Gnat-Stats & Phat-Stats PC Performance Display
Arduino OLED PC Performance Monitor with Client software
Gnat-Stats Tiny OLED & Phat-Stats TFT PC Performance Monitor Display
GnatStats (OLED) & PhatStats (TFT) form an Arduino serial display. HardwareSerialMonitor is a PC serial client, both are written by Rupert Hirst and Colin Conway.
HardwareSerialMonitor Windows client reads the hardware statistics from the PC.
This data is forwarded over the hosts’ serial  port to an Arduino compatible micro processor. It is then, displayed using the GnatStats(OLED) or PhatStats(TFT) sketch.
This project, assumes you have a above average experience with Arduino, the IDE and the compatible boards available.
The HardwareSerialMonitor was designed for dedicated GPU's . Your mileage may vary with Integrated Graphics
To help with construction there are hook up guides, links below:
Phat-Stats ILI9341 TFT Display Hook up Guide
Gnat-Stats SSD1306 OLED Display Hook up Guide
Going Forward:
The project needs to be ported over to LibreHardwareMonitor , a fork of OpenHardwareMonitor  for future support, as this gets a lot more updates for new PC hardware. If anyone can help please get in touch, thanks.
http://tallmanlabs.com
http://runawaybrainz.blogspot.com/
https://github.com/koogar/HardwareSerialMonitor
https://github.com/koogar/Gnat-Stats
The above software/code is licensed under the following terms:
GPL v2
Gnat-Stats, Phat-Stats & Hardware Serial Monitor Copyright (C) 2016 Colin Conway, Rupert Hirst and contributors
This program is free software; you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation; either version 2 of the License, or (at your option) any later version.
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details.
You should have received a copy of the GNU General Public License along with this program; If not, see http://www.gnu.org/licenses/.
HardwareSerialMonitor was inspired by Psyrax's "SerialSender". Psyrax is given attribution and thanks, by being an honorary member of the project.
x-zip-compressed - 1.38 MB - 04/30/2021 at 15:39
Download
Download
PhatStats_TFT_ESP32_BT_Experimental_V2.0.2.2.zip
v2.0.2.2.BT: Use either BT or USB Serial "enable_DualSerialEvent" Change Baud rate to 115200 v2.0.2 Reduce the amount of header files. Change Boot Logo. Reduce the Size of the MHz font in the frequency gains display to allow for an extra digit. ESP32 Bluetooth Communication (BT Classic not BLE) Adjust NeoPixel brightness together with screen brightness using the rotary encoder (battery saver) If using a battery or LiPo pack you must take some responsibility, do your research!!!. No advice will be given, or implied regarding which you should use etc. !!!THE WEMOS LOLIN32 APPEARS TO HAVE NO (BMS) "LOW VOLTAGE CUT OFF " ON THE LIPO SOCKET!!! OTHER BOARDS ARE THE SAME, USE A LIPO BATTERY WITH BUILT IN PROTECTION (BMS).
x-zip-compressed - 45.61 kB - 05/01/2021 at 14:16
Download
PhatStats_TFT_ATSAMD_QT-PY_V2.0.3.zip
x-zip-compressed - 226.62 kB - 04/30/2021 at 15:36
Download
PhatStats_TFT_STM32F1_V1.6.5.9.zip
v1.6.5.9: Reduce the Size of the MHz font in the frequency gains display to allow for an extra digit New Boot screen Move encoder modes in its own function tab Rename switchpin to encoder_Button Clean up old stuff NOTE: After 1.6.5.9 STM32 BluePill is no longer supported!!! New features will not be compatiable. Trouble ? Cagan Celik's great guide to installing Phat-Stats on the STM32 BluePill https://www.technopat.net/2021/04/04/harici-sicaklik-gostergesi-yapimi/
x-zip-compressed - 392.00 kB - 04/26/2021 at 00:35
Download
View all 10 files
  • 1 × Arduino Leonardo/ ProMicro / STM32F1 / ATSAMD21 / ESP32
  • 1 × SSD1306 0.96" i2C OLED or ILI9341 2.2, 2.4, 2.8, 3.2" TFT SPi Display
  • 5 × Arduino Experience
  • Gnat-Stats (OLED) & Phat-Stats (TFT) Hook Up Guides
    Rupert Hirst03/11/2021 at 23:32 0 comments
    *Hook up guides for Gnat-Stats(SSD1306 OLED) and Phat-Stats(ILI9341 TFT)
    *for supported Micro Controllers.
    Phat-Stats Hook Up Guide
    Gnat-Stats Hook Up Guide
  • Phat-Stats ​TFT V1.6.3 ATSAMD21
    Rupert Hirst01/06/2021 at 17:23 1 comment
    Phat-Stats TFT V1.6.3 ATSAMD21
    (requires HardwareSerialMonitor 1.3 Upwards)
    Minimize blinking on screen data value changes and screen refresh.
