So overall layout will be similar to the following image (quickly rendered in Power Point):
8 tracks are lined up vertically, controls are on the first column, track mutes / display on second column, inputs on third, and outputs on fourth.
Note that the push buttons are momentary push, and can be illuminated by separate control logic. The idea is to pair with the ACL Sinfonion, not exactly, but in spirit. You can see buttons with full and partial illumination here for an idea of functionality:
