to load (xxxxx.yyy);
      2. From the cpmtools directory open the provided DOS command shell and give the following command (I'll use here the name disk0QPM.dsk for the disk image file):
        MAKEDISK0QPM disk0QPM.dsk
      3. After the execution copy the file disk0QPM.dsk in the SRecord directory;
        D0TOHEXQPM disk0QPM.dsk
      5. After the execution you will find four files named from disk0QPM_SEG0.hex to disk0QPM_SEG4.hex to upload into the virtual disk with iDisk.
      Remember that you...
  • A new OS: QP/M 2.71 and a RTC for timestamping
    Just4Fun05/23/2017 at 15:37 0 comments
      Here is an interesting alternative to CP/M developed by MICROCode Consulting that supports also file timestamping, and it is 100% CP/M 2.2 "compatible".
      MICROCode Consulting has released the original installation files and all the documentation in their site with the "restricted usage" condition, that means free for non-commercial use and for personal use only, so it should be ok for us. Anyway I've sent them a mail about this project.
      To enable timestamping you need a DS3231 based RTC module like this one:
      WARNING: these modules can cause battery "explosion"! How to fix it
      This cheap modules have a trickle charging circuit that may cause the "explosion" of the battery if you use a standard CR2032 cell. More, it can damage also a rechargeable LIR2032 cell (see this thread). So the safer thing is "disable" the trickle charging circuit (a CR2032 can last 5/10 years, so there is no practical need to a rechargeable battery, after all...).
      To avoid any charging current flowing into the battery you can take away the series limiting 200 Ohm resistor (or cut the trace). Alternatively you can take away the red diode, or destroy it (it is in series with the 200 Ohm resistor). In the following photo you can see the module with some Kapton tape (used as thermal barrier) before to desolder the 200 Ohm resistor (on the right marked as 201) with an hot air gun:
      And here after the desoldering:
      Now the module it's safe and a CR2032 can be used. To connect it use the SCL/SDA/VCC/GND terminals and connect them at the corresponding pins of the IOEXP/I2C connector of the Z80-MBC (pay attention because the position of the signals is different):
      QP/M quick set up guide
      The setup is quite similar to those used to install CP/M. The Assembler automated toolchain must be already set up and the Virtual Disk Module present.
      Here all the steps:
      1. Connect the DS3231 module (with the CR2032 battery inside);
      2. Update the IOS using the new file S221116_R100218_Z80.ino in the File section;
      3. Reboot the Z80-MBC and from a terminal emulator you'll see this:
        Press Y. If you are enough fast you have the RTC set up with the right date/time taken from the sketch compile time (if you are lazy like me you'll find this very handy...). In any case it is possible adjust the date/time manually too from the boot selection menu;
      4. Reboot the Z80-MBC again and select the iLoad boot mode;
      5. From the File section download the file "QPM271_DiskPack.zip", unzip it in the directory used for the Assembler automated toolchain;
      6. Upload the file "iDisk - S250317.hex" to the Z80-MBC using the Dos batch L.BAT (see Assembler automated toolchain) with the command:
        L "iDisk - S250317.hex"
      7. When iDisk waits for the input stream, from the Tera Term menu select "File" -> "Send file..." and choice one of the unzipped .hex file from QPM271_DiskPack.zip;
      8. Repeat step 7 for all the four files;
      9. Press the Reset button on the Z80-MBC and enter into the boot selection menu and select 4 to load the OS from disk 0 (and select the disk light ON if not already done, to have an idea of the behavior):
      NOTE: as already noticed, if you experience errors during the serial upload increase the delay after each line from the Tera Term menu (Setup -> Serial port -> Transmit delay -> msec/line). In my VM I set up a 90ms delay. This is due because Arduino serial port doesn't have any handshaking.
      Now you have QP/M 2.71 up and running, but you need further operations to enable the file timestampig (as stated in the QP/M Installation Guide):
      1. To enable file disk timestamping it is necessary run the utility QSTAMPX from A:
        and do the "disk timestamping" for both A: and B: disks.
        When done type the command D $T and check that the output is similar to this:
      2. Now to set up a starting date to all files give the command QSUB SETDATE to run a simple batch that I made to do this initialization easily;
      3. Copy the file SETDATE.QSB to drive B: (using the command QPIP B:=SETDATE.QSB) and repeat from B: the same batch (QSUB SETDATE)....
  • AUTOEXEC for CP/M
    Just4Fun05/02/2017 at 16:39 1 comment
      Playing with the Z80-MBC I realized that there was a missing feature: to run a program automatically after the "cold" boot.
      So after some searches I found a way to implement in the BIOS a function similar to AUTOEXEC.BAT for DOS using the CP/M SUBMIT command and a batch file that I called AUTOEXEC.SUB (of course...).
      Editing the AUTOEXEC.SUB file it is possible to run a sequence of commands after the cold boot (as with AUTOEXEC.BAT for DOS), and it is possible enable or disable the execution of the AUTOEXEC batch file from the IOS boot selection menu (but this isn't possible with DOS...).
