Two layers PCB!
A project log for A 4$, 4ICs, Z80 homemade computer on breadboard
No iron, no cry! Build a mini 4MHz Z80 64kB RAM system with Basic and Forth interpreters, CP/M 2.2, QP/M 2.71, Assembler and C toolchains
just4funJust4Fun 02/06/2017 at 20:440 Comments
Thanks to Bill Westfield now we have a beautiful ready to made PCB!
I've uploaded in the Files section all the Eagle files (schematic + PCB) zipped as 4chipZ80-Eagle-PCB.zip.
There are two versions, the first one with some little bugs and a second one with the needed corrections (see the "readme" file inside the zip for the explanations).
In any case I suggest to check at the Bill GitHub repository here for any update/information before sending it to a service (so you are sure to use the last updated version...).