     CPU Turbo or GPU Boost Mode frequency gains. (eg: +895MHz) or gain %
    Show when CPU or GPU is Throttling (Hit Thermal Junction Max temp)
    Show when CPU or GPU Turbo or Boost Mode is active.
    Add rotary encoder for PWM screen brightness.
  • Gnat-Stats HardwareSerialMonitor V1.3 update preview
    Rupert Hirst12/07/2020 at 18:42 0 comments
    Additional GPU Features:
    Fan Speed Load%, Fan Speed RPM, Total Memory, Used Memory, Current Power Consumption in Watts (Nvidia)
    Additional system RAM features:
    Total Memory, Available Memory, Memory Load.
    Picture showing the old and new GPU features.
    Currently Gnat-Stats HardwareSerialMonitor is still using the OpenHardwareMonitor source code, which is unfortunately outdated.
    New hardware support can only be leveraged using the LibreHardwareMonitor Source Code going forward.
    My time is limited, If anyone can help the transition please get in touch.
    Thanks
    Koogar
  • Run on Startup Win10
    Rupert Hirst06/15/2020 at 22:21 0 comments
    Due to the Windows 10 not allowing programs to run on startup as admin, here is a workaround script.
    1)  Right-click on the HardwareSerialMonitor.exe , go to properties, then compatibility and check "Run as Administrator"
    2)  Create the VBScript using a text editor (I used Notepad)
      Set WshShell = CreateObject("WScript.Shell" )
      WshShell.Run chr(34) & "C:\Program Files (x86)\HardwareSerialMonitor\HardwareSerialMonitor.exe" & Chr(34), 0
      Set WshShell = Nothing
    (The above path is an example, edit this to where your HardwareSerialMonitor.exe path is located)
    Save the script as "HardwareSerialMonitor.vbs" (no quotes)
    Note: Make sure to save it as a .vbs not .txt
    3)  Now place the HardwareSerialMonitor.vbs in the HardwareSerialMonitor folder:
    4)  Goto the Windows startup folder
    %AppData%\Microsoft\Windows\Start Menu\Programs\Startup, alternatively access it by Win+R ⇒ shell:startup ⇒ Enter
    Create a shortcut to the .vbs script above by right clicking then "New" ⇒ "Shortcut" ⇒ "Browse" for the "HardwareSerialMonitor.vbs" Script and select it.
    HardwareSerialMonitor Should now run on startup
  • Gnat-Tacho PC HardwareTachometer
    Rupert Hirst10/16/2018 at 11:26 1 comment
    The Gnat-Tacho is just an example of what you could make with a bit of imagination.
    Using a NeoPixel Ring (16)  and the NeopixelRingGauges.ino to form a CPU/GPU Bargraph.
    Custom overlay
View all 5 project logs
  • 1
    Step 1
    • Gnatstats Tiny OLED PC performance monitor  &  HardwareSerialMonitor  Windows Client
    This project, assumes you have above average experience with Arduino, the IDE, compatible boards available and other related hardware.
    ___________________________
    Project principles:
    The HardwareSerialMonitor application  detects the sensors of most modern PC graphics, CPU and motherboards whilst, also pooling windows hardware stats.
    This data is then sent over a serial com port to an Arduino Microcontroller running the GnatStats Sketch and displayed on the OLED/TFT display.
    Compatible boards:
    •    ProMicro   (Atmel ATMega 32u4) (Gnat-Stats)   Note: supports Neopixels
    •    QT-PY / XIAO Atmel ATSAMD21  (Phat-Stats)    Note: supports Neopixels
    •     BluePill   Ti STM32F103C8   (Phat-Stats)   Note: Does not support Neopixels!!!
    •     ESP32 LoLin32 / Lite / D32  (Phat-Stats)   Note: supports Neopixels
           ATMega 32u4 boards are more suited to (OLED) GnatStats .  They do not have the required memory for (TFT) PhatStats.
    Compatible Screens:
    • OLED :  SSD1306 (i2c) or SH1106 (i2c)  128x64 Pixels  (SH1106 is not supported on the ATSAMD21 due to library restrictions)
    Note: SH1106 are usually  screens over 0.96" but not limited to. The (GND/ VCC) pin out order is different, although, more recent versions have the same pin order as the SSD1306 (VCC/GND), buyer beware!!!
    •  TFT    :  Red PCB ILI9341 (SPi) 320x240 Pixels
    Library and MCU core links are included within the Arduino sketch.