      AUTOEXEC for CP/M quick set up guide
      You must have CP/M 2.2 already up and running (see CP/M 2.2, iDisk and a new IOS), and you can have also only a "single disk" installed (but I recommend the original dual disk configuration), meaning that only U1 (see the A110417 schematic) is populated. Of course the Assembler automated toolchain must be already set up.
      Here all the steps:
      1. Update the IOS using the new file S221116_R300417_Z80.ino in the File section;
      2. Reboot the Z80-MBC and select the iLoad boot mode;
      3. From the File section download the file CPM22SYS_BIOS_S050217_R300417.hex. This file contains only the new CP/M system image for the system tracks of Disk 0, so the "user files" will be left untouched;
      4. Upload the file "iDisk - S250317.hex" to the Z80-MBC using the Dos batch L.BAT (see CP/M 2.2, iDisk and a new IOS) with the command:
      5. When iDisk waits for the input stream:from the Tera Term menu select "File" -> "Send file..." and choice CPM22SYS_BIOS_S050217_R300417.hex. After the upload iDisk will show a summary, at this point press W to proceed and confirm your choice (as done for the CP/M 2.2 installation described in CP/M 2.2, iDisk and a new IOS). Wait until the write and verify phase is completed.
      6. Press the Reset button on the Z80-MBC and enter into the boot selection menu and select 4 for CP/M loader.
      All done!
      How use it
      To create or edit AUTOEXEC.SUB from drive A, you can use the ED command or an other editor like the Turbo Pascal editor. In this case remember to terminate the file with a CR, or "strange" things will occur when executing the SUBMIT AUTOEXEC command.
      You can test the execution giving the command SUBMIT AUTOEXEC from drive A (you can omit the extension .SUB inside the SUBMIT command).
      To enable the AUTOEXEC execution after the cold boot change the corresponding state to ON from the usual IOS boot selection menu.
      If the AUTOEXEC is enabled but the AUTOEXEC.SUB file doesn't exist in the drive A, an error will be displayed:
      New "disk packs"
      I've updated both "disk packs" in the files CPM22_DualDiskPack_v2.zip and CPM22_SingleDiskPack_v2.zip with the new BIOS in the system tracks. So if you are installing them for the first time or you need for any reason to reload them, the new BIOS will be installed. I've added an example of AUTOEXEC.SUB too.
      How it works
      The "trick" used was to inject the string "SUBMIT AUTOEXEC" into the CCP (the Command Processor of CP/M) input buffer. The BIOS after the cold boot checks if the AUTOEXEC flag is set in the IOS, and in this case makes the injection. When the CCP starts after the cold boot, it runs this injected command.
      In this video there is an in depth explanation for a "legacy" Altair 8800 clone.
      The CP/M 2.2 and the new BIOS sources are in the file "CPM22 BIOS - S050217 R300417.zip" in the File section.
  • CP/M 2.2, iDisk and a new IOS
    Just4Fun04/20/2017 at 20:36 14 comments
      CP/M 2.2 quick set up guide
      The set up is very simple. I've done an utility (iDisk) to simplify all the needed operations. Of course the Virtual Disk Module must be present, but you can have also only a "single disk" installed (but I recommend the original dual disk configuration), meaning that only U1 (see the A110417.pdf schematic) is populated.
      The Assembler automated toolchain must be already set up.
      Here all the steps:
      1. Update the IOS using the new file S221116_R130417_Z80.ino (or a newer version if present) in the File section;
      2. Reboot the Z80-MBC and select the iLoad boot mode (if not already selected);
      3. From the File section download the file "iDisk - S250317.hex" and copy it into your PC in the directory used for the Assembler automated toolchain . (Do not use the source file "iDisk - S250317.c" because it requires a special compiling option);
      4. From the File section download the file "CPM22_DualDiskPack.zip" and unzip it (for a single disk configuration download the file "CPM22_SingleDiskPack.zip"). Each disk image is divided into four .hex files called "segment" (32kB each) that are named accordingly (e.g. D0XXX_SEG1.hex means the segment 1 of disk 0);
      5. Upload the file "iDisk - S250317.hex" to the Z80-MBC using the Dos batch L.BAT (see Assembler automated toolchain) with the command:
      6. When iDisk waits for the input stream:
        from the Tera Term menu select "File" -> "Send file..." and choice one of the unzipped .hex file from CPM22_DualDiskPack.zip (or CPM22_SingleDiskPack.zip for a single disk configuration). After the upload iDisk will show a summary:
        at this point press W to proceed and confirm your choice.
        You don't have to follow any order in the "segments" upload sequence, iDisk will know how to do. To know before each upload what "segments" have been already written into the disks just see the "Disk segment write status":
        in the photo the segments 0, 1 and 3 of Disk 1 have been already successfully written, so you can choose any of the remaining;
      7. Repeat step 6 for all the eight (or four for the single disk pack) "segment" files;
      8. Press the Reset button on the Z80-MBC and enter into the boot selection menu:
        select 4 for the CP/M loader (and select the disk light ON if not already done, to have an idea of the behavior).
      All done!
      NOTE: if you experience errors during the serial upload increase the delay after each line from the Tera Term menu (Setup -> Serial port -> Transmit delay -> msec/line). In my VM I set up a 90ms delay. This is due because Arduino serial port doesn't have any handshaking.
      Disk speed
      The Virtual Disk Module is based on simple EEPROMs using a 200KHz I2C serial bus. Of course do not expect the same speed of an hard disk with a DMA controller!
      The speed probably is like using the floppy drive of those days...
      Single disk configuration
      You can have also only a "single disk" installed (but I recommend the original dual disk configuration), meaning that only U1 (see the A110417.pdf schematic) is populated.
      In this case you have about 120kB free, because the first two tracks of Disk 0 are reserved for the system image (Disk 1 doesn't have the system image, so all the 32 tracks are used for the file system).
      Because the BIOS is the same and is configured for a dual disk system, if you try to select the "B:" drive you'll get a "BAD SECTOR" error.
      Disk pack contents
      In the disk 0 image there are the various external CP/M commands, the Basic interpreter, the CP/M Assembler and the Macro Assembler.
      I've added also D, an alternative DIR command, and PEG, a bin to hex converter (and vice-versa) to exchange files:
      In the disk 1 image there is the complete Turbo Pascal compiler v3.01A with a sample program (SA.PAS):
      In the "single disk pack" the CP/M Assembler and the Macro Assembler are missing, and the Turbo Pascal is without the installing executable (not a big issue anyway) and without the sample program.
      In a next Log I'll explain how create custom...
  • Virtual Disk Module, a new IOS and ViDiT
    Just4Fun04/13/2017 at 19:37 3 comments
    It's time for a new "module", the Virtual Disk Module! In the photo is that one on the right, near the previous GPIO module.
    In the File section is possible see the simple schematic A110417.pdf with two I2C EEPROM 24LC1025.
    With this module it is possible to emulate two disks of 128kB each (probably like the floppy disk drives of those years).
    Each disk is divided into 32 tracks of 32 sectors. Each sector is 128 bytes long.
    Of course to manage this new HW there is a new release of IOS. The new file S221116_R180217_Z80.ino is in the File section.
    This new IOS checks if the module is present and prints a message if found:
    There is also a new item in the boot selection menu if the virtual disk is found, to use the User led as a disk activity led:
    I suggest to activate this option to have an idea of the behavior.
    ViDiT
    In the File section I've added a simple test program (file "ViDiT - S090417.c") to check the virtual disk. Of course you need to compile it with the C "toolchain":
    About I2C speed
    With this IOS the I2C speed is 200KHz. Note that if you are using a 16MHz external quartz to clock the Atmega32 the I2C speed will be 400kHz. In this case I suggest to lower the two 4k7 pull-up resistors (on SDA and SCL signals) to about 2k2.
    The next Log will bring the CP/M 2.2 up and running...
  • Forth language, new multi-boot selection and a new name
    Just4Fun02/17/2017 at 21:33 4 comments
    Forth
    Thanks to Bill Westfield now we have a new language for the Z80-MBC, the fig-FORTH v1.3 (here the link to the Bill GitHub repository with the source he adapted for the TASM assembler with the needed modifications for the Z80-MBC).
    The acronym "fig" stands for "Forth Interest Group", that was a world-wide non-profit organization (now dissolved) for the promotion of the Forth computer language.
    I've just started to play with this thing, and I must say that it is not the most friendly language I've seen... anyway it is an interesting different approach.
    To enable Forth just upload the new IOS release S221116_R120217_Z80.ino in the Files section, and select the Forth language from the new multi-boot menu (see next paragraph).
    Here it is a "blink" demo program:
    ( Blink test - Forth - Z80-MBC
    : ledon 1 0 P! ;
    : ledoff 0 0 P! ;
    : delay 4000 0 DO NOOP LOOP ;
    : blink CR ." Blinking..." CR BEGIN ledon delay ledoff delay 0 UNTIL ;
    To execute give the command "blink":
    If you are using Tera Term to send a text file to load a forth source, remember to set up a delay of 1ms for each character (serial port managed by the Arduino bootlader doesn't have any handshaking, so for now this is required to handle the serial stream without errors when sending a text file using a terminal emulator):
    New multi-boot selection
    Now pressing the User key after a reset brings to a new menu to chose the preferred boot mode. During this phase the LED-D0 will blink until you choose the boot mode:
    New name
    As you can see from the previous photos, from this release the MBC acronym changes to "Multi Boot Computer"...
  • An automated C language toolchain
    Just4Fun02/09/2017 at 21:26 0 comments
    Here how set up a toolchain to program the Z80-MBC using the C language. It is based on SDCC (Small Device C Compiler) and uses the same "process" of the previous Assembler toolchain.
