Here is an example of a photo taken by the MicroSat camera:
Animation generated by the website of all photo taken by the MicroSat camera for the day :
Solar camera embedded micro satellite circuit sculpture
MicroSat-01.gifGif made by the MicroSatGraphics Interchange Format - 7.00 MB - 03/14/2023 at 02:27 |
Micro-SAT ESP32 and Website Code.zipMicro-SAT ESP32 and Website Codex-zip-compressed - 8.38 MB - 03/14/2023 at 02:27 |
Schematic_MicroSat_2023-03-13.pngSchematic of MicroSatPortable Network Graphics (PNG) - 60.63 kB - 03/14/2023 at 02:27 |
Hard to say, continuously, maybe sends 2 to 3 photos without sun, otherwise 2 photos spaced 15 minutes apart without sun.
The problem is that even without anything connected, the supercap is slowly discharging, and connected with the ESP in standby the converters consume some energy. But I think it’s optimisable.
Hi! Nice sculpture,
I would like to know what are the up and down voltage converter you are using?
Hi! Thanks :)
For the Step-UP: https://fr.aliexpress.com/item/4001054709058.html
And for the Step-down: https://fr.aliexpress.com/item/32891890551.html
I know that now it is possible to have just one module that step-up and regulates the output if the input voltage goes beyond the output voltage like this: https://fr.aliexpress.com/item/1005002587844860.html , but I didn’t have any at that time.
I suggest to increase values of R1 and R2 at least 10 times in a way to reduce current leak +cap in parallel to R2.
Best way is to use micropower monitors like STM1061 /TPS3840/MIC841/etc
Hi thanks for your comment, I just used what I had on hand when I made the circuit, now I have additional KA75330 and KA75450, I can maybe do it again with a KA75330 connect on the pin enable of the ESP32...
I don't think 66K at 5V leak a lot of current, like 75µA ?
I wonder if the internal resistance of the supercap isn't consuming more current ^^
I'm new with this kind of projects, could you share the circuit and code where you use the KA75330?
Also another question, is it possible to store the taken images to the sd card you can insert in the ESP?
Great project, I love it.
How many time did the capa give you ?