    Notes:
    •               Plug the Arduino into a dedicated USB Port, try avoid using a USB hub. Timings can be critical to avoid garbled or corrupted screen info
    •               HardwareSerialMonitor was designed for dedicated GPU's . Your mileage will vary with Integrated Graphics
    Guides:
    technopat.net: Making an External Temperature Gauge
    technopat.net: Additional Tiny Performance Monitor for a Computer
    Technopat YouTube (Turkish)
    TallmanLabs: Phat-Stats ILI9341 TFT Display Hook up Guide
    TallmanLabs: Gnat-Stats SSD1306 OLED Display Hook up Guide
    Limitations:
                         My coding ability...     eg: There is no CPU fan support, the CPU fan is a motherboard fan. It requires a motherboard chip to be detected, and the correct fan sensor.
    I can only test the hardware I own. Overall it has worked with everything I have tried.
    HardwareSerialMonitor and the way some things have to be detected.  See (4) as it relies on the "OpenHardwareMonitorLib.dll"
    OpenHardwareMonitor updates are few and far between.
    Going forward:
                               Some PC hardware support for certain CPU / GPU's is lacking, particularly certain Ryzen CPU's.
    HardwareSerialMonitor needs to be ported from the OpenHardwareMonitorLib.dll to the LibreHardwareMonitorLib.dll (open source) as this has more features such as network /ethernet and receives updates on a more frequent basis.
    My time is limited, if you can help with this please get in touch, thanks.
View all instructions
estoyarto wrote 2 days ago point
Hi, great project ! Its possible to use https://ipc2u.com/catalog/vl050-8048nt-c01  , from and android of things kit?
Rupert Hirst wrote 2 days ago point
No, it is not even remotely similar.
Thanks Rupert!
phamanhduc1011 wrote 6 days ago point
i tried phat stats, i modified the code to fit with my set up (no encoder, no neopixel) and the upload was successful. However, it keep showing NO COM DATA. I wonder if anythings could go wrong?
Rupert Hirst wrote 6 days ago point
Thats not much information
Ozkan wrote 05/05/2021 at 14:45 point
Hi, Can I turn off Auto Mode on HardwareSerialMonitor? Can I get it to start by selecting the port I specified?
For example; Let's start by selecting the COM7 port.
https://prntscr.com/12j1okc
Rupert Hirst wrote 05/05/2021 at 17:51 point
It does not make much of a difference anyway as it writes the last port to a config file in the folder. When HardwareSerialMonitor starts it uses this information.
So it will always start use the last port, except for BT where you have to manually click the port again.
When it is in Automatic Mode the icon will be green.
Select the port you want to start, then click Automatic Mode at the top.
You will see a tick mark and the port named at the top in the Automatic Mode section.
stefan.schnitzer wrote 05/04/2021 at 09:30 point
Very nice project, I built a version for my PC.
https://img-9gag-fun.9cache.com/photo/axM3eWK_460swp.webp
Rupert Hirst wrote 05/05/2021 at 14:28 point
nice 3d printed enclosure
yusuf bayram wrote 04/27/2021 at 21:43 point
Hello, I tried to upload the project to Seeeduino XIAO and It shows me error "No device found on COM*" Looks like i did everything correct as I see.
https://imgur.com/a/JuBgIfB
Rupert Hirst wrote 04/27/2021 at 23:26 point
Do not use a USB hub, try a different usb port.
I have had problems with some USB3 ports when uploading
yusuf bayram wrote 04/28/2021 at 00:05 point
I don't use USB hub and tried all USBs on my pc, Didn't change anything.
Rupert Hirst wrote 04/28/2021 at 02:05 point
well i guess you messed up the flash.
Enter Bootloader Mode
Sometimes the Seeeduino XIAO port may disappear when user programming process fails. we can solve this problem by the following operation:
Connect the Seeeduino XIAO to your computer.
Use tweezers or short lines to short the RST pins in the diagram twice.
The orange LED lights flicker on and light up.
At this point, the chip enters Bootloader mode and the burn port appears again. Because the samd21 chip has two partitions, one is the Bootloader and the other is the user program. The product will burn a bootloader code in the system memory when it leaves the factory. We can switch modes by performing the above steps.
https://wiki.seeedstudio.com/Seeeduino-XIAO/
yusuf bayram wrote 04/29/2021 at 00:34 point
Those steps worked. Thank you.
Ozkan wrote 04/21/2021 at 19:42 point
hi, Everything works fine in the 1st picture, but when I enter the game, it is like the 2nd picture.
1. https://prntscr.com/11tb244
2. https://prntscr.com/11tb1zs
What is the problem ? Help pls.
im using Bluepill + 2.8 TFT (PhatStats_TFT_STM32F1_V1.6.3)
ragook wrote 04/21/2021 at 23:17 point
Maybe you have a garbage un-shielded motherboard USB header adaptor?
