[Project log - 27112022]
A project log for Building a equipment to help ambulances
Building a equipment to help ambulances run through intersections.
TRAN.VINH.QUANGTRAN.VINH.QUANG 03/20/2023 at 15:440 Comments
The project continued to complete the prototype drawing, set up a suitable footprint for processing. The footprints without data are referenced by equivalent components, through the datasheet to confirm the required dimensions, this makes it convenient to solder the components later, avoiding having to redo due to the size deviation standard.
The project welcomes interested members to register to attend and continue to update...
