Main Sequencer Variables
The Mute Sequencer is an 8 track step sequencer, storing boolean values for the mute status. The maximum sequence length is 255 steps with 8 tracks containing the mute values. Length is the current sequence length (minimum 1, max 255) and step is the current step number. So if you look at sequencer[3][TRACK_1] you'd get the boolean value for Track 1 at step 3.
boolean[255][8] sequencer[step][track]
byte length
byte step
To not get confused on the boolean value for mute/unmute, we also #define their values. And because tracks are 1 indexed physically, and 0 indexed logically we'll also add in #defines for them too. These will also double as their button numbers.
#define MUTE false
#define UNMUTE true
#define TRACK_1 0
#define TRACK_2_ 1
#define TRACK_3 2
#define TRACK_4 3
#define TRACK_5 4
#define TRACK_6 5
#define TRACK_7 6
#define TRACK_8 7
Buttons have a few arrays to allow debounce and have state change flags for rising edge / falling edge logic.
boolean[14] button_current_state[button]
boolean[14] button_last_poll[button]
boolean[14] button_changed[button]
LEDs are a bit simpler, as they are just an array, but because we're controlling LED intensity as well, they are actually byte arrays for 0-255:
byte[14] led[button]
And adding a few more defines for the rest of the buttons and modes. (Mode is the general state machine state, of which we have 4)
#define BUT_STEP_PLUS 8
#define BUT_STEP_MINUS 9
#define BUT_ADD_UMO 10
#define BUT_DEL_MO 11
#define BUT_LIVE_EDIT 12
#define BUT_RESET 13
#define BUTTON_DEBOUNCE_TIME 50
#define MODE_EDIT 0
#define MODE_LIVE 1
#define MODE_LIVE_UMO 2
#define MODE_LIVE_MO 3