    In the following it is assumed the the Assembler toolchain is already set up in a Windows host as described in in the Log: New iLoad boot mode and an automated Assembler toolchain.
    So only the SDCC relevant part is explained here.
    Here it is a short video with the toolchain in action:
    What you need to do:
    1. Create a working directory (or use the previous one) where to store the C sources and the two batch files (C.BAT and L.BAT) in the C_batch.zip file from the File section (if you are using the same assembler working directory overwrite the previous L.BAT);
    2. With a text editor search the line:
      "C:\Program Files\teraterm\ttermpro.exe" /c=3 /BAUD=9600 /w="Z80-MBC Terminal" /m=LoadZ80.ttl
      inside C.BAT and L.BAT and verify that both the path and the COM number (/c=3 means COM3) meet your system;
    3. Download and install SDDC from here;
    4. Download the file S030217_crt0.s from the Files section in the working directory;
    5. Open the DOS command line and give the command: "sdasz80 -o S030217_crt0.s".
      Then rename the generated S030217_crt0.rel as crt0.rel. Copy it in the SDCC directory "C:\Program Files\SDCC\lib\z80" (may be a bit different in your system) overwriting the old one.
    All done!
    As usual close Tera Term before every new upload.
    To check if it is all ok, download from the File section the file C_demo.zip and unzip it in the working directory.
    From the DOS command line give the command: "C Blink.c" to check if all the toolchain works as in the video.
    Try also the other demo ANSItest.c (taken from here) to check the ANSI capabilities of a different terminal emulator or a physical terminal:
    About SDCC
    I'm pretty new to SDCC. The SDCC documentation is 8051 "focused", so the given examples can be misleading if used with an other processor in mind.
    When "porting" SDCC to a target HW, there are 3 things to prepare:
    • customize the crt0.rel file that contains the initialization code for the target system;
    • add to the library the function putchar(char c) to send output to the console;
    • add to the library the function getchar() to read from the keyboard.
    I found the documentation quite missing about how to modify for a custom system.
    In particular in the provided crt0.s example there isn't a needed global declaration of three variables (l__INITIALIZER, s__INITIALIZED and s__INITIALIZER). Without this declaration the code will not compile.
    And to make this customization you need to know how the provided assembler works, but the assembler manual is not provided. So you must find it googling...
    If you are used to the Arduino IDE, read carefully the SDCC manual. This C compiler is a lot more "rude" about types and syntax... (as C standard is...).
    Last minute update
    Just found the assembler and linker documentation here!
View all 14 project logs
  • 1
    Quick instructions intro:
    All the detailed instructions are provided in the "DETAILS" section and in every "LOG".
    Because this project has grown a lot on the way (more than I've supposed at the beginning...) here you can find a short and simple build guide without "navigate" into all the various "LOGs".
    This short guide is referred to the current (at present date 31 August 2017) last "level" of development as described in "A new OS: QP/M 2.71 and a RTC for timestamping".
  • 2
    Add the Atmega32 support in your Arduino IDE:
    The standard distribution of Arduino IDE doesn't have the Atmega32 "core" support files.
    You need to add them from here.
  • 3
    Flash the Atmega32:
    First of all you need to flash the Arduino bootloader into the Atmega32.
    To do this there are a lot of ways. I use a cheap USBASP programmer that you can find "around" for less than 2$.
    Remember to select from Arduino IDE the "Atmega32 8MHz Internal" clock option before flashing the bootloader!!!
View all 6 instructions
william.huskey wrote 6 days ago point
built the bread board, get from the armega..
Z80-MBC (Multi Boot Computer) - A041116
IOS - I/O Subsystem - S221116 R100218
IOS: Loading phase 1 boot program...
IOS: Loading phase 1 done.
IOS: Z80 is running from now.
but nothing after that.. logic probe shows activity on memory address and data busses
may be the memory chips I have are not really cmos...  DS2139y-150+ ..   but I would think I would get some other out put..
william.huskey wrote 5 days ago point
more output from debug
: I/O READ operation requested - DATA: 03 00000011 ADDR: 02 00000010
IOS: I/O READ operation requested - DATA: CD 11001101 ADDR: 02 00000010
IOS: I/O READ operation requested - DATA: DA 11011010 ADDR: 02 00000010
IOS: I/O READ operation requested - DATA: 04 00000100 ADDR: 02 00000010
IOS: I/O READ operation requested - DATA: C1 11000001 ADDR: 02 00000010
IOS: I/O READ operation requested - DATA: E5 11100101 ADDR: 02 00000010
IOS: I/O READ operation requested - DATA: 2A 00101010 ADDR: 02 0000
IOS: I/O READ operation requested - DATA: 23 00100011 ADDR: 02 00000010
IOS: I/O READ operation requested - DATA: EB 11101011 ADDR: 02 00000010
IOS: INT operation (nothing to do)
Cyril V. wrote 08/30/2018 at 00:13 point
Just got my PCBs. The solder is black, they look really good.
I have couple to spare. I think to sell 2 for $5 plus shipping. PM me if interrrested.