Rupert Hirst wrote 04/23/2021 at 00:08 point
You could try this to slow the connection down
/* Delay screen event, to stop screen data corruption ESP8622 / ESP32 use 15 or 25, most others 5 or 0 will do*/
int Serial_eventDelay = 15;
It should'nt be doing it really, I have no problems with the STM32.
BTW, I am no longer supporting the STM32 I did one last update v1.6.5 you can find it in the files section Depreciated2.zip
Going forward it will be ATSAMD  (including ESP32 maybe!!! due to bluetooth)
Edgaras wrote 04/15/2021 at 10:02 point
Hello, does anyone else experienced issues with freezing? I got this built and it freezes every 5-10 mins, I have unplugged the USB and plug it back in so it would start showing live details again
ragook wrote 04/15/2021 at 14:45 point
No Zero freezing here i run it all day long.
You havent provided much info.
What PC system ? What Arduino? Which Screen?
Edgaras wrote 04/15/2021 at 14:52 point
Good point
cpu: ryzen 3600
ram: corsair rgb pro 3000 16gb
gpu: rtx 2060 msi ventus
mobo: asrock steel legend b450
I use Arduino micro + SH1106 1.3inch oled screen
Code works perfectly fine, top right corner flashes D1, D2, D3 (as separate pages of info) for few minutes, and then it stops refreshing and freezes with data on oled screen frozen and not changing anymore. Thats when I have to unplug USB, plug it back in and it starts working again until it freezes again.
ragook wrote 04/15/2021 at 15:07 point
Are you using a USB hub?
"Notes:
              Plug the Arduino into a dedicated USB Port, try avoid using a USB hub. Timings can be critical to avoid garbled or corrupted screen info"
Edgaras wrote 04/16/2021 at 13:07 point
direct usb to motherboard and front io panel tried, both same result. Actually motherboard USB froze faster than front io port
Rupert Hirst wrote 04/16/2021 at 13:46 point
i have heard that Ryzen motherboard chipsets have a problem with frequent USB disconnects
phamanhduc1011 wrote 04/15/2021 at 09:56 point
there are ILI9225 driver displays in my area, LCD TFT 2.2 SPI to be specific. Is this screen be used with this project?
Rupert Hirst wrote 04/15/2021 at 14:41 point
ILI9225 resolution 176x220
ILI9341  resolution 240x320
It has to run native, its not like a TV with scaling
phamanhduc1011 wrote 04/15/2021 at 23:50 point
thanks for your response
cagancelik88 wrote 04/12/2021 at 10:51 point
Just curious why has bluepill support been dropped without any explanation? I also cannot see latest working bluepill & tft lcd combo (which was v1.6.3) in your deprecated.zip file.
Rupert Hirst wrote 04/12/2021 at 16:22 point
Hi,
STM32 was dropped because all the PM's regarding problems are to do with the BluePill. It is also, harder to maintain, as some features going forward simply will not be supported.
The BluePill maybe be cheap at $3 but, so is the QT-PY $6 and XION $5
I don't save money when someone choses a BluePill over the alternative, I just get questions which involve lengthy answers.
The goal was always to have one platform, to rule them all :)
PS: The depreciated.zip has been updated
Ozkan wrote 04/06/2021 at 14:15 point
When I compile the code, I get an error like the picture.
https://prntscr.com/115skz0
Rupert Hirst wrote 04/06/2021 at 21:00 point
Look at the error and  try reading the line regarding the adafruit grfx library in the sketch
Ozkan wrote 04/08/2021 at 19:01 point
I am using BluePill, all my connections are as in the diagram. I have successfully compiled the code and loaded it into the microcontroller and connected everything correctly. I see nothing but the white screen.
https://prntscr.com/117jnxx
https://prntscr.com/117jo0f
tahaguven wrote 03/30/2021 at 16:11 point
Seeeduino XIAO I hooked up with. white screen appears. what would be the reason ?
minidaveo wrote 03/31/2021 at 14:59 point
same for me, tried connecting the rotary to 5v and still nothing
perhaps there is a resistor , a high/low output command or external power that’s needed to get it to work??
tahaguven wrote 03/31/2021 at 18:29 point
I applied exactly what the project wanted.
Rupert Hirst wrote 03/31/2021 at 19:31 point
Same for me? Tried connecting the rotary encoder?
5v what are you using? the only Arduino boards that Phat Stats use a rotary encoder on are 3.3v MCU's unless you want to blow a pin
minidaveo wrote 03/31/2021 at 19:51 point
I’m using the seeed xiao
I used the 5v from pin 13 as per shown on the pin out picture you have on your website
tried the 3.3v pin 11 first but nothing and looking on the internet the rotary can take 5v vcc anyway
Rupert Hirst wrote 03/31/2021 at 20:01 point
I don't use the 5v pin.
