Gnat-Stats & Phat-Stats PC Performance Display
Arduino OLED/TFT PC Performance Monitor with Client software
Gnat-Stats Tiny OLED & Phat-Stats TFT PC Performance Monitor Display
GnatStats (OLED) & PhatStats (TFT) form an Arduino serial display. HardwareSerialMonitor is a PC serial client, both are written by Rupert Hirst and Colin Conway.
HardwareSerialMonitor Windows client reads the hardware statistics from the PC.
This data is forwarded over the hosts’ serial  port to an Arduino compatible micro processor. It is then, displayed using the GnatStats(OLED) or PhatStats(TFT) sketch.
This project, assumes you have a above average experience with Arduino, the IDE and the compatible boards available.
The HardwareSerialMonitor was designed for dedicated GPU's . Your mileage may vary with Integrated Graphics
To help with construction there are hook up guides, links below:
Phat-Stats ILI9341 TFT Display Hook up Guide
Gnat-Stats SSD1306 OLED Display Hook up Guide
Going Forward:
The project needs to be ported over to LibreHardwareMonitor , a fork of OpenHardwareMonitor  for future support, as this gets a lot more updates for new PC hardware. If anyone can help please get in touch, thanks.
http://tallmanlabs.com
http://runawaybrainz.blogspot.com/
https://github.com/koogar/HardwareSerialMonitor
https://github.com/koogar/Gnat-Stats
The above software/code is licensed under the following terms:
GPL v2
Gnat-Stats, Phat-Stats & Hardware Serial Monitor Copyright (C) 2016 Colin Conway, Rupert Hirst and contributors
This program is free software; you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation; either version 2 of the License, or (at your option) any later version.
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details.
You should have received a copy of the GNU General Public License along with this program; If not, see http://www.gnu.org/licenses/.
HardwareSerialMonitor was inspired by Psyrax's "SerialSender". Psyrax is given attribution and thanks, by being an honorary member of the project.
x-zip-compressed - 1.38 MB - 04/30/2021 at 15:39
Download
Download
PhatStats_TFT_ATSAMD_QT-PY_V2.0.7.zip
V2.0.7 Fix CPU & GPU Overclock gains "-+" bug
x-zip-compressed - 232.08 kB - 07/21/2021 at 13:50
Download
PhatStats_TFT_ESP32_BT_V2.0.7.zip
V2.0.7 Fix: CPU & GPU Overclock gains "-+" bug Still to Fix : Dual Event (USB and BT) needs fixing
x-zip-compressed - 154.66 kB - 07/21/2021 at 13:50
Download
PhatStats_TFT_STM32F1_V1.6.5.9.2.zip
x-zip-compressed - 795.31 kB - 07/21/2021 at 13:50
Download
View all 9 files
  • 1 × Arduino Leonardo/ ProMicro / STM32F1 / ATSAMD21 / ESP32
  • 1 × SSD1306 0.96" i2C OLED or ILI9341 2.2, 2.4, 2.8, 3.2" TFT SPi Display
  • 5 × Arduino Experience
  • Phat-Stats ILI9341 2.8" TFT Enclosure Prototype
    Rupert Hirst2 days ago 0 comments
    Rear view  MCU "sight glass"
     Bottom USB C input, so the cable can lay in any position.
  • Gnat-Stats Concept SSD1306 OLED Enclosure
    Rupert Hirst07/03/2021 at 22:35 0 comments
  • Phat-Stats Slim USB Concept Case
    Rupert Hirst06/16/2021 at 15:02 0 comments
  • Phat-Tacho Bluetooth Concept Case with new DisplayStyle
    Rupert Hirst05/27/2021 at 23:04 1 comment
  • Gnat-Stats (OLED) & Phat-Stats (TFT) Hook Up Guides
    Rupert Hirst03/11/2021 at 23:32 0 comments
    *Hook up guides for Gnat-Stats(SSD1306 OLED) and Phat-Stats(ILI9341 TFT)
    *for supported Micro Controllers.
    Phat-Stats Hook Up Guide
    Gnat-Stats Hook Up Guide
  • Phat-Stats ​TFT V1.6.3 ATSAMD21
    Rupert Hirst01/06/2021 at 17:23 1 comment
    Phat-Stats TFT V1.6.3 ATSAMD21
    (requires HardwareSerialMonitor 1.3 Upwards)
    Minimize blinking on screen data value changes and screen refresh.