Just4Fun wrote 07/22/2018 at 18:26 point
First Z80-MBC2 IOS release is coming...:
https://farm2.staticflickr.com/1808/43571727791_48473e6662_o.jpg
villaromba wrote 07/24/2018 at 19:40 point
Looking good............
Peabody1929 wrote 07/06/2018 at 17:03 point
When can we see the Schematic?
Just4Fun wrote 07/07/2018 at 11:26 point
I'll made a new "Log" here with the link when the "project" page is ready...
Just4Fun wrote 07/06/2018 at 10:02 point
Z80-MBC2 PCB just arrived! Now the fun starts... https://farm1.staticflickr.com/839/29361725228_01ee99a83d_o.jpg
Just4Fun wrote 06/17/2018 at 17:52 point
Just tested the new 3D rendering with raytracing of Kicad 5 RC2. The result is stunning... https://farm2.staticflickr.com/1745/42810522692_58348711fc_o.jpg
Just4Fun wrote 06/15/2018 at 08:33 point
Cyril V. wrote 06/15/2018 at 14:59 point
I really like all this new headers - nice work :)
Peabody1929 wrote 06/15/2018 at 16:00 point
Does the board use a MCP23S17 or MCP23017? (SPI or I2C)
Just4Fun wrote 06/15/2018 at 16:13 point
MCP23017 (I2C). It isn't possible to share the SPI with the SD module because, as far as I know, the common SD modules on ebay have a level shifter that is not 3-stated when not selected (the IC it is, but the design not...).
After all I don't see a real need of an MCP23S17, and you can re-use all the ICs of the "old" Z80-MBC...
Cyril V. wrote 06/15/2018 at 17:41 point
What is the J3 header for? (icsp header for the atmega?)
Just4Fun wrote 06/15/2018 at 17:54 point
Yep!
Cyril V. wrote 06/15/2018 at 18:08 point
With https://jlcpcb.com/ you can have 10pcs (10cm* 10 cm max) for just for $2. I just used them and the quality is ok.
Just4Fun wrote 06/16/2018 at 07:12 point
Yes, I have already used their service too... (see ESP-01 NanoBoard). At this moment they seem to have the best price (about 7$ in EU) including the cheapest shipping method (registered air mail).
villaromba wrote 06/15/2018 at 18:48 point
Nice one!! Looking forward to the build ...CP/M2 or 3 ?
Just4Fun wrote 06/16/2018 at 07:18 point
Both! I thing I'll start with the CP/ 2.2 because I already used it, so it will be more "easy" test the SD.... I have to add the "deblocking" routine (to menage the 512 byte sector of the SD) in the BIOS as stated in the "CP/M 2.2 Alteration Guide"...
Just4Fun wrote 06/01/2018 at 06:42 point
Z80-MBC2 project status (for those interested...):
Currently I've tested the new SRAM loader algorithm and the SRAM bank switch HW on the "old modified" breadboard, and they seem work as expected.
The next things to check are the new virtual I/O engine and the SD, but at this point I'm starting to think that I could make the new PCB just now and then go ahead using it...
john wrote 06/02/2018 at 23:39 point
Just curious if you have a link to this project?
Just4Fun wrote 06/03/2018 at 08:45 point
Up to now there isn't anything "published" yet (only a very first draft here: https://farm5.staticflickr.com/4740/25227641727_e48a4fdc31_o.jpg ).
Probably I'll make a new "project" here after at least a partially tested PCB...
Cyril V. wrote 06/05/2018 at 14:11 point
That is nice, I can't wait to test it.
John.D.Gay wrote 05/30/2018 at 18:13 point
Just getting ready to start playing with this.
Digging up some Z-80's and other hardware. Can't wait to see where this goes.
John.D.Gay wrote 05/31/2018 at 15:13 point
So, poking around at available memory chips, I'm thinking of just using 28C128 16K EEPROM and 48K RAM for my build. Maybe I could add an SDCard for storage as well? I'm kinda new to this but that is my current target.
Just4Fun wrote 05/31/2018 at 15:37 point
Hmmm... 28C128...?
You are building a completely different "thing"....
John.D.Gay wrote 05/31/2018 at 17:04 point
So far I'm only tossing around ideas that your project has inspired me to explore.
ATM, I've only got NMOS Z-80's so they are not compatible with the ATmega. My makerspace doesn't have the ATmega32A lying around ATM, anyway. So I'm just thinking out loud.
Since I cannot find the parts I was hoping to, I still might just buy some V3 boards and build them with purchased parts instead.
I am also poking around with a 68000 style board as well. Just bringing back memories of when these came out when I was a teen and getting into Electronics and Computers.
Just4Fun wrote 06/01/2018 at 06:12 point
I've some 68008 and Z180 laying around... May be I'll do "something" with  these, but not for now....