The rotary encoder can take 5v sure but the XIAO can not its a 3.3v micro
find this line in the Config settings
#define enableQTPYneopixel      // uncomment to disable QT-PY built in Neopixel if you have a XIAO
and change it to
//#define enableQTPYneopixel      // uncomment to disable QT-PY built in Neopixel if you have a XIAO
Maybe the it is interfering with a pin number on the XIAO
minidaveo wrote 03/31/2021 at 20:12 point
will try that tomorrow, my setup is currently at work
appreciate the help
just to confirm you are running the screen, rotary and xiao off the usb cable power and no other external power source??
Rupert Hirst wrote 03/31/2021 at 21:05 point
It powers from USB only, the rotary encoder does not even have to be connected
the board files in the code are for the QT-PY
Maybe you should get familiar read this beforehand.
https://www.thingiverse.com/thing:4812311 dalgibbard is using the XIAO
Rupert Hirst wrote 04/01/2021 at 00:22 point
I tried a XIAO it works Perfectly
check your pins and select the correct board before you upload
https://drive.google.com/file/d/1RjsJJhGxfFMJ0PMAkJE1SlpBRTMX9KGM/view?usp=sharing
Rupert Hirst wrote 03/31/2021 at 19:27 point
 I have never tried a XIAO but it is pin compatible and the same ATSAMD as a QT-PY.  They are made to be compatible with each other
Did you install the board core in Arduino  correctly according to Seeed?
minidaveo wrote 03/31/2021 at 19:54 point
yes libraries and board manager as per your instructions from your code were installed
Rupert Hirst wrote 04/01/2021 at 00:20 point
minidaveo wrote 04/01/2021 at 07:42 point
it works! Updated the board manager to seeeduino that’s where I went wrong, perhaps you could update your files to include the https://files.seeeduino.com/arduino/package_ seeeduino_boards_index.json path so others can use that for the XIAO instead of the QT-PY
many thanks again
Rupert Hirst wrote 04/02/2021 at 01:04 point
Working?
yusuf bayram wrote 04/03/2021 at 09:09 point
I have the same issue with BluePill. I succesfully compiled and uploaded the code to the micro controller and the hooked up everything correct. I don't see anything but the white screen.
Rupert Hirst wrote 04/03/2021 at 13:24 point
Upload to this standard example graphic test.
https://github.com/koogar/Gnat-Stats/blob/master/TFT_PhatStats/TFT_STM32/BluePill_ILI9341_graphicstest.zip
yusuf bayram wrote 04/03/2021 at 16:15 point
Thanks for answer. I uploaded the example and it was the same white screen and I realized one or two solders that I made on BluePill pins wasn't good. Now it's working properly.
https://imgur.com/9yfa4jE
Don wrote 03/27/2021 at 00:28 point
Got an oddity on PhatStats 1.6.2. I used an Adafruit Feather M0 Express,  2.8" HiLetgo ILI9341 display from Amazon (same display I used with GnatStats 1.5 TFT), with the rotary encoder option. When my CPU and GPU clock down to idle (800MHz for CPU, 300MHz for GPU) I still have a trailing digit wth the MHz overlaid on it (numerically 800 looks like 8000 for the CPU, 300 looks like 3005 for the GPU for example). Any ideas on how to fix this?
Edit: created a workaround in the code (for now, unless there is no other fix).
Changed the cpu clock ctring to use text size 3 instead of 4, coded in a trailing space. Did the same for the MHz.
    tft.setTextSize(3);
    //tft.setTextSize(4);
    tft.setCursor(105, 55);
    tft.print(cpuClockString); //CPU Freq
    tft.print(" ");
    tft.setTextSize(1);
    tft.print("MHz   ");
I also did the same for the gpu string setup. I have made some other edits that fit my build better. If my edited version can be helpful, I can upload it somewhere.
Rupert Hirst wrote 03/27/2021 at 18:15 point
PM'd
cagancelik88 wrote 03/26/2021 at 18:46 point
Unfortunately the last update broke the NeoPixel for me. It used to work in previous version. Although I'm not sure if it was working the way it's supposed to be because I got it working just today. The LEDs were responding to GPU and CPU utilization somehow but colors seemed a bit off or random.
I was checking this page then I realized that there's a new version. As I said uploading it to my Pro Micro made the LEDs go completely dark now. My screen is SH1106 and I'm using 220 Ohm resistor between ProMicro's "D10" pin and NeoPixel's "DI" pin.
Here are some images:
https://ibb.co/tPgztg0
https://ibb.co/kcRzgdt
nvm figured it out: I had to uncomment #define enableNeopixelGauges
cagancelik88 wrote 03/24/2021 at 20:55 point
Hey there,
Can I get some info on how to print or cut the overlay for gnat-stats? How was it made? And where can I find that glass/plastic top piece? Thanks!
Rupert Hirst wrote 03/25/2021 at 22:08 point
The glass and chrome bezel were from a car voltage meter.
The overlay was cut out with a Cricut
cagancelik88 wrote 03/26/2021 at 18:41 point
Thank you very much!
tahaguven wrote 03/23/2021 at 10:41 point
Hello there. I am using bluepill and an ILI9341 display. but the articles do not appear properly. what is the reason of this ? thanks.
ragook wrote 03/23/2021 at 23:11 point
so little information
ragook wrote 03/24/2021 at 19:39 point
What Arduino STM32 core are you using?
you need to use this
https://github.com/rogerclarkmelbourne/Arduino_STM32/wiki/Installation
Not the official STM32 core it is slow.
tahaguven wrote 03/24/2021 at 21:49 point
STM32F103C8T6
I use
ragook wrote 03/24/2021 at 22:30 point
The chip it is what is used in the arduino ide the core is not.  Hmmmmmm.
See... we shall
Rupert Hirst wrote 03/25/2021 at 23:10 point
STM32F103C8T6  is not the core.
The core is what the Arduino Software uses for each different boards
For the BluePill you must use
tahaguven wrote 03/25/2021 at 23:15 point
ok i did everything here. the result has not changed.
my screen is 240x320 does it matter? ILI9341 2.8 "240x320
Rupert Hirst wrote 03/26/2021 at 00:38 point
you are using the same screen as i am using.
Did you upload the code again using the new core?
You should see this exactly this when selecting the board in the Arduiino IDE
https://drive.google.com/file/d/1UrBxE95TJuFvXjs56rZ852UwmJLu61g1/view
Have you tried it on another PC? do you get the same result?
tahaguven wrote 03/26/2021 at 11:03 point
https://resimyukle.xyz/i/zPOOMT
I did everything from there
tahaguven wrote 03/26/2021 at 11:04 point
I will try it on another computer.
tahaguven wrote 03/26/2021 at 20:16 point
https://resimyukle.xyz/i/OTJNIG
another computer is the same. It works on first boot and is corrupted afterwards.
https://resimyukle.tc/image/f22e1ecb-76aa-4951-9d73-e3aa79e0fda0.oySA
Rupert Hirst wrote 03/26/2021 at 22:18 point
try this
https://drive.google.com/file/d/1sUiX74_KPjE0kLxWbxqtoWFmubcnedoQ/view?usp=sharing
tahaguven wrote 03/27/2021 at 11:13 point
https://resimyukle.xyz/i/A95TBB
has not changed. the result is the same
Rupert Hirst wrote 03/27/2021 at 20:30 point
Try this version
https://github.com/koogar/Gnat-Stats/blob/master/TFT_PhatStats/TFT_STM32/DEPRECIATED/PhatStats_TFT_STM32F1_V1.6.2.zip
Change the pins for the encoder according to the pins.txt
tahaguven wrote 03/27/2021 at 21:08 point
the result has not changed the same :(
Rupert Hirst wrote 03/28/2021 at 02:53 point
I really don't know then.
I know what is happening just not why on yours
What does it say on the Chip
https://hackaday.com/2020/10/22/stm32-clones-the-good-the-bad-and-the-ugly/
tahaguven wrote 03/28/2021 at 11:13 point
https://resimyukle.xyz/i/QTJN5a
tahaguven wrote 03/28/2021 at 11:16 point
https://resimyukle.xyz/i/34TSCJ
let me show the screen. which might be the problem?
tahaguven wrote 03/28/2021 at 21:34 point
ATSAMD21
I ordered. Do you think the problem is related to the card?
Rupert Hirst wrote 03/31/2021 at 09:57 point
Your ILI9341 TFT is good, I do not know if it is your BluePill, my works great.
You could try changing the below value in the PhatStats Config settings
/* Delay screen event, to stop screen data corruption ESP8622 use 25, most others 5 or 0 will do*/
int Serial_eventDelay = 0; //
Try values from  5 to 25
it should not need anything for a STM32 but its worth trying
Which ATSAMD did you buy?
tahaguven wrote 04/04/2021 at 12:48 point
problem solved. The USB driver needs to be plugged directly into the motherboard. When I plug a USB in the safe, the writings are corrupted. thank you.
TheRandomGuy wrote 03/19/2021 at 15:44 point
Hello! I am very interested in this project and I want to try it myself! I wanted a twist in order to learn to code. So, I bought 3.5-inch TFT LCD screen for Arduino Uno and I'm trying to modify the coding to fit on this screen. Any tips, suggestions? where should I start? I already downloaded all the libraries for the screen and tested it and it works fine, although the touch screen is funky( i don't want to use it anyway).
Rupert Hirst wrote 03/19/2021 at 17:35 point
What is the controller for the 3.5" screen?