     CPU Turbo or GPU Boost Mode frequency gains. (eg: +895MHz) or gain %
    Show when CPU or GPU is Throttling (Hit Thermal Junction Max temp)
    Show when CPU or GPU Turbo or Boost Mode is active.
    Add rotary encoder for PWM screen brightness.
  • Gnat-Stats HardwareSerialMonitor V1.3 update preview
    Rupert Hirst12/07/2020 at 18:42 0 comments
    Additional GPU Features:
    Fan Speed Load%, Fan Speed RPM, Total Memory, Used Memory, Current Power Consumption in Watts (Nvidia)
    Additional system RAM features:
    Total Memory, Available Memory, Memory Load.
    Picture showing the old and new GPU features.
    Currently Gnat-Stats HardwareSerialMonitor is still using the OpenHardwareMonitor source code, which is unfortunately outdated.
    New hardware support can only be leveraged using the LibreHardwareMonitor Source Code going forward.
    My time is limited, If anyone can help the transition please get in touch.
    Thanks
    Koogar
  • Run on Startup Win10
    Rupert Hirst06/15/2020 at 22:21 0 comments
    Due to the Windows 10 not allowing programs to run on startup as admin, here is a workaround script.
    1)  Right-click on the HardwareSerialMonitor.exe , go to properties, then compatibility and check "Run as Administrator"
    2)  Create the VBScript using a text editor (I used Notepad)
      Set WshShell = CreateObject("WScript.Shell" )
      WshShell.Run chr(34) & "C:\Program Files (x86)\HardwareSerialMonitor\HardwareSerialMonitor.exe" & Chr(34), 0
      Set WshShell = Nothing
    (The above path is an example, edit this to where your HardwareSerialMonitor.exe path is located)
    Save the script as "HardwareSerialMonitor.vbs" (no quotes)
    Note: Make sure to save it as a .vbs not .txt
    3)  Now place the HardwareSerialMonitor.vbs in the HardwareSerialMonitor folder:
    4)  Goto the Windows startup folder
    %AppData%\Microsoft\Windows\Start Menu\Programs\Startup, alternatively access it by Win+R ⇒ shell:startup ⇒ Enter
    Create a shortcut to the .vbs script above by right clicking then "New" ⇒ "Shortcut" ⇒ "Browse" for the "HardwareSerialMonitor.vbs" Script and select it.
    HardwareSerialMonitor Should now run on startup
  • Gnat-Tacho PC HardwareTachometer
    Rupert Hirst10/16/2018 at 11:26 1 comment
    The Gnat-Tacho is just an example of what you could make with a bit of imagination.
    Using a NeoPixel Ring (16)  and the NeopixelRingGauges.ino to form a CPU/GPU Bargraph.
    Custom overlay
View all 9 project logs
  • 1
    Step 1
    • Gnatstats Tiny OLED PC performance monitor  &  HardwareSerialMonitor  Windows Client
    This project, assumes you have above average experience with Arduino, the IDE, compatible boards available and other related hardware.
    ___________________________
    Project principles:
    The HardwareSerialMonitor application  detects the sensors of most modern PC graphics, CPU and motherboards whilst, also pooling windows hardware stats.
    This data is then sent over a serial com port to an Arduino Microcontroller running the GnatStats Sketch and displayed on the OLED/TFT display.
    Compatible boards:
    •    ProMicro   (Atmel ATMega 32u4) (Gnat-Stats)   Note: supports Neopixels
    •    QT-PY / XIAO Atmel ATSAMD21  (Phat-Stats)    Note: supports Neopixels
    •     BluePill   Ti STM32F103C8   (Phat-Stats)   Note: Does not support Neopixels!!!
    •     ESP32 LoLin32 / Lite / D32  (Phat-Stats)   Note: supports Neopixels
           ATMega 32u4 boards are more suited to (OLED) GnatStats .  They do not have the required memory for (TFT) PhatStats.
    Compatible Screens:
    • OLED :  SSD1306 (i2c) or SH1106 (i2c)  128x64 Pixels  (SH1106 is not supported on the ATSAMD21 due to library restrictions)
    Note: SH1106 are usually  screens over 0.96" but not limited to. The (GND/ VCC) pin out order is different, although, more recent versions have the same pin order as the SSD1306 (VCC/GND), buyer beware!!!
    •  TFT    :  Red PCB ILI9341 (SPi) 320x240 Pixels
    Library and MCU core links are included within the Arduino sketch.