Moomin House wrote 05/28/2018 at 21:36 point
Howdy!  I'm thinking of ordering a PCB and building this using the files from https://github.com/WestfW/4chipZ80.  Haven't had a z80 since my Kaypro.  I'm a little confused, though -- I'm looking in the V2 directory and there are the files in Z80-4chip-v2.1-gerbers.zip which are named Z80-4chip-v2.1.* and are dated 11/14/17, and files listed that aren't in the zip file, which are named Z80-4chip7.* and are dated 2/4/18 (dates are from the downloaded and unzipped files).  What's the difference in these sets of files?  Would I be better off ordering a board using one or the other?
Thanks!
Just4Fun wrote 05/29/2018 at 06:14 point
Last version is V3 here: https://github.com/WestfW/4chipZ80/tree/master/Gerbers-V3
The file to use for production is Z80-4chip-v3-gerbers.zip.
There is a little fix to apply. Read here: https://github.com/WestfW/4chipZ80/issues/2
Happy soldering... :)
WestfW wrote 05/30/2018 at 07:21 point
The gerbers are sort of the 'release" points for the design files that are updated more continuously.  The nice thing about github is that you can see the history as well:
https://github.com/WestfW/4chipZ80/commits/master
Moomin House wrote 06/03/2018 at 22:06 point
Great -- thanks.  I'll order some V3 pcbs and get this started.
Peter K wrote 04/27/2018 at 08:25 point
Stupid question from a stupid person, but how’s the compatibility with existing software for the supported OS’s?
Just4Fun wrote 04/27/2018 at 10:13 point
Hi, no question is stupid... :)
I think that the terminal used could bring some compatibility issues...
I mean if you use an ANSI terminal emulation, if a program wants an other kind of terminal may not work.
Remember also that you have only two 128kb "drives" available.
Peter K wrote 04/27/2018 at 17:14 point
Good to know, thanks for the reply!
WestfW wrote 03/04/2018 at 01:29 point
Hmm.  Remember "piggybacking" chips?  ( http://www.retrotechnology.com/memship/membcard2k-6.jpg )
It occurs to me that if you had a output-only device (like a bit-banged graphics device), you could probably piggyback a second ATmega32 on top of the one we have now,  just picking up the data bus, 8bits of address bus, and the WAIT signal.  That would leave most of portB and portD (and the i2c pins from C) for doing "stuff" with.  The "master" m32 might have to have code to leave the bus active for a couple extra cycles so that the "extra" chip could grab the data without active handshaking, but ... that seems possible.
WestfW wrote 03/04/2018 at 01:32 point
scratch freeing the I2C pins - connect them to the main AVR and use them for I2C slave for lower-speed data (do both video and keyboard on that second chip!)
Just4Fun wrote 03/04/2018 at 08:43 point
May be using an Atmega128A could be more simple (and cheaper...), and probably the only changes on the "sketch" are related to the Z80 Clock output, or reassigning some GPIO's pin if some swaps are made to optimize the pcb layout...
After all the Atmega128A package is not so difficult to solder, and can be done using a normal iron with a "fat" tip and some flux... (https://www.youtube.com/watch?v=erb6-i54tbo).
About a video terminal, I've an idea how to do that... at the cost of about 1$... but no time (as usual...).
Cyril V. wrote 03/04/2018 at 21:31 point
What about a Mini Maple broad clone (Less than $4 on Aliexpress https://www.aliexpress.com/item/STM32F103CBT6-maple-mini-ARM-STM32-compatibility/32674146722.html). Is the 20 I/O 5 volt tolerant of the STM32F103CBT6 enough?
Just4Fun wrote 02/16/2018 at 07:33 point
If someone is interested, in the Z80-MBC GitHub Repository I've uploaded all the previous versions of the IOS "sketch" (under the "Old Versions" directory). The "Changelog" is inside each sketch, at the beginning.
I've uploaded also the Q/PM 2.71 "Diskpack" (to use the RTC), that was missing in the repo. To install Q/PM follow the "Log": A new OS: QP/M 2.71 and a RTC for timestamping.
Edgar Salgado wrote 02/12/2018 at 21:54 point
I finally got a working Z80-MBC soldered on the v2 pcb! Great! I flashed the ATMEGA but... I have difficulties having the terminal emulator send any text... I get stuck at the first promt (to set the RTC at compile time). I tried 9600 7 bits, but I can't find any valid setting to get it to send keystrokes :( Any good configuration for "screen" or "minicom", or putty under linux?
Thanks for this fun projet :)
Just4Fun wrote 02/13/2018 at 15:20 point
Use 9600, 8bit, N, 1S (no flow control).
Remember to upgrade the sketch to the last version (S221116_R100218_Z80.ino).
Under linux probably you need to enable USB for your username too.
