I have set the feedrate about 200mm/min and the cnc runs the gcode I created earlier. This pcb sample for testing 4G module. The CNC runs just enough for test and need surface finishing for solder components.
Continue to update...
A project log for Building a equipment to help ambulances
Building a equipment to help ambulances run through intersections.