    Notes:
    •               Plug the Arduino into a dedicated USB Port, try avoid using a USB hub. Timings can be critical to avoid garbled or corrupted screen info
    •               HardwareSerialMonitor was designed for dedicated GPU's . Your mileage will vary with Integrated Graphics
    Guides:
    technopat.net: Making an External Temperature Gauge
    technopat.net: Additional Tiny Performance Monitor for a Computer
    Technopat YouTube (Turkish)
    TallmanLabs: Phat-Stats ILI9341 TFT Display Hook up Guide
    TallmanLabs: Gnat-Stats SSD1306 OLED Display Hook up Guide
    Limitations:
                         My coding ability...     eg: There is no CPU fan support, the CPU fan is a motherboard fan. It requires a motherboard chip to be detected, and the correct fan sensor.
    I can only test the hardware I own. Overall it has worked with everything I have tried.
    HardwareSerialMonitor and the way some things have to be detected.  See (4) as it relies on the "OpenHardwareMonitorLib.dll"
    OpenHardwareMonitor updates are few and far between.
    Going forward:
                               Some PC hardware support for certain CPU / GPU's is lacking, particularly certain Ryzen CPU's.
    HardwareSerialMonitor needs to be ported from the OpenHardwareMonitorLib.dll to the LibreHardwareMonitorLib.dll (open source) as this has more features such as network /ethernet and receives updates on a more frequent basis.
    My time is limited, if you can help with this please get in touch, thanks.
View all instructions
obivankenobi7o7 wrote 2 days ago point
Hi, I use Xiao with ILI9341. I upload all be required library. But It gives an error even though the whole library is installed. I could not solve. Please help me
Error code this:
                                       collect2.exe: error: ld returned 1 exit status
                                       exit status 1
                                       Error compiling for board Seeeduino XIAO.
Rupert Hirst wrote 2 days ago point
Does the blink example sketch work?
obivankenobi7o7 wrote a day ago point
I solved problem with removing all libraries and change that new one. Thank you for attention)  last question- how to i change ram icon with corsair ram?
Rupert Hirst wrote 20 hours ago point
you will have to make your own ram logo
obivankenobi7o7 wrote 19 hours ago point
Okey, thanks you
rijeve3877 wrote 07/11/2021 at 20:15 point
Hi man, is there any 3d printable file of case and enclosure for the project and models also the ones that you put the images in the gallery?
Thanks in advance
Rupert Hirst wrote 07/12/2021 at 17:19 point
Not yet but i will included them soon
Agustin wrote 07/10/2021 at 09:48 point
Hi all, love this project! made my gnat-stats with a ProMicro and its amazing, i have rainmeter skin with all CPU processes and I discovered a process called WmiPvrSE.exe with constantly spikes every 3 seconds, this happens only when auto-mode is select, doesnt happen in manual mode, i changued line 91 in form.cs from:
if (isAttached)
to
if ((isAttached) && (isConnected != true))
Seems to be fine now, but i dont know if im going to break other feature like my first attempt where i uncommented line 91 and 92 with the result of Usb_DeviceAdded broken haha, my knowledge is limited in coding
Colin Russell-Conway wrote 07/15/2021 at 11:04 point
WmiPvrSE is part of the windows 10 OS that checks windows management instrumentation.  From what I can recall (its been a while since I put that together and it kind of grew organically) in auto mode it checks if the usb device is attached periodically to make sure it disconnects gracefully.  I'll have to go through the code again when I've time and figure that one out.
Lê Công Mạnh wrote 07/09/2021 at 05:11 point
Hi , everything is working fine now , but i want to change the yellow in the ram frame to red . Where do I have to fix it?
Rupert Hirst wrote 07/09/2021 at 13:28 point
 tft.drawBitmap(16, 268, Trident2_RAM_BMP, 100, 40, ILI9341_YELLOW);
to
 tft.drawBitmap(16, 268, Trident2_RAM_BMP, 100, 40, ILI9341_RED);
Lê Công Mạnh wrote 07/10/2021 at 06:56 point
Wou :O Thank you, I changed it and it's beautiful <3
Lê Công Mạnh wrote 07/05/2021 at 08:30 point
Hi I got an error hope you can help.
I use PhatStats_TFT_ATSAMD_QT-PY the screen is working properly but the GPU parameters part is not working and missing
Fan Load
Fan Speed
Power
Hope you help me <3
Rupert Hirst wrote 07/05/2021 at 23:55 point
so little info specs?
