PhatStats PC Performance TFT Display
Arduino TFT PC Performance Monitor with Client software
PhatStats ili9341 TFT PC Performance Monitor Display
PhatStats (TFT) form an Arduino serial display. HardwareSerialMonitor is a PC serial client, both are written by Rupert Hirst and Colin Conway.
HardwareSerialMonitor Windows client reads the hardware statistics from the PC.
This data is forwarded over the hosts’ serial  port to an Arduino compatible micro processor. It is then, displayed using the Phat-Stats sketch.
This project, assumes you have a above average experience with Arduino, the IDE and the compatible boards available.
The HardwareSerialMonitor was designed for dedicated GPU's . Your mileage may vary with Integrated Graphics
To help with construction there are hook up guides, links below:
Phat-Stats ILI9341 TFT Display Hook up Guide
Going Forward:
The project needs to be ported over to LibreHardwareMonitor , a fork of OpenHardwareMonitor  for future support, as this gets a lot more updates for new PC hardware. If anyone can help please get in touch, thanks.
http://tallmanlabs.com
http://runawaybrainz.blogspot.com/
https://github.com/koogar/HardwareSerialMonitor
https://github.com/koogar/Gnat-Stats
Gnat-Stats (OLED) has moved to a new project page here
The above software/code is licensed under the following terms:
GPL v3
Gnat-Stats, Phat-Stats & Hardware Serial Monitor Copyright (C) 2016 Colin Conway, Rupert Hirst and contributors
This program is free software; you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation; either version 2 of the License, or (at your option) any later version.
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details.
You should have received a copy of the GNU General Public License along with this program; If not, see http://www.gnu.org/licenses/.
HardwareSerialMonitor only was inspired by Psyrax's "SerialSender". Psyrax is given attribution and thanks, by being an honorary member of the project.
WeeStatServer-0.5.2_Libre.0.9.3-pre256_Binary.zip
Alternative to HardwareSerialMonitor but uses LibreHardwareMonitor libraries. Requires .net6
x-zip-compressed - 3.96 MB - 10/06/2023 at 15:16
Download
HardwareSerialMonitor_v1.4.4_9600_OHM.0.9.6.1.PR_NET4.8_Binary.zip
added experimental Intel Jasper Lake Support added experimental Intel Rocket Lake Support added experimental Intel AlderLake support added Alde Lake Mobile support added Intel RaptorLake support Boris Vogel https://github.com/BrsVgl/openhardwaremonitor
x-zip-compressed - 1.46 MB - 09/22/2023 at 11:57
Download
x-zip-compressed - 171.34 kB - 06/20/2023 at 00:27
Download
x-zip-compressed - 272.40 kB - 06/20/2023 at 00:24
Download
TachoStats_V3.1.7.1_SeeedRoundDisplay.zip
https://www.seeedstudio.com/Seeed-Studio-Round-Display-for-XIAO-p-5638.html Seeed Studio Round Display for XIAO - 1.28-inch round touch screen, 240×240 resolution
x-zip-compressed - 180.38 kB - 06/20/2023 at 00:07
Download
View all 11 files
View all 8 project logs
View all instructions
daniel_geiger wrote 01/09/2018 at 12:15 point
Can you add support for temperatures on Intel Coffee Lake? (i7-8700k w/ asus strix z370-e) Would be nice
Rupert Hirst wrote 02/05/2018 at 16:45 point
Some one needs to add the support on the Open Hardaware Monitor github then I can compile it
c wrote 12/30/2017 at 15:58 point
Please could you add support for temperatures on AMD Ryzen (particularly the r5 1600 on the asus prime b350-plus)?
 I've tried compiling https://github.com/openhardwaremonitor/openhardwaremonitor/pull/970 and https://github.com/LibreHardwareMonitor/LibreHardwareMonitor, both of which have ryzen support and looking through the source code but I can't spot a problem and neither works.
Rupert Hirst wrote 02/05/2018 at 16:47 point
i managed to compile Kraust's Fork here  0.8.1.0
https://github.com/Kraust/openhardwaremonitor
Added Ryzen Temperature Support (Off the Chip, not the Motherboard)
If you want to test the compiled DLL for Ryzen send me a PM with your email address
Tomas wrote 08/17/2018 at 00:44 point
please send me the ryzen compiled DLL, I have been working on this and I cant make the cpu core speed or the cpu temperature work..
amigof wrote 06/04/2019 at 19:36 point
Please send me ryzen DLL!
amigofs@gmail.com
Thanx!
Rupert Hirst wrote 10/09/2018 at 18:09 point
Ryzen support seems an ongoing issue with all forms of open hardware monitor.
Hari Wiguna wrote 06/05/2017 at 12:53 point
Rupert, that's a crapton of info you packed into 64 pixel tall display! Fantastic!
PS: Thanks for following my Giant RGB LED Cube project!