The UNO is not compatible with Phat-Stats
TheRandomGuy wrote 03/19/2021 at 19:37 point
I dont know what controller you are talking about...
https://www.amazon.ca/480x320-Screen-Module-Arduino-Without/dp/B07NWH47PV/ref=sr_1_7?dchild=1&keywords=3.5+inch+screen+arduino&qid=1616182604&sr=8-7
this is the one that I bought
Don wrote 03/27/2021 at 06:27 point
I tried to rewire a 2.4" UNO shield screen when testing the older Gnat Stats 1.5TFT. I never found a wiring setup that got it working on the Arduino Micro for Gnat Stats. I went with a 2.8" ILI9341 display (the one I got for $17.00USD is over $70 on Amazon Canada). But the following one *should* work with any of the PhatStats compatable microcontrollers.
https://www.amazon.ca/WayinTop-ILI9341-Display-240X320-Resistor/dp/B087C3PP9G/ref=sr_1_5?dchild=1&keywords=ili9341&qid=1616826075&sr=8-5
You can also look for ILI9341 3.5" 240x320 if you want that screen size.
EVilm1 wrote 02/12/2021 at 18:56 point
Hello ! I'm new and I discovered this project.
It's incredible and I would love to do the same at home.
I have never tested this kind of project before and after several hours of research on your project,
I still have some questions before buying the components.
I think my message can help a lot of people in the same situation as me. The project displayed here is not very intuitive for a beginner. But doable!
I would like a mini oled screen displaying my pc information in real time.
If I have understood everything correctly, for that I must :
If I want to use a mini oled screen, I can take a "SSD1306 (i2c)" such as this one :
https://www.amazon.fr/AZDelivery-pouces-Arduino-Raspberry-microcontr%C3%B4leur/dp/B01L9GC470/
As a controller, I can take the Arduino ProMicro like this one :
https://www.amazon.fr/ARCELI-Atmega32U4-Bootloadered-d%C3%A9veloppement-Microcontr%C3%B4leur/dp/B07J2Q3ZD5/
Then I need to connect the SSD1306 display to the ProMicro, is there a mounting shema?
From what you can see on the 2nd picture of the project, the display is directly installed on the ProMicro if I'm not mistaken.
I imagine that the GND must be aligned but the others don't match... I don't know.
Edit : I did download the files and found the connections I think. SDA on pin2, SCL on pin3 and I guess GND on pin4 and VCC on pin 5?
If I want to use a mini OLED display I have to take the GnatStats (OLED) file and not the PhatStats (TFT) file because it is only for TFT displays. (Is this correct?)
So I can take this file : "GnatStats_ProMicro_OLED_V1.33.zip".
Then you have to flash the code on the ProMicro, in the folder there are several ".ino" files and a "bitmap.h" file.
I guess I have to flash them on the ProMicro, but I have to flash them all? From what I've seen I have to compile the files. Is that right?
I've done Arduino before but it was just on an Arduino UNO.
Suppose I manage to flash the ProMicro, I connect it via USB to the PC. I connect it in internal USB 2.0.
We can quickly get lost between OpenHardwareMonitor, HardwareSerialMonitor, LibreHardwareMonitor...
If I understood correctly, for the ProMicro to capture the information, HardwareSerialMonitor must be running (and there are solutions that exist to launch it at startup automatically).
When running it sends information about the COM port, the ProMicro receives, and displays.
Finally, I use very recent components such as a Ryzen 9 and an RTX 2060. I guess if OpenHardwareMonitor manages to read my information, it must work with this project?
Here is what I understood, I would like you to please confirm all what I said, or to complete some points.
If everything is ok I'll go ahead and order the components!
Thank you for your help ;-)
Rupert Hirst wrote 02/13/2021 at 16:26 point
Hi,
Answer to some of your questions.
Running on Startup: https://hackaday.io/project/19018-gnat-stats-tiny-oled-pc-performance-monitor/log/179299-run-on-startup-win10
All the tabs get compiled together as one in the Arduino IDE  just like any other sketch. The tabs are there to break the code down into modules, it would be very long and hard to work with other wise.
HardwareSerialMonitor the companion to  Gnat-stats(OLED)  or Phat-stats(TFT) work together and are  developed by me.
LibreHardwareMonitor is a fork of OpenHardwareMonitor both are open source. One is better than the other.
HardwareSerialMonitor relies on one file "OpenHardwareMonitorLib.dll" from OpenHardwareMonitor to detect the hardware and send it to the Arduino sketch.
 OpenHardwareMonitor application does not need to be run or present on the host PC.
You could connect the USB internally to the motherboard with the appropriate adaptor "internal usb header adapter" which is easily found on Google.
This project has evolved a lot since its inception and thus it has been hard to do a guide for beginners.