Lê Công Mạnh wrote 07/06/2021 at 01:39 point
Yes
Lê Công Mạnh wrote 07/06/2021 at 01:44 point
I want to fix this error, please help, here is the picture: https://imgur.com/a/ZHoRRah
Rupert Hirst wrote 07/06/2021 at 22:09 point
/* Remove Specific GPU items Power/Fan RPM/Fan% */
#define enable_gpuPowerStats // Nvidia Specific???
#define enable_gpuFanStats%
#define enable_gpuFanStatsRPM
Lê Công Mạnh wrote 07/07/2021 at 06:53 point
Thank you it worked :D
It works fine on desktop but when used with laptop some functions don't work. Do you have a solution?
bryant.eadon wrote 07/04/2021 at 16:41 point
Is there a use case for this in automobiles ?  Tapping into the ODBII interface, or CAN bus would be super interesting to build this into a generic "monitor this physical thing with a configurable HUD".      Given the similarities now with computers and Cars - this could really open up the doors to an interesting set of features.
wivope7038 wrote 07/01/2021 at 03:06 point
suggestion: can we have a web server on the for example ESP32 version to access all the PC information on it maybe even remote out of the house if someone port forwarding the IP address or maybe just checking the temps and PC load from another room in the house.
Rupert Hirst wrote 07/01/2021 at 21:21 point
While I have share your thoughts, it is beyond my ability.
Rupert Hirst wrote 07/01/2021 at 21:22 point
Maybe someone would be willing to work on it?
Or try this https://github.com/juanillo62gm/Wi-Fi-Hardware-Monitor
Colin Russell-Conway wrote 07/15/2021 at 11:11 point
You'd need something with wifi or other networking and USB-Serial, so technically an ESP32 could work, but instead of writing to a screen you could alter the Arduino sketch to update a wepage or write it back to any of the hundreds of IoT home automation apps like ESPHome.  There are loads of tutorials online for those.
wivope7038 wrote 06/26/2021 at 18:44 point
Sorry there was no replay bottom so I send new one here
you asked "Whats the screen brightness like when you connect it straight to 3.3v?"
It's great when connected straight to 3.3v but when I connect it to the pin 4 it's very dim
No I don't use any resistor
Rupert Hirst wrote 06/26/2021 at 20:21 point
Yes replying on Hackaday is awful !!!
  ESP32 analogueWrite Function
  https://github.com/ERROPiX/ESP32_AnalogWrite
you the above library installed?
because you can not set brightness without it!!!
wivope7038 wrote 06/26/2021 at 21:23 point
Thanks man it worked, I had two ESP32 AnalogWrite library (ESP32_AnalogWrite)and(ESP32_ESP32S2_AnalogWrite) after I delete both of them and add the one you send I was able to change the brightness and it was bright enough.
Thanks again
wivope7038 wrote 06/24/2021 at 11:11 point
Hey man, There is no "TML_ErriezRotaryFullStep.h" file in PhatStats_TFT_ESP32_BT_Experimental_V2.0.2.2 but there is "#include <TML_ErriezRotaryFullStep.h>" in the code.
also I decommented the Encoder_PWM2 but still I can't change the brightness with encoder and the screen brightness is too low almost unreadable.
How can I be able to change info which are shown on the screen manually? like the CPU and GPU logo or other texts? because I'm having AMD FX 6300 and R9 290 but some informations are missing.
Thanks for the great hack
Rupert Hirst wrote 06/24/2021 at 15:39 point
Taken from the documentation in the code!!!
  Rotary encoder
  https://github.com/koogar/ErriezRotaryEncoderFullStep
you can not change the brightness on the encoder without it OFC.
/* Uncomment your CPU,*/
//#define AMD_CPU
#define INTEL_CPU
/* Uncomment your GPU,*/
#define NVIDIA_GRAPHICS
//#define AMD_GRAPHICS
/* Manually name the  CPU,*/
//#define Manual_cpuName
String set_CPUname = "xxxxxxxx";
/* Manually name the GPU,*/
//#define Manual_gpuName
String set_GPUname = "xxxxxxxx";
/* Manually set GPU ram total,*/
//#define Manual_gpuRam
String set_GPUram = "xx";
/* Use the Rotary Encoder for variable PWM control, connected direct to the MCU PIN,*/
/* If commented the screen brightness will default to the fixed level below,*/
//#define Encoder_PWM2 // Use rotary encoder for PWM screen brightness control  3.3v
/*TFT Start Up Brightness*/
volatile int brightness_count = 130; // Start Up Brightness 0 - 255
wivope7038 wrote 06/25/2021 at 22:33 point
Sorry I haven't read it before
Thanks a lot, all of them solved
but three more question :
1. I set the brightness value to 1000 is it okay? because the screen was so dim and still kinda is.
  if (brightness_count > 1000) {
    brightness_count   = 1000;
2. Can I connect two screen? like one ILI9341 and one SSD1306
If not have I will be able to connect one pro micro and one ESP32 to the same PC and drive the at the same time? cause on Hardware Serial Monitor I couldn't find such an option.
