Gnats-Stats Updates
A project log for Gnat-Stats, Tiny OLED PC Performance Monitor
Arduino OLED PC Performance Monitor with Client software
Rupert HirstRupert Hirst 10/16/2018 at 11:261 Comment
Version 1.3:
Top Config option to disable all pre-selected power/gnd pins on Arduino pins D4 and D5 when not powering OLED from ProMicro
Top Config option to disable/enable "activitychecker" (Enable blank screen on serial timeout eg: PC powered down, Disable to retain last sampled info eg: PC crash or overclocking diagnostics)
Option to trigger an event at a given CPU or GPU threshold eg: LED indicator at 100% CPU Load.
NeoPixel Ring CPU/GPU Bargraph example:
Gnat-Tacho
Custom overlay
fuhiyal wrote 04/18/2019 at 10:46 point
Hi,
i built this using Arduino Nano and sd1306 . I am newbie to this types of projects(may be in all arduino projects).I successfully uploaded the code to the board and it was in 128x32. I didn't configure the oled library and then i realized and changed.But after changing the code to 128x64 , in  my display no value is being shown, Only CPU GPU Mhz C etc.(When 128x32,some values shown correctly but not full screen that's why i changed the res).
How to fix that ? Does it have something to do with the main code? The code in in 128x64 and i can't find the problem ;( . Can you help me?