The ProMicro while being a very capable micro is very limiting due to its small memory especially in  HardwareSerialMonitor v1.3.
As I try  new platforms eg: 32u4/ ESP8266 / STM32 /ATSAMD etc. I have updated the code. Having so many options and pitfalls it has been impossible to cater for beginners yet it makes it easier for advanced users with those micro's
I have been experimenting with the Adafruit QT-PY & Seeeduino XIAO a cheap powerful solution which will limit the project to one specific board.
Going forward, the only code with be for that platform. At which point I could do a guide for beginners for the OLED and the TFT versions with hook up diagrams etc. for select hardware.
As for compatibility with your Ryzen, I could not tell you.  I have seen many images with Ryzen's that work and many questions about it doesn't, some is user error, some is not.
In theory if it works in the OpenHardwareMonitor application it should work in HardwareSerialMonitor and Gnat-Stats.
The Ryzen platform has been problematic for OpenHardwareMonitor especially as it gets few updates.
Yet!!! if it works in OpenHardwareMonitor  and not in HardwareSerialMonitor / Gnat-Stats they could be detecting certain Ryzen CPU's in a different manner to which I am not aware of.
Hope this clears up a few things
Rupert
EVilm1 wrote 02/14/2021 at 02:11 point
Hi !
Thank you for your complete and detailed answer.
I downloaded the file and managed to compile it, I understood by myself that it was enough to open only one file for all the other files to follow in the compilation.
So I managed to compile the whole thing, (Gnat-stats for OLED)
However, there are still some mistakes that I don't really understand.
These are warnings and not errors, I guess it doesn't matter because I don't want to use NeoPixel (leds).
Here are the warnings:
GnatStats_ProMicro_OLED_V1.33.ino:180:0:  /Adafruit_SSD1306.h:63:0: warning: "BLACK" redefined #define BLACK SSD1306_BLACK  ///< Draw 'off' pixels
GnatStats_ProMicro_OLED_V1.33.ino:165:0: note: this is the location of the previous definition #define BLACK 0x000000 // OFF
The same for white...
As you say QT-PY would be more suitable for OLED screens. Does the code work with QT-PY today? I need to buy QT-PY more than ProMicro?
Nothing is specified about QTPY in Gnat-Stats 1.33. Would it still be SDA on pin2, SCL on pin3, GND on pin4 and VCC on pin 5?
Or just connect the pins with the same name? (GND -> GND, VCC -> 3.3V, SDA -> SDA, SLC -> SCL) a bit laborious sorry xd
I looked at your code a little bit, very interesting! There are even 3 possible displays!
Thank you for your project and your help :D
Rupert Hirst wrote 02/15/2021 at 18:21 point
The warnings you are getting look like library conflict errors probably because you have more than one library with the same header file(.h) name.
The QT-PY is more suitable for TFT screens but will work with OLED as long as it is a SSD1306 not the SH1106 as there is no library for the QT-PY that I can find.
I have OLED  working on the QT-PY I just have not released it yet
All the OLED screens which are 0.96" tend to be SSD1306 while screen sizes above that will be SH1106 but the seller will still call it a SSD1306!!!.
you can  tell by the pin order
SSD1306 = VCC/GND/SCL/SDA
SH1106    = GND/VCC/SCL/SDA
The pin connections are VCC to VCC GND to GND,  SDA and SCL  are different depending on the Microprocessor.
SDA and SCL are not mentioned in the code, you only have to connect them to the correct  pins.
EVilm1 wrote 02/16/2021 at 23:07 point
Thank you for your response,
What do you mean by "I have OLED working on the QT-PY" ?
Does GnatStats_ProMicro_OLED_V1.33 already work with QT-PY and OLED SSD1306 ?
For the pins I think I understood, it's just logic...
Thanks
Alvaro rubio wrote 02/03/2021 at 19:44 point
hola de nuevo alguien me puede decir como tengo que conectar  LOS PINES de un lcd ILI9341 a la placa STM32 ? LO AGRADECERIA MUCHO
Alvaro rubio wrote 02/03/2021 at 18:25 point
como tengo que conectar el arduino en el lcd de 320x240
me refiero al esquema electrico
Alvaro rubio wrote 02/02/2021 at 15:21 point
Hola buen dia tengo varias preguntas
puede conectar un lcd 240x320  a arduino pro micro , si es así como tengo que conectar los pines y en que lugar
Rupert Hirst wrote 02/02/2021 at 18:14 point
GnatStats_TFTonly_ProMicro_STM32_V1.5b
TFT Version 1.5 : STM32 BluePill & ProMicro Suppport
: 128x160 ST7735 & 240x320 ILI9341 TFT Support
Alvaro rubio wrote 02/03/2021 at 12:02 point
vale y solo con instalar esa version en arduino y conectarla deberia encender??