3. I saw Battery Monitor Voltage divider on Phat-Stats ILI9341 TFT Display Hook up Guide, Is that for monitoring with this version of code? cause I didn't find anything related to that in the code.
Rupert Hirst wrote 06/26/2021 at 18:00 point
1. no only 0-255
if its too dim there is some issue with the screen anything over 200 is very bright on my screens. Are you using a resistor on the backlight?
2. No
3. its on version 2..0.6
yusuf bayram wrote 06/21/2021 at 02:13 point
I use ILI9341 and XIAO with Neopixel ring. Everything is working well but Neopixel lights randomly and only red. I tried both 220 and 330ohm resistor between A6 and Din connectors and did not work. Is ist only suppouse to be 300ohm or I am doing something wrong? In the meantime I don't use Rotary.
Rupert Hirst wrote 06/22/2021 at 12:24 point
#define enableNeopixelGauges //
All the resistor does is protect the data pin even 100 ohms would be fine
Colin Russell-Conway wrote 07/15/2021 at 11:16 point
Yeah I'd go with a 100 ohms, but the XIAO may not have enough power for a neopixel ring, try dropping the neopixel brightness in the arduino sketch.
estoyarto wrote 05/15/2021 at 17:52 point
Hi, great project ! Its possible to use https://ipc2u.com/catalog/vl050-8048nt-c01  , from and android of things kit?
Rupert Hirst wrote 05/15/2021 at 19:52 point
No, it is not even remotely similar.
estoyarto wrote 05/16/2021 at 00:14 point
Thanks Rupert!
phamanhduc1011 wrote 05/11/2021 at 12:57 point
i tried phat stats, i modified the code to fit with my set up (no encoder, no neopixel) and the upload was successful. However, it keep showing NO COM DATA. I wonder if anythings could go wrong?
Rupert Hirst wrote 05/11/2021 at 14:57 point
Thats not much information
Ozkan wrote 05/05/2021 at 14:45 point
Hi, Can I turn off Auto Mode on HardwareSerialMonitor? Can I get it to start by selecting the port I specified?
For example; Let's start by selecting the COM7 port.
https://prntscr.com/12j1okc
Rupert Hirst wrote 05/05/2021 at 17:51 point
It does not make much of a difference anyway as it writes the last port to a config file in the folder. When HardwareSerialMonitor starts it uses this information.
So it will always start use the last port, except for BT where you have to manually click the port again.
When it is in Automatic Mode the icon will be green.
Select the port you want to start, then click Automatic Mode at the top.
You will see a tick mark and the port named at the top in the Automatic Mode section.
stefan.schnitzer wrote 05/04/2021 at 09:30 point
Very nice project, I built a version for my PC.
https://img-9gag-fun.9cache.com/photo/axM3eWK_460swp.webp
Rupert Hirst wrote 05/05/2021 at 14:28 point
nice 3d printed enclosure
yusuf bayram wrote 04/27/2021 at 21:43 point
Hello, I tried to upload the project to Seeeduino XIAO and It shows me error "No device found on COM*" Looks like i did everything correct as I see.
https://imgur.com/a/JuBgIfB
Rupert Hirst wrote 04/27/2021 at 23:26 point
Do not use a USB hub, try a different usb port.
I have had problems with some USB3 ports when uploading
yusuf bayram wrote 04/28/2021 at 00:05 point
I don't use USB hub and tried all USBs on my pc, Didn't change anything.
Rupert Hirst wrote 04/28/2021 at 02:05 point
well i guess you messed up the flash.
Enter Bootloader Mode
Sometimes the Seeeduino XIAO port may disappear when user programming process fails. we can solve this problem by the following operation:
Connect the Seeeduino XIAO to your computer.
Use tweezers or short lines to short the RST pins in the diagram twice.
The orange LED lights flicker on and light up.