Edgar Salgado wrote 02/13/2018 at 18:06 point
That worked great! It's been flashing the latest firm and works out of the box with "screen /dev/ttyUSB0 9600". It was that bug that was messing with the UART 😃
wenij wrote 02/11/2018 at 16:19 point
I try to trace the M32 code, but can't understand why need to do one BUSREQ_ for exit wait status?
digitalWrite(BUSREQ_, LOW);                // Request for a DMA
digitalWrite(WAIT_RES_, LOW);              // Reset WAIT FF exiting from WAIT state
digitalWrite(WAIT_RES_, HIGH);             // Now Z80 is in DMA, so it's safe set WAIT_RES_ HIGH again
digitalWrite(BUSREQ_, HIGH);               // Resume Z80 from DMA
The BUSREQ will be check in last instruction T cycle, but the Wait should happen after T2  of the instruction cycle.  Why not just do WAIT_RES_ L and H?
Just4Fun wrote 02/13/2018 at 15:16 point
BUSREQ_ is used to avoid data clash exiting from Twait and to handle the FF (because it is used in the "unstable" region too, when both R and S are asserted)
Just4Fun wrote 02/05/2018 at 16:07 point
Just as a starting point, here it is a first unfinished untested draft of what the Z80-MBC2 could be, with SD card and banked memory:
and here a simulation of the memory bank controller (for CP/M 3):
https://simulator.io/board/QpvxBsvpV2/2
Only an idea, not having the time to do any HW/SW check/test/proof for now...
villaromba wrote 02/05/2018 at 19:19 point
Excellent!!! Some very interesting additions/enhancements. Good to go down the SD Card route for greater flexibility and ease of programs.  CP/M 3 with  banked memory - a welcome change to CP/M 2!!!! Look forward to some builds in the future.
Cyril V. wrote 02/06/2018 at 18:04 point
That look great, can't wait!
Quick question: Why do you need the two MMBT2907A?
Thank you for the very clear explanation - as usual :)
Just4Fun wrote 02/09/2018 at 07:08 point
In the Z80 datasheet the maximum referenced I(OL) is 2mA. Probably it is possible sink more current at the cost of an higher V(OL), but this it is out of specs. So for a typical 4/5mA led it's safer to use a transistor (or a mosfet) to do the job.
The MMBT2907A is an smd PNP, but here I'll use a TH part (a "generic" 2N2907, that costs near nothing...).
kitguy wrote 01/29/2018 at 09:12 point
I only have ATMEGA328P-PU. Is it possible to use 328P-PU instead of 32A?
Just4Fun wrote 01/30/2018 at 06:52 point
Sorry, it isn't possible...
WestfW wrote 02/01/2018 at 06:11 point
(it needs pretty much all 40 pins of the Atmega32.)
J.B. Langston wrote 01/22/2018 at 00:28 point
I started working on a Z80 project a few weeks ago using a very similar approach to yours.  I didn't actually know about your project until after I started on mine but found it when browsing Z80 projects on Hackaday. I saw in your last comment that you are squeezed for I/O. I'm using a MCP23S18 to get extra I/O on my project.  Here's my code in case it has anything you can use... https://github.com/jblang/z80ctrl
WestfW wrote 01/20/2018 at 02:53 point
I've uploaded the V3 schematics, PCB, and gerbers to https://github.com/WestfW/4chipZ80
This version adds on-board I2C EEPROMs, at the expense of some of the prototyping area.
Once again, I haven't actually fabbed or tested these, so ... use at your own risk.  I'll let you know if I get feedback.
(Also note that at this point, none of the firmware in the github  repository  has been updated since the initial PCB, so it doesn't include any of the new stuff and is otherwise "stale.")
It's tempting to, say, use an ATmega128 (which are also very cheap)  to get some extra IO, do away with the prototyping area in favor of some sort of video-out circuitry, and maybe do some more SMT to make more room on the PCB, but I also feel like this should be kept "easy to hack hardware" by using through-hole components.  Sigh.
Cyril V. wrote 01/20/2018 at 13:59 point
We could have the two versions side by side.
A simple through-hole version like the V3.0 without AV and Keyboard easy to solder.
A SMD Verision with AV and Keyboard for people with more skill in soldering.
Another solution is to use a header board ATMega128 just for $2 more (this one is widely available):
https://www.ebay.com/itm/ATMEGA128-Adapter-Plate-Adapter-ATMEGA128-Plate-Development-System-Board/401255920894?hash=item5d6cb774fe:g:~wkAAOSw241YcTE0
wenij wrote 02/06/2018 at 03:45 point
for the temporarily solution, I use arduino 2560 + WestfW V2.1 and wire jump it to the M32 IC socket, and change the pin define in the Arduino  .ino file, and it still can work very well. Now, I have more extra pin can play more test ^_^.
share my modify arduino code and picture.
https://drive.google.com/drive/folders/1BWa1PmOornjm9QEJT2ijpwvvKtwBV4ul?usp=sharing
Just4Fun wrote 02/06/2018 at 07:37 point
OMG! I never thought of doing such a thing... Great!!
wenij wrote 01/21/2018 at 00:43 point
Is it possible to add  2 x 22pF load capacitors for ATMEGA32's XTAL1/2 to get external 16MHZ.
WestfW wrote 01/21/2018 at 05:56 point
You and CyrilV both want that.  There are pads on the xtal pin that might ALMOST work for a resonator with built-in caps (although they were mainly aimed at having extra IO pins on chips that let you reuse the pins if the internal osc was used (although, I'm not sure that there are any such chips.)
I'll give it a try for v4?  standard sized crystals?  Would it be OK to put some components UNDER the m32?  (requires use of a socket, of a particular type, or maybe putting the components on the bottom of the board.)  This strikes me as "riskier" than adding the EEPROMs; I'll need to move around some other key traces and stuff...
wenij wrote 01/21/2018 at 06:45 point
using standard crystals is good, and it should be ok to put under m32. ( using socket also give a chance to replace with more flash size  chip.  ex.  m644 or m1284p)
Just4Fun wrote 01/23/2018 at 11:18 point
Bill, I think that the grounding of the oscillator is not good...
Give a look here: https://electronics.stackexchange.com/questions/39136/competing-pcb-crystal-layout-recommendations
WestfW wrote 01/24/2018 at 07:04 point
Hmm. I'm not sure how much I can do, and I'm not sure I trust some of those app notes that apply to SMT high-speed oscillators when it comes to relatively low-speed TH parts (it seems to me like PCB traces here are similar in length to the pin/bondwire traces inside the chip, for instance.)
I can do a bit to help stop the "patch antenna effect" by providing an isolated path to CPU GND, maybe. Does this look any better?
https://photos.app.goo.gl/ppamAo90bjVazeKV2
(has anyone EVER seen a commercial or other published design that follows the Atmel "caps go between the pins and the crystal" recommendation?)
Just4Fun wrote 01/24/2018 at 10:38 point
For what I know, this it seems a lot better to me...
Just4Fun wrote 01/22/2018 at 17:17 point
Bill, it seems that someone (in Japan...??) is selling your PCB as a kit: https://store.shopping.yahoo.co.jp/orangepico/zwy7ve8yim.html
Cyril V. wrote 01/22/2018 at 17:58 point
It is the V2 for $13.5 (1500 yen) it is not too bad.
WestfW wrote 01/23/2018 at 08:15 point
That's fine with me, if it's OK with you.  It's nicely attributed too, a far as I can tell...
wenij wrote 02/03/2018 at 06:51 point
I get the V3.0 PCB board today, build one board, and work very well. But maybe have a little issue, the 2nd EEPROM address seems change from 0x51 to 0x52. ( need to change the arduino code to use it)
#define   EXT_EEPROM1   0x52  // I2C EEPROM 1 address (128kB))
WestfW wrote 02/04/2018 at 22:30 point
Huh.  Sure enough, that's the way the address lines are set up in the schematic, despite the labels that say 0/1.  I wonder how I managed to do that - the "add on" for the V1 PCB that I drew up is correct.  Sorry about that.
On the bright side, the address pins for the EEPROMs are supposedly laid out so that it would be easy to cut traces and add jumpers on the bottom of the board to change their addresses (though in this case, the SW change sounds easier.)
Marcelo Dantas wrote 02/05/2018 at 21:45 point
Would you be able to refer me to a maker of good/cheap prototype boards of V3?
wenij wrote 02/06/2018 at 00:49 point
I use seeedstudio fusion service, you can check it. for this project, it only cost $4.9 but $18  for DHL. https://www.seeedstudio.com/fusion.html
Just4Fun wrote 02/06/2018 at 07:25 point
I usually use ELECROW (https://www.elecrow.com/pcb-manufacturing.html).
5 PCBs 10x10cm @ $4.9 (any color) plus about $8 for shipping in EU using the cheapest "registered airmail". It usually takes about 20 days from the order.
Sometimes they add one or two PCBs more for free.
This is last batch I did with them: https://farm5.staticflickr.com/4480/37621987006_84a53aa93f_o.jpg
They added two more PCBs for free...
wenij wrote 02/06/2018 at 09:05 point
wa..  the shipping cost of ELECROW servicve is  cheap than seeedstudio. thanks, this good info.
WestfW wrote 02/07/2018 at 03:22 point
Most of the Chinese suppliers are running "up to ten 10x10cm boards for $5 (or less)" deals these days, so shipping costs tend to dominate, and run about $20 for all but the cheapest shipping methods (that many vendors seem unwilling to use.) (and 5 boards might be cheaper to ship than 10.)
The PCB itself is very conservative - min 0.3mm traces and 0.6mm vias, which is about twice the typical advertised limits.  Anywhere should be able to make them.
Ronald Lens wrote 11/24/2017 at 21:27 point
Just received my PCBs from China. Could not find an affordable PCB manufacturer around here (the Netherlands), now have 5 v2 PCBs for 1$ apiece excluding shipping. Have to say the boards look very good. If anyone around NL would like one, let me know, I order 5 which is the minimal order.
https://imgur.com/wbaBLA6
Looking forward to putting it together.
Edgar Salgado wrote 11/25/2017 at 19:30 point
Hello Ronald, what about selling and sending one to me via normal post to Spain? Is that an option? :)
