S221116_R050720_Z80.ino
Adds support for 4 drives and others updates. Please see the following repo (created by Al Williams) for new tools, updates and info: https://github.com/wd5gnr/Z80-MBC (by Al Williams)
ino - 165.09 kB - 07/07/2020 at 13:13
Download
S111216.c
TASM Assembler utility.
C Source File - 1.21 kB - 05/15/2018 at 06:05
Download
build.sh
Linux shell script to invoke TASM for WINDOWS (using wine) to assemble Z80 source code and produce a HEX file and a 'C' header file containing the code. Requires TASM 3.2 and wine. See the notes in the script (by Scott).
x-shellscript - 1020.00 bytes - 05/14/2018 at 19:31
Download
optiboot_m32-20mhz.hex
Anyone wishing to overclock the AVR at 20MHz; OptiBoot HEX file for ATmega32/A running at 20MHz (by Scott).
x-hex - 1.31 kB - 05/14/2018 at 18:29
Download
optiboot_m32-8mhz.hex
OptiBoot HEX file for ATmega32/A running at 8MHz (by Scott).
x-hex - 1.31 kB - 05/14/2018 at 18:28
Download
optiboot_m32-16mhz.hex
OptiBoot HEX file for ATmega32/A running at 16MHz (by Scott).
Download
S221116_R080518_Z80.ino
Adds support for AVR @ 16MHz, Z80 @ 4 or 8MHz, 24FC1026 EEPROMS, definable I2C rate for the EEPROMS (up to 800KHz). See notes at top of file (by Scott).
ino - 161.78 kB - 05/14/2018 at 04:16
Download
Makefile
MAKEFILE for use with SDCC under Linux. Should work for all SDCC 'C' projects. Supports the "data-loc=" and "code-loc" options (by Scott).
makefile - 6.08 kB - 05/14/2018 at 04:14
Download
iDisk-S250317_R090518.c
Bugfix. See top of file for details (by Scott).
x-csrc - 14.80 kB - 05/14/2018 at 04:09
Download
S221116_R100218_Z80.ino
The sketch for the Atmega32A (New release. Fix the "ghost RTC" bug: when there isn't any Virtual Disk (only Basic and Forth) the RTC clock was always incorrectly found).
x-arduino - 167.93 kB - 02/10/2018 at 16:45
Download
Z80-MBC PCB version - BOM.xls
Component list and BOM for the Z80-MBC PCB version (see schematic and gerbers at: https://github.com/WestfW/4chipZ80)
ms-excel - 28.50 kB - 10/17/2017 at 07:05
Download
Z80-MBC - BOM.xls
Component list and BOM for the Z80-MBC on breadboard
ms-excel - 28.50 kB - 10/17/2017 at 07:04
Download
SRecord-custom.zip
Batch and custom files for SRecord utility to make custom virtual disk images.
Zip Archive - 16.06 kB - 05/29/2017 at 15:03
Download
CPMtools-custom.zip
Batch and custom files for CPMtools utility to make custom virtual disk images.
Zip Archive - 4.48 kB - 05/29/2017 at 15:02
Download
BIOS QPM271 - S080517.asm
Source file of the BIOS for QP/M 2.71 with the RTC support
asm - 34.20 kB - 05/23/2017 at 19:19
Download
QPM271_DiskPack.zip
QP/M 2.71 Disk 0 image
Zip Archive - 110.02 kB - 05/23/2017 at 19:18
Download
CPM22 BIOS - S050217 R300417.zip
Sources for CP/M 2.2 and the BIOS (New version with the new BIOS supporting AUTOEXEC)
Zip Archive - 40.30 kB - 05/02/2017 at 17:35
Download
CPM22SYS_BIOS_S050217_R300417.hex
Disk 0 system tracks only upgrade with CP/M 2.2 and the new BIOS supporting AUTOEXEC.
x-hex - 14.92 kB - 05/02/2017 at 17:07
Download
CPM22_DualDisklPack_v2.zip
CP/M 2.2 dual disk system image (New version with the new BIOS supporting AUTOEXEC)
Zip Archive - 184.36 kB - 05/02/2017 at 17:06
Download
CPM22_SingleDisklPack_v2.zip
CP/M 2.2 single disk system image (New version with the new BIOS supporting AUTOEXEC)
Zip Archive - 101.35 kB - 05/02/2017 at 17:04
Download
iDisk - S250317.c
iDisk source
x-csrc - 18.29 kB - 04/21/2017 at 15:28
Download
iDisk - S250317.hex
The ready to use iDisk executable (.hex format)
x-hex - 17.68 kB - 04/21/2017 at 15:27
Download
ViDiT - S090417.c
Test program for the Virtual Disk Module
C Source File - 9.53 kB - 04/18/2017 at 14:10
Download
A110417.pdf
Virtual Disk Module schematic
Adobe Portable Document Format - 22.98 kB - 04/13/2017 at 19:29
Preview
Download
C_demo.zip
Two SDCC demo programs.
Zip Archive - 1.25 kB - 02/09/2017 at 21:11
Download
C_batch.zip
Two .BAT files for the SDDC toolchain.
Zip Archive - 1.01 kB - 02/09/2017 at 21:10
Download
S030217_crt0.s
"crt0" source file for the SDCC compiler.
Assembler Source File - 4.23 kB - 02/09/2017 at 21:08
Download
4chipZ80-Eagle-PCB.zip
Z80-MBC Eagle 2-Layer PCB and schematic made by Bill Westfield (Thanks Bill for sharing!). See his GitHub site for more info and updates: https://github.com/WestfW/4chipZ80.
Zip Archive - 2.04 MB - 02/04/2017 at 17:30
Download
S091216 R230117.asm
Z80-MBC uLoader source file
asm - 3.70 kB - 01/31/2017 at 20:42
Download
S260117.asm
Z80-MBC iLoad source file.
asm - 15.06 kB - 01/31/2017 at 20:42
Download
BlinkDemo.asm
The Assembler demo program used in the video for the "automated" Assembler toolchain.
- 1.80 kB - 01/31/2017 at 21:38
Download
LoadZ80.ttl
Tera Term macro for the "automated" toolchain.
turtle - 708.00 bytes - 01/31/2017 at 20:40
Download
asmbatch.zip
Two .BAT files for the Assembler toolchain.
Zip Archive - 1.03 kB - 01/31/2017 at 20:40
Download
A080117 Kicad4.zip
KiCad4 Project Files for the GPIO Expansion Module.
x-zip-compressed - 22.96 kB - 01/22/2017 at 13:34
Download
A080117.pdf
GPIO Expansion Module schematic.
Adobe Portable Document Format - 31.36 kB - 01/22/2017 at 13:34
Preview
Download
A041116 KiCad4 Files.zip
Z80-MBC KiCad4 Project Files.
Zip Archive - 37.14 kB - 01/08/2017 at 09:12
Download
basic.asm
Z80-MBC Basic interpreter.
x-asm - 196.93 kB - 01/04/2017 at 14:27
Download
S121216.asm
Z80-MBC uBIOS source file.
x-asm - 8.63 kB - 01/04/2017 at 14:27
Download
A041116 schematic.pdf
Z80-MBC schematic.
Adobe Portable Document Format - 101.42 kB - 12/17/2016 at 13:46
Preview
Download
