Overview of the Modes
- Edit Mode
- Any changes to the current step's value is saved into the step sequencer
- Add will add a step, shifting the rest of the sequence right and incrementing length
- Delete will delete the current step, shifting the rest of the sequence left and decrementing length
- Pressing Edit/Live will change mode to 'Live' mode
- Live Mode
- Changes made to the current step will NOT be saved at clock/step+/step-/reset
- Pressing Add/UMO will change mode to 'Live Unmute Override' mode
- Pressing Del/MO will change mode to 'Live Mute Override' mode
- Pressing Edit/Live will change mode to 'Edit' mode
- Live Unmute Override
- When pressing the tracks buttons, will turn on unmute overrides for those tracks, these overrides will not be changed by the step sequencer
- Pressing Add/UMO will change mode to 'Live' mode
- Live Mute Override
- When pressing the tracks buttons, will turn on mute overrides for those tracks, these overrides will not be changed by the step sequencer
- Pressing Del/MO will change mode to 'Live' mode
General Button Behavior
- Track button LEDs will show the current step's mute status
- Pressing a track button will toggle the current value and the LED that indicates its value
- Step+ and Step- buttons
- Normally not illuminated
- Will illuminate at 50% for 100ms on receiving a pulse on the clock jack input
- When pressed, will change LED brightness to 100% until released
- When pressed, will display current step on the track buttons until released
- if 8 or less steps, will display in '8-up' mode at 50% brightness
- if more than 8, will display in binary mode at 50% brightness
- Add/UMO and Delete/MO buttons
- In Live mode, will latch to 50% brightness when UMO and MO modes are active
- In Edit mode
- Will shift all steps right one from current step, and keep the current step the same value
- This essentially 'copies' the current state, at step+1, and shifts the other steps +1
- In Live Mode
- transitions to UMO/MO modes
- Edit/Live Button
- On Press toggles between Edit and Live mode
- When pressed
- LED goes to 100% brightness, until released
- on release either latches off (edit mode) or 50% (live modes)
- Reset Button
- Will illuminate at 50% for 100ms when receiving reset pulse on the reset jack input
- When pressed
- LED goes to 100% brightness until released
- Sets current step to 0
- Disables clock in when pressed