At this point, the chip enters Bootloader mode and the burn port appears again. Because the samd21 chip has two partitions, one is the Bootloader and the other is the user program. The product will burn a bootloader code in the system memory when it leaves the factory. We can switch modes by performing the above steps.
https://wiki.seeedstudio.com/Seeeduino-XIAO/
yusuf bayram wrote 04/29/2021 at 00:34 point
Those steps worked. Thank you.
Ozkan wrote 04/21/2021 at 19:42 point
hi, Everything works fine in the 1st picture, but when I enter the game, it is like the 2nd picture.
1. https://prntscr.com/11tb244
2. https://prntscr.com/11tb1zs
What is the problem ? Help pls.
im using Bluepill + 2.8 TFT (PhatStats_TFT_STM32F1_V1.6.3)
ragook wrote 04/21/2021 at 23:17 point
Maybe you have a garbage un-shielded motherboard USB header adaptor?
Rupert Hirst wrote 04/23/2021 at 00:08 point
You could try this to slow the connection down
/* Delay screen event, to stop screen data corruption ESP8622 / ESP32 use 15 or 25, most others 5 or 0 will do*/
int Serial_eventDelay = 15;
It should'nt be doing it really, I have no problems with the STM32.
BTW, I am no longer supporting the STM32 I did one last update v1.6.5 you can find it in the files section Depreciated2.zip
Going forward it will be ATSAMD  (including ESP32 maybe!!! due to bluetooth)
Edgaras wrote 04/15/2021 at 10:02 point
Hello, does anyone else experienced issues with freezing? I got this built and it freezes every 5-10 mins, I have unplugged the USB and plug it back in so it would start showing live details again
ragook wrote 04/15/2021 at 14:45 point
No Zero freezing here i run it all day long.
You havent provided much info.
What PC system ? What Arduino? Which Screen?
Edgaras wrote 04/15/2021 at 14:52 point
Good point
cpu: ryzen 3600
ram: corsair rgb pro 3000 16gb
gpu: rtx 2060 msi ventus
mobo: asrock steel legend b450
I use Arduino micro + SH1106 1.3inch oled screen
Code works perfectly fine, top right corner flashes D1, D2, D3 (as separate pages of info) for few minutes, and then it stops refreshing and freezes with data on oled screen frozen and not changing anymore. Thats when I have to unplug USB, plug it back in and it starts working again until it freezes again.
ragook wrote 04/15/2021 at 15:07 point
Are you using a USB hub?
"Notes:
              Plug the Arduino into a dedicated USB Port, try avoid using a USB hub. Timings can be critical to avoid garbled or corrupted screen info"
Edgaras wrote 04/16/2021 at 13:07 point
direct usb to motherboard and front io panel tried, both same result. Actually motherboard USB froze faster than front io port
Rupert Hirst wrote 04/16/2021 at 13:46 point
i have heard that Ryzen motherboard chipsets have a problem with frequent USB disconnects
phamanhduc1011 wrote 04/15/2021 at 09:56 point
there are ILI9225 driver displays in my area, LCD TFT 2.2 SPI to be specific. Is this screen be used with this project?
Rupert Hirst wrote 04/15/2021 at 14:41 point
ILI9225 resolution 176x220
ILI9341  resolution 240x320
It has to run native, its not like a TV with scaling
phamanhduc1011 wrote 04/15/2021 at 23:50 point
thanks for your response
cagancelik88 wrote 04/12/2021 at 10:51 point
Just curious why has bluepill support been dropped without any explanation? I also cannot see latest working bluepill & tft lcd combo (which was v1.6.3) in your deprecated.zip file.
Rupert Hirst wrote 04/12/2021 at 16:22 point
Hi,
STM32 was dropped because all the PM's regarding problems are to do with the BluePill. It is also, harder to maintain, as some features going forward simply will not be supported.
The BluePill maybe be cheap at $3 but, so is the QT-PY $6 and XION $5
I don't save money when someone choses a BluePill over the alternative, I just get questions which involve lengthy answers.
The goal was always to have one platform, to rule them all :)
PS: The depreciated.zip has been updated
Ozkan wrote 04/06/2021 at 14:15 point
When I compile the code, I get an error like the picture.
https://prntscr.com/115skz0
Rupert Hirst wrote 04/06/2021 at 21:00 point
Look at the error and  try reading the line regarding the adafruit grfx library in the sketch
Ozkan wrote 04/08/2021 at 19:01 point
I am using BluePill, all my connections are as in the diagram. I have successfully compiled the code and loaded it into the microcontroller and connected everything correctly. I see nothing but the white screen.
https://prntscr.com/117jnxx
https://prntscr.com/117jo0f
